XO rear der., and Twist Shifters, XT cranks, e-13 DRS
Juicy 7 brakes, Gravity Dropper seat post,
Hope Pro II with ZTR Flow
For suspension, I have different XC and DH configurations.
For DH I use a Vivid 5.1 and a Totem Solo Air.
For XC I use a Monarch 4.1 and a Lyrik Solo Air (modified for 176 mm travel)
With the Kenda tires I'm using the XC build comes in at 28.9 lbs. I haven't weighed the DH config.
I actually tried to get more travel initially, but didn't think about the too-short rebound damper rod. I posted the mods on the Shocks and Suspension forum. There are still some questions about durability, but I'm pretty optimistic at this point.
BTW, the weight I posted was with a Thompson seat post. I think the GD adds about half a pound.
Best brakes I've ever had. I ran than for 6 months on my 575 and put 'em on the 7.
No issues installing the Hammerschmidt. I called Yeti and asked them about it---while they wouldn't come out and say anything officially they alluded that you could just bolt on the Hammerschmidt and avoid any of the cutting the hammerschmidt manual talks about. The BB and ISCG tabs are already faced and aligned. I did need to use the spacers that came with the kit but not biggie.
The shifting is unreal. Can't wait to test it on some real stuff.
Wow, these 7s look so serious. I'd love to know how they perform with the RP23.
I am not a weight winnie but in summer time I like my bikes light. It's getting so dusty and hot (and I'm not getting younger eighther) here that it's just not that fun to peddal up hill. After retreating to my HT during the summer, I find my 575.............................heavy?.
I was pretty unhappy with the RP23, since it seemed to bottom out very easily, even when I used less sag than recommended. I switched to the Vivid which I liked very much, but caught the weight weenie bug and switched again to a Monarch. The Monarch is "okay", but it still bottoms out pretty easy - not as easy as the RP23, though.
I started thinking I might pickup another RP23 (I had already sold mine) and get it Pushed. I sent them an email asking what they could do for me, and here is the response:
The biggest problem with running the air shocks on the longer travel bikes is the fact that Fox only offers those shocks with the high volume air sleeves. These air sleeves are the source of your problems causing the need to run excessive air pressure and they bottom out too easily. I would hang on to the Monarch because we will be tuning those shortly and offering air volume reducer kits at the same time. We do not have any ETA right now but it will be soon as we are riding the prototype Monarchs currently and as soon as it is available it will be up on our web site.
So now I check the Push site at least once a day...
Yes, even the early 7's had the 2010 shock. Admittedly I didn't give it much of a chance. I rode it around the house and hopped off a few curbs. When it bottomed out I added more air and repeated. It still bottomed out. Since I had a Vivid available I swapped them and sold the RP23.
siza M Turquoise
TALAS 36RC2 FIT
Gravity Dropper Turbo
Avid Elixir CR, Tungsten lever with Goodridge lines and 203 XTR rotor F 160 XTR rotor R
X.9 Shifters and rear D
Goodridge cables white
Sunline V One 754 lowrise
E13 DRS with 2009 bashring white
I´m 174 cm and it fit perfect to me... looks big but when you sit on it and ride... it´s totally different, the cockpit is close and very fast handly....
I posted it here. Basically, I made a shorter base plate for the air side of the fork. I tried to get the full 7" (178mm), but the rebound damper shaft was too short and made a horrible racket when the fork topped out.
I use the air for XC and coil for FR and DH. I should really just stick with the coil shock. It is so much smoother, and never bottoms out. I think tiggs got his Vivid Pushed, and liked it even more. I was thinking about doing the same, but someone at Push replied to my email saying they were almost ready to Push the Monarch and I should wait. That was several months ago, though.
I bottom out the Monarch regularly on XC trails. It's way stiffer than the RP23, though, and more than a pound lighter than the Vivid. It handles small bumps pretty well considering I keep the sag at about 10%. It has a certain range, say, when riding down stairs, that will shake your fillings out if you take it at speed.
Except for the weight there's nothing about the Vivid I don't like. I swapped the DHX coil for a Vivid on my ASX and liked it so much I started with the Vivid when I got the 7. The RP23 lasted just long enough for a test ride around the house.
Dude the ASR-7 is one tall frame.. dang i'd like to see someone next to it. Dang.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
