Anyone running scwalbe hans dampfe on a sb66
Fancy using these on my upcoming build but people have said the 2.3 width is more like a 2.5.....so wondering if there might be a rubbing issue??
I am running them on my alloy SB66, no rubbing issues so far but then I also haven't had a "full" compression of the rear suspension yet, which is where most people seemed to experience rubbing. I have put some protective tape on the seat tube just in case though.
they may rub at full bottom out, but some Biketape will sort that out. It is just annoying, not dangerous.
After I changed to Vivid Air, I had no more rub issues, as well as the rear felt mor controlled and plush..
Hans Dampf are really good tires, and I will recommend them.
- You may not post replies
- You may not edit your posts
Forum Rules
