• 09-18-2014
    BlownCivic
    I'm a bit late to the game, but just got finished (more or less) my lightweight ASR5C build:
    19lbs, 5ozs
  • 09-18-2014
    Procter
    Well done, fantastic weight. You could go even lighter with a 1x11. Just sayin'.
    Mine's still in the 26lbs arena with my Haven build. :P
  • 09-19-2014
    BlownCivic
    I'd die with a 1x11 on a particular race that I participate in every year - Squamish Test of Metal.
  • 09-19-2014
    Procter
    Looks like you have a 24t granny? And I assume a 11-36t rear?
    So:
    Your current lowest gear would be 24x36 = .7
    1x11 would be 30t front x 42 rear = .7 as well.
    ( I'm using BikeCalc.com - Bicycle Gear Ratio Chart )
    But, just jokin around, not trying to convince you to go 1x11. Its still pretty pricey, my bikes are 2x10 and 1x10.
  • 09-19-2014
    BlownCivic
    You're right in that there wouldn't be a big diff on the low gears from my build to the 1x11 (I'm currently 40/26 at the front and 11/36 in the back). I get .72 and if I went 32 front and had the 42 rear I'd be at .76. However there are some long fast downhill sections too and I was spinning out the last time I rode the race with a 42 front, so it'd be nuts with a 32 front. I need the range of 2x10 for that race.
  • 10-16-2014
    scottspark60
    My ASR5C
    Hi guys. Just sharing here my ASR5C build.
    Frame: Yeti ASR5C 2009, size S
    Fork: 2012 Fox Fork 140 Float RLC, 15mm TA
    Handlebar: Easton Haven Alloy 31.8 x 700
    Stem: Thomson X4, 31.8x70mm
    Headset: Chris King
    Grip: ODI Rogue Lock-on
    Seatpost: Fox DOSS 100mm travel (housing replaced with Jagwire white)
    Saddle: Fizik Arione (to be replaced with Fizik Gobi Kium black/red)
    Brakes: SRAM XO
    Shifters: SRAM XO
    RD: SRAM XO Type 2
    Wheelset: Easton EA90 100x15mm TA front, Easton EA90 142x12mm TA Rear
    Tires: Schwalbe Rocket Ron EVO TLR, 26x2.4 front and rear (stans tubeless set-up)
    Cassette: SRAM PG1070 11-36T, (17T removed and added e13 42T red cog)
    Rotors: AVID HSX 180 front and 160 rear
    Crankset: SRAM XO 3x10 converted to 1 x10 (Raceface NW 32T chainring)
    Chain: YBN 10 speed
    Pedals: Xpedo white red and CB Candy 3 red
    Weight: 11.2Kgs
    thanks for viewing
  • 10-21-2014
    igno-mtb
    Frame Yeti ASR 5 alloy, size L
    Fork Fox Float FIT RL 120
    Seat post Truvativ Stylo T20
    Stem Race face Evolve 70mm
    Handlebar Race face Evolve 720mm
    Saddle Specialized Riva
    Brakes Avid BB7
    Tires Forté Pisgah 26x2.3
    Wheelset Mavic XC717 to XT hubs
    Headset FSA The Pig
    Brake rotors SLX centerlock
    Brake levers Avid FR5
    Grips Ergon GR-1
    Pedals Shimano PD-520
    Rear Derailleur Shimano XT
    Chain SRAM 1050
    Shifters Shimano SLX
    Cassette Shimano XT
    Crankset Shimano SLX W/Race Face narrow wide 32t
    Bottom Bracket Shimano XT
  • 10-28-2014
    sam_buka
    Hi guys , some lovely looking bikes here. I've just posted a couple of asr questions here which I'd love to get your opinions on:
    http://forums.mtbr.com/yeti/yeti-asr...te-936709.html
  • 11-11-2014
    Haylex
    My 5c, after riding it for about 6 months with the 120 fork I have changed to a 150 to see how it goes, hopefully I haven't ruined it! I ride it uphill to go downhill though and have lightly beefed it up somewhat to suit.
    Medium frame
    XT drivetrain and brakes
    32t chainring and bashguard
    DT swiss 350 32h / ZTR crest wheelset
    Fox factory 150 ctd fork / 130 rp23 shock
    50mm stem, 720 bars
    Fox DOSS dropper
    12x142 rear axle
    Rock razor rear / Hans Dampf front
    Weight unknown, somewhere in the 11kg range I'd say
  • 11-20-2014
    gotdurt
    DU bushing alternatives
    My ASR-5 has a hunger for DU bushings... I recall reading in the past about others changing to a pin-type busing (similar to the polymer versions), as well as using RWS needle bearings, but I can't seem to find those threads now, and can't find applications for the 23.5mm size (which seems to be proprietary) in either option.
    So... those that have made a conversion, any conversion, what did you use, and how has it held up?
  • 11-20-2014
    ruscle
    I used the RWS needle bearings originally which worked great. I ended up converting the suspension front and back to BOS which was a huge improvement all round, so I'm running the BOS Viper out back which is so sweet and smooth. They sell their own needle bearings to fit the shock which I found to be a much better/tighter fit than the RWS needle bearings. Feels nice having the needle bearings on the suspension making it all buttery smooth.
  • 11-20-2014
    gotdurt
    Do you remember what size you used? The guys at RWS aren't even sure, since they don't have a direct application for the ASR-5.
  • 11-20-2014
    ruscle
    Will check tonight once home from work for you.
  • 11-21-2014
    ruscle
    Spacer measurements are found in the online manual for the ASR-5 in the exploded parts diagram. link below. Look on page 13 (or 26 actual number on the bottom left corner of page)
    http://www.silverfish-uk.com/DocumentHandler/12409
    The top spacer is 22mm and the bottom is 23.5mm with a 8mm inner dimension for the bolt.
  • 11-21-2014
    gotdurt
    Awesome, thanks.
    Has anyone tried the Fox polymer bushings on the lower/rear eye? Matt at Yeti said it won't work, that it would fail, but no explanation... I don't see why the DU bushings with the aluminum reducers ("hats") would be superior in that application... Tempted to try it anyway.
  • 11-21-2014
    gotdurt
    Unfortunately the 23.5mm is a proprietary size; fox does not offer it (this is per both Fox and Yeti). That's where the challenge is.
    Fox makes a 23.36mm kit for the polymer bushings, but Yeti says it won't work, that I have to stay with the old style 3pc (I'm skeptical) that I have to get through a Yeti dealer.
    RWS says they don't have a direct fit on file for the ASR-5 (probably for this reason), but that we can probably make something work, so we are still trying to determine what to start with; their .5mm shims will cause an offset (that's why I was hoping you had a part #, since I know that worked).
  • 11-21-2014
    ruscle
    I remember that the BOS lower spacer was to wide so just slowly sanded each side as equally as possible till it fit flush. Didn't take much effort and was just like taking the anodising off. I've had zero problems in 2 years. I used Custom shims made by local machinist to fit either side of kit to make up to 23.5 with the RWS kits, was quite fiddly if I recall, but worth it. I think you can get them made on eBay as well for very little money.
    You can get the little guide pin tool to help line up the bolts/spacers which makes the job easier. Link below
    YETI Guide Pin Tool | Yetifan
  • 11-21-2014
    ruscle
    There's always the BOS kits, I'm not 100% sure the needle bearings are the same size to fit Fox shocks.
    http://boutique.bosmtb.com/spare-parts/bearing-kit.html
  • 11-21-2014
    gotdurt
    Hmm, at $99 shipped to the US, I think I'll explore local (US) options. Haven't heard of BOS, I'll google some and see if they are available in the states. Having some shims made for the RWS bearings might not be a bad idea, in fact, I might even be able to face-down the RWS shims, only need to go .18mm on each.
  • 02-26-2015
    joefang
    Sharing my asr5
    Frame: Yeti ASR5 small
    Fork: FOX 36 140mm
    Handlebar: Easton Haven 35 750mm
    Stem: Easton Haven 35 70mm
    Headset: Chris King
    Grip: ODI TLD Lock-on
    Seatpost: KS LEV
    Saddle: Fizik Gobi XM
    Brakes: Shimano XTR trail
    Shifters: SRAM XX1
    RD: SRAM XX1 type 2.1
    hub: Chris king 20mm front, 142x12 rear
    rim:ZTR arch ex
    Tires: Schwalbe Hans dampf 2.35 front, maxxis DHR II 2.3 rear
    Cassette: SRAM XX1
    Rotors: Shimano RT86 180mm/160mm
    Crankset: SRAM XX1 arm+wolf tooth
    BB:Chris king
    Chain: SRAM XX1
    Pedals: Shimano m785
  • 02-26-2015
    Procter
    Nice man! That's a beefy fork for that bike, hope the rest of the bike can handle it :P
  • 02-26-2015
    gotdurt
    8 Attachment(s)
    Okay, new theme; I need motivation :p I've seen a lot of photos of pretty ASR-5s posing in living rooms and garages, back yards etc, details of parts...
    Let's see some in context; in their element, doing what they do best...
    Here are some of mine from last fall, from an enduro and a trip to AZ:
    Attachment 967888Attachment 967882Attachment 967884Attachment 967885Attachment 967886Attachment 967887Attachment 967889
  • 02-27-2015
    gio80
    last week snow ride
  • 02-27-2015
    gotdurt
    Originally Posted by gio80 View Post
    last week snow ride
    Holy cow, you are more committed than I am; if it is less than 40 deg out, I stay inside :p
  • 04-03-2015
    ride the biscuit
    Could say the exact stack height for heatube plus headset for a medium asr 5? It looks like all the models use external headsets. I'm keeping my eye out for a medium frame, but now I'm thinking my fork's steer tube will be too short which would jam up my plans.
    thanks
  • 04-03-2015
    ride the biscuit
    Originally Posted by gotdurt View Post
    As for what I'm coming off of, I have several bikes, but the ASR5 is replacing a Stumpy FSR Comp. I also have a new med '13 Trek Fuel EX9 frame, with all the right measurements, that is begging for a shot.
    Well, already bumped the thread once. Its been a while since this conversation, but I would love to know how you felt about the 13 fuel ex.
    These are the two bikes I'm considering. 5'10" and currently on a M devinci dexter, which is bad ass and fun; however, my fork is a marz 44 rc3 ti (the 140mm version) and I'd like to get a frame to suit that fork rather than find a shorter fork to fit that frame. My build is a lot more trail than XC, anyways.
  • 04-07-2015
    BlownCivic
    thanks
    I'll measure when I get home. Mine's set up with a combo of parts for the headset to keep the stack height as short as possible (Lefty PBR130). However, it's also a straight 1 1/8" steerer. Is your's tapered?
  • 04-07-2015
    NightOWL
    the ASR-5 has a tapered head tube
  • 04-07-2015
    ride the biscuit
    I have a straight HT. If you have a tape measure handy I'd appreciate it, but at the moment I'm leaning towards a fuel ex mainly since the suspension layout is fairly similar to my current bike. So I shouldnt be surprised by a different feel. So no need to go to any trouble if its not right there at arms reach. Thank you!
  • 07-15-2015
    Unboundboarder
    Question please answer!
    Originally Posted by mnigro View Post
    Vanilla build with XT drive train, XX Rev, GD post and Oozey wheels. No ride time as I just built it up yesterday but it feels good so far. Can't wait for the ifrst ride tomorrow... now if the rain will hold off.
    Attachment 776665
    HEY JUST WONDERING WHAT YEAR/ EXACT MODEL(if you know) your bike is! I bought one but have no clue and can't remeber mone but it looks just like yours
