Results 1 to 12 of 12
    Reputation: bpnic's Avatar
    Aug 2005
    Any CC DB air cans on Asr5's out there? (Not Sb's)
    Just thinking it over and was looking for some input for an aggressive Asr5 build. (Google didn't return much info, nor did CC's site, "didn't recommend spring rate?)
    I'd hit it, but I bruise like a peach.
    Reputation: drbelleville's Avatar
    I know you posted this over thee weekend, yet did you ask CC if they know of anything? Its a good question as the wife has an ASR-5 and its RP23 may "need" replacing
    Aug 2005
    I fired off an email, but I'm sure they are home enjoying some much needed R&R. Maybe tomorrow I'll give them a ring, but in the meantime, I'd love to read/see how the rear of an Asr5 behaves with one.
    Reputation: nybike1971's Avatar
    What size shock does the ASR5 use?
    Aug 2005
    Re: Any CC DB air cans on Asr5's out there? (Not Sb's)
    Quote Originally Posted by nybike1971 View Post
    It's a 7.875"x2"(50mm), but I'd throw on a 2.25" (57mm)and bump travel from127mm to 140 if I had to.
    Sent from my KFHD8.9 using Tapatalk 2
    Aug 2005
    Plz tell me you have one for sale!
    Sent from my KFJWI using Tapatalk 2
    Ka-coo-ka-cha!
    Reputation: snigs's Avatar
    Feb 2010
    Quote Originally Posted by bpnic View Post
    This is not advisable, since the clearance of the tire to the seat tube could be affected. The 5 was designed around 127mm of travel, and I would expect that to be the limit before things start hitting each other.
    Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
    Aug 2005
    Quote Originally Posted by snigs View Post
    I measured before posting, and it shouldn't rub anymore than my Sb66 did.
    Also, on a side note: I just noticed, the Fox can spec'd on my Asr5's will support a 57mm stroke, but obviously is internally limited to 50mm.
    No but I happen to have a 7.875x2.25 CCDB Air shock on the Chilcotin that you could borrow to try out if you want to.
    Aug 2005
    You've the man!
    Bumping an old thread- did the ccdb air clear the frame? I'm considering the new ccdb inline for my asr5, and really want it to work!
    Reputation: Ismaka's Avatar
    Nice thread! I only saw one asr5 with Monarch Plus, what happened with cc db air?
  1. CCDBA's Big Cans
    By woodyak in forum Knolly
    Last Post: 11-06-2012, 02:00 PM
  2. Replies: 29
    Last Post: 08-31-2012, 03:29 PM
  3. Long Trail Ale, now available in cans!
    By golfduke in forum Beer Forum
    Last Post: 07-09-2012, 03:26 PM
  4. When Are The White SB's Shipping?
    By mcgraw67 in forum Yeti
    Last Post: 12-05-2011, 12:27 PM
  5. Cans or bottles!
    By jimbowho in forum Beer Forum
    Last Post: 01-05-2011, 08:36 PM
