    Dec 2008
    ASR-C XC forks 100mm or 120mm
    Hi
    I've just got a ASR-C at a blow out price in the UK, want to use it as a fast trail bike.
    Thinking of going 120mm for the slacker head angle, is this the right way to go or would i enjoy the ride more using 100mm?
    Cheers Phil
    Tribe member
    Reputation: feltbee's Avatar
    Hey Phil! I've used to have an aluminum ASR that I ran at 100mm and 120mm. I've got an ASRc now and run it at 120mm. I don't think I'd enjoy riding at 100mm as much.
    Dec 2008
    Quote Originally Posted by feltbee View Post
    Cheers thanks for the info...
    Reputation: tonyinatlanta's Avatar
    I have an ASR-C that I initially had a Fox F32 RLC 100mm fork on it. I switched it out last year for a 120mm with a remote lock-out switch and love it. The 120mm I can ride more aggresive and also for longer rides without getting worn out/beat up feeling and if I need a stiffer ride for climbs or sprints in XC racing it's super easy to lock it out with the remote switch. One thing that did take some tinkering with when I switched was getting the stem length and stack height optimized because the 120mm sits higher, so initially when I set it up with the same settings as my 100mm I was washing out the front end cause my center of gravity was up too high. But once I got the stem height/angle slammed pretty aggresive it actually put me in a more aggresive stance and I could really dig deep into turns more than I ever could with the 100mm fork.
  1. Jet 9 RDO - 100mm or 120mm fork?
    By drz400sm in forum Niner Bikes
    Last Post: 01-14-2013, 07:33 PM
  2. Lefty PBR 120mm down to 100mm?
    By Bradyab in forum Cannondale
    Last Post: 09-09-2012, 08:48 AM
  3. 100mm vs 120mm Fork
    By mtber13 in forum Specialized
    Last Post: 10-22-2011, 10:11 AM
  4. 100mm vs 120mm Fork
    By mtber13 in forum General Discussion
    Last Post: 10-18-2011, 08:01 AM
  5. 100mm vs 120mm Fork?
    By Ace5high in forum 29er Bikes
    Last Post: 09-06-2011, 01:10 PM
