Page 10 of 18 FirstFirst ... 6 7 8 9 10 11 12 13 14 ... LastLast
Results 226 to 250 of 430
  1. #226
    Here's my new 5
    Vanilla build with XT drive train, XX Rev, GD post and Oozey wheels. No ride time as I just built it up yesterday but it feels good so far. Can't wait for the ifrst ride tomorrow... now if the rain will hold off.
    The ASR 5 build/picture thread-asr5.jpg
  2. #227
    Damn! That blue frame and your build look nice and clean.
    Bravo!
    Lynn Woods
    JRA cycles
  3. #228
    Thanks. I was worried how it would look if I went with the blue frame. Hoped for an Ano Black but this is all that was left. I would have bought it no matter what color it came in though. My rear brake line was a bit too short so had to improvise with the routing until the new line comes it.
    I also went a little crazy with the frame tape on the rear triangle... Not much bare carbon left back there.
  4. #229
    Jan 2009
    Quote Originally Posted by mnigro View Post
    I did the same. I also do like the chainstay protection Yeti installs from the factory.
  5. #230
    Any bigger riders on a 5 that can chime in on Psi of the ctd? I'm 200lb and running a 1/2 inch sag, should be spot on 25%, which for me is 195 psi. I had this on its maiden voyage today and it tended to blow through the mid travel. I was a bit surprised because I though the bike was supposed to have a more firm mid stroke. I was thinking that it might be initial stiction on the shock that is causing it to show 25% sag when it might really be softer but I'm rocking around a bit and then resetting the o-ring so it should be correct.
    What is your weight and what psi you running?
  6. #231
    Btw, the bike rides and climbs well with the zero stack bottom cup I'm using and the Rev at 130mm. Gets hung up on the chunky stuff during steep climbs a bit but no more than my old motolite. Really flickable and fun bike. Digging it so far.
  7. #232
    Feb 2013
    Just got my bike back from the LBS after transferring all my parts over from my roscoe... well happy!!
    Attached Thumbnails Attached Thumbnails The ASR 5 build/picture thread-bike.jpg
  8. #233
    Austin, Texas
    Reputation: smokehouse4444's Avatar
    Lots of beauties posted recently. Love these bikes. I've noticed on mine that the difference when I switch from the 29er to the 5 are not as dramatic. Not sure why, probably head angle or something, but couldn't be happier with the turquoise baby!
  9. #234
    Oct 2012
    Anybody weighed the ASR-5 X0/x9 build from CC yet? Mines is coming in the next couple days so just curious!
  10. #235
    CC should give the total build weight at the bottom of the order page.
  11. #236
    Oct 2012
    Ya it said 25.88 pounds, just seemed a hair on the light side for an aluminum frame with a 140 on it. Stoked if its really that light!
  12. #237
    Jan 2013
    Here's mine. Just added a WTB yeti saddle and will be getting a dropper seat post soon.
    Spec is
    ASR5a in large
    Fox Float FIT 140mm
    Xt all round
    Hope hubs with stans arches
    Thomson 70mm stem
    Purgatory tyres 2.3 front and rear
    My new Yeti by lehutch, on Flickr
    Llandegla, frozen but fast by lehutch, on Flickr
    Best bike ever
  13. #238
    Long live the ASR-7
    Reputation: Doba's Avatar
    Nov 2008
    Yeti Cycles ASR-5 with Fox Float CTD - 2012 from Departmentofgoods.com
    If anyone is looking for a smoking deal on a frame, here you go.
  14. #239
    Reputation: BMC FS's Avatar
    Dec 2011
    At Moonscape
    ASR5 Med frame Al
    Fox RL 140mm fork
    FSA SL K bars and seatpost
    XT 38/28 crankset
    Sram XO rear derailleur X9 shifters and front derailleur
    Reynolds Wheelset
    Forte Tires, Tsali rear, Pisgah front
    Beautiful Loaded stem 50mm
    Stainless Eggbeaters
    The ASR 5 build/picture thread-moonscape.jpg
  15. #240
    Dec 2011
    Quote Originally Posted by ddprocter View Post
    Not sure where exactly you're referring to - I got some scrapes where the red arrow is, so I covered this with a piece of stick-on frame guard. I'm not sure whether this was chain slap or hitting it on roots and rocks - chain can't really get up there very easily unless it comes off. But, frame guard fixed it.
    Attachment 772403
    Not sure what you mean here either, but, on all my bikes, I've always had chips and chain slap all around where the green arrows are, so I wrap both the chainstay and the seatstay with extra handlebar tape or cut an inner tube down the middle and use it for wrap.
    Sorry for the late late reply. Here is where the chainlsap is. Don't know how to put those fancy arrows on an attachment but if you blow up pics you could see nics. The ASR 5 build/picture thread-lower-chain-stay.jpgThe ASR 5 build/picture thread-upper-chain-stay.jpg
  16. #241
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Quote Originally Posted by BMC FS View Post
    Sorry for the late late reply. Here is where the chainlsap is. Don't know how to put those fancy arrows on an attachment but if you blow up pics you could see nics. Click image for larger version.
Name:	lower chain stay.jpg
ID:	785294Click image for larger version.
Name:	upper chain stay.jpg
    Ok so on Pic 1: have a piece of stick-on frameguard there now. You could even use 2 layers. This is needed pretty much on every bike I have ever had, even my other bike with a MRP G2 chainguide. Don't know how it gets up there but it does. And, even if you used a chainguide to reduce chain slap, one day you'll probably get chainsuck up there on a muddy day, so best to protect it.
    On pic 2: I think this is a pic of chips on the bottom, outer edge of the chainstay, right? This is most likely chain slap and unavoidable. I highly recommend wrapping the entire chainstay as in my pic, with bar-tape or an inner-tube cut down the middle. This has also been a necessity on every bike I've owned.
  17. #242
    Dec 2011
    Thanks for the tip. Have a piece of vinyl tape for temp. Need to get some of the Lizard skin silicone tape pieces. Just trying to keep it clean looking as possible so trying to avoid a big wrap of some sort unless I can find something cool looking.
  18. #243
    How does the chain get way down/over there on pic #1? Are you sure it's not from rocks being thrown up from the front wheel? As for the bottom pic, I put a piece of black electrical tape right there on my frame, and there's not a scratch after a full season of riding. Maybe a Shadow+ or Sram type2 would help....
  19. #244
    Reputation: gomer hardtale's Avatar
    new baby
    the new bike on it's maiden voyage. pretty sweet
    Attached Thumbnails Attached Thumbnails The ASR 5 build/picture thread-img_1072.jpg
    bikeporn is protected speech
  20. #245
    Dec 2011
    Quote Originally Posted by max_lombardy View Post
    Yes, not rocks. It happens while in the small ring. I have a spacer on the drive side of bottom bracket so can't move it out anymore. Just have to keep protective tape on it. Bikes worth it though.
  21. #246
    My much loved ASR5a
    DSC00896 by ruscle1, on Flickr" width="549">
    DSC00887 by ruscle1, on Flickr" width="549">
    DSC00894 by ruscle1, on Flickr" width="549">
    DSC00885 by ruscle1, on Flickr" width="549">
    DSC00892 by ruscle1, on Flickr" width="549">
    Full Spec:
    * Frame Size: Medium ASR5a
    * Fork: BOS Deville 140
    * Shock: Bos Vip'R
    * Brakes: Hope Tech EVO V2's with 183mm rotors
    * Cranks: Middleburn Duo X-Type
    * Shifters: Sram XX
    * Front Derailleur: Sram XX
    * Rear Derailleur: Sram XX
    * Pedals: Point1 Podium's
    * Stem: Easton Haven 55mm
    * Handlebar: Easton Havoc carbon
    * Seatpost: Rock shox Reverb
    * Saddle:Gilles Berthoud Galibier
    * Bottom Bracket: Hope Ceramic
    * Cassette: Sram X0, 11-36
    * Headset: Chris King
    * Grips: ESI Chunky foam
    * Spokes: Sapim CX-Ray
    * Front Tire: Continental UST Rubber Queen 2.2
    * Front Rim: Light-bicycle wider carbon
    * Front Hub/Skewer: Chris King ISO 20mm
    * Rear Tire: Continental UST Rubber Queen 2.2
    * Rear Rim: Light-bicycle wider carbon
    * Rear Hub/Skewer: Chris King ISO 12x142
    * Weight: Not sure, probably close to 27LB
  22. #247
    Jan 2011
    Here is my first ASR5:
    <a href="http://s283.photobucket.com/user/edwardgurhy/media/YetiASR5_zps4eeed560.jpg.html" target="_blank"><img src="http://i283.photobucket.com/albums/kk318/edwardgurhy/YetiASR5_zps4eeed560.jpg" border="0" alt=" photo YetiASR5_zps4eeed560.jpg"/></a>
    Here is my second ASR5, doing a spot of riding in Les Arc:
    <a href="http://s283.photobucket.com/user/edwardgurhy/media/IMG_0669_zps41205764.jpg.html" target="_blank"><img src="http://i283.photobucket.com/albums/kk318/edwardgurhy/IMG_0669_zps41205764.jpg" border="0" alt=" photo IMG_0669_zps41205764.jpg"/></a>
    ...and back home after a bit of a clean and refresh:
    <a href="http://s283.photobucket.com/user/edwardgurhy/media/IMG_0958_zpsedfa9467.jpg.html" target="_blank"><img src="http://i283.photobucket.com/albums/kk318/edwardgurhy/IMG_0958_zpsedfa9467.jpg" border="0" alt=" photo IMG_0958_zpsedfa9467.jpg"/></a>
    .... and here is the current one:
    <a href="http://s283.photobucket.com/user/edwardgurhy/media/IMG_0316_zps50d3eb4c.jpg.html" target="_blank"><img src="http://i283.photobucket.com/albums/kk318/edwardgurhy/IMG_0316_zps50d3eb4c.jpg" border="0" alt=" photo IMG_0316_zps50d3eb4c.jpg"/></a>
    All different builds - but some parts have migrated from one bike to another. Each done lots of miles and the current one is in bits waiting for some suspension bushes to arrive. Now has a dropper seatpost on which is great fun....
  23. #248
    Reputation: smithcreek's Avatar
    Nov 2012
    Took her out for a first ride yesterday and I'm very happy. Guess I can now officially say I"m glad I joined the tribe. So much more nimble than my last bike for the slow, techy, twisty, rocks and roots sections we have in New England. Tight up and downhill turns are a breeze compared to what I was used to. The only thing I need to get used to is getting the front up. My last bike was too easy, and I don't mean in a good way, so that's just what I'm used to. I'll need to change my technique, put a bit more oomph into it. I had been thinking of going back to a hardtail but this bike should be perfect for what I need. The rear end is very firm, easy to pedal, but takes away a lot of the big hits.
    The bike is mainly X0, Cane Creek Headset, Easton Haven stem, American Classic wheels. Fork is a Fox Talas 110-140 which is great to have on the techy sections. In fact most of my riding is on the 110 setting and the rear suspension on this bike is nice and firm so pedal strikes were no issue, and on our trails that's important. The Ritchey bars and Shimano pedals are about the only thing that will be changed once I figure out what I want.
    The ASR 5 build/picture thread-dsc01090.jpg
  24. #249
    Reputation: KevinGT's Avatar
    Dec 2012
    Love those less-than-common colors. The slate gray ano, blue, and orange look fantastic!
  25. #250
    Dang Ruscle that's a crazy build! Very non-traditional!!! Cool
