    Reputation: Streetdoctor's Avatar
    Oct 2011
    Anyone blown out the rear shock on their SB95?
    I've been riding rigid/hardtail the last few months. Rode my SB95c today and can't tell the difference between climb and descend. Even in the parking lot they both feel the same. I don't remember it being that wayÖ.
    Front Range, Colorado
    Chilling out
    Reputation: bear's Avatar
    The '12 Fox RP23 that came on my 95a failed twice. Fox was great about warranty support but it was a PITA.
    Both times it felt like the top-out was bad, like there was no damping in the last 5-10mm of the stroke.
    If there's no difference in feeling between C and D on your bike I'd contact Fox about it. I did both of mine through their online/web-RMA-request.
    After the second trip it was noticeably better than stock, almost like it was custom tuned for me.
    Not as good as the Cane Creek DBAir I put on while the RP23 was away the second time, but really nice.
    Oct 2011
    Quote Originally Posted by bear View Post
    travel is smooth throughout the range, I just can't see or feel a difference from C -D
    Dec 2013
    Quote Originally Posted by Streetdoctor View Post
    I'm assuming you've checked air pressure first, rule of thumb I heard was 20psi over your geared up riding weight. For me this is a problem because after about 20 miles of riding I'll loose 10-15psi, but once my shock gets down to 225psi It'll hold for days, just doesn't like holding 240psi. Reason I mention is there is a significant difference between C T & D when properly aired up for my weight, but the less PSI the less the difference between the positions.
  1. Is my shock blown?
    By skim500 in forum Tooltime
    Last Post: 03-09-2012, 09:13 PM
  2. Blown shock on stumpy comp
    By bushwacker72 in forum Specialized
    Last Post: 01-07-2012, 10:16 PM
  3. Blown Rp2 rebound chamber, PUSH or new shock?
    By Cata1yst in forum Shocks and Suspension
    Last Post: 09-15-2011, 08:58 PM
  4. Is my 2009 Epic's shock seal blown?
    By bwalton in forum Specialized
    Last Post: 07-24-2011, 09:37 PM
  5. Is my 2009 Epic's shock seal blown?
    By bwalton in forum Shocks and Suspension
    Last Post: 07-19-2011, 07:32 AM
