Results 1 to 2 of 2
    Reputation: titusquasi's Avatar
    ASR 7 Headset Lower Cup Removal
    Has anyone come up with a way to remove the lower headset cup from an ASR 7 (or 2011 575) without paying $100 for the special Yeti tool? I have a Cane Creek 110 and the headset is pressed up very close to the headtube taper inside. There is no way to get a standard removal tool to work and a screwdriver won't work. I may try to put a bend in a flat screwdriver to see if I can get in that tiny gap between the headset and the headtube taper. Thanks for any assistance.
    Got it done.
    Old flat screwdriver in a vise. Made a bend. Took some time to shape the tip to sit flat on top of the headset. It took a bit to get it moving...slow and steady while working my way around the headset after that.
    Attached Thumbnails Attached Thumbnails ASR 7 Headset Lower Cup Removal-2013-01-06_12-22-14_41.jpg
