Results 1 to 6 of 6
    Feb 2010
    angleset for asr7
    is there an angleset that fits the 2011 ASR 7, and if there which one is it please?
    Ride and Smile
    Reputation: axolotl's Avatar
    There is and I've got one if you want it?
    Feb 2010
    and which one is it please?
    Reputation: nybike1971's Avatar
    Doesn't the ASR-7 use an external top cup headset (EC34 in Cane Creek speak)? The minimum size headtube top cup for an Angleset is 44mm, if I remember correctly so I think you are out of luck.
    There are other angle headset manufacturers that make cups that will fit your frame, Works Components is an example and MTBR user SaarG7 machined some as well (look his thread up in the Turner forum). Works Components does not have the angle headset EC34/ZS49 or EC49 as a standard option, but I bet they can pull together what you need if you talk to them.
    Reputation: bpnic's Avatar
    Aug 2005
    Quote Originally Posted by nybike1971 View Post
    Nyb'71 is correct.
    I'd hit it, but I bruise like a peach.
    Ride and Smile
    Thanks for the correction. Thought it was a 44 49.
    Works is a better product than the angleset as well. I bet the custom turner is better too!
  1. confused about ASR7
    By spadmike in forum Yeti
    Last Post: 07-14-2011, 11:34 AM
  2. Replies: 13
    Last Post: 04-23-2011, 12:41 AM
  3. Split between 575 or ASR7..
    By swan3609 in forum Yeti
    Last Post: 02-24-2011, 10:26 PM
  4. ASR7 verses ASX
    By mdlb21 in forum Yeti
    Last Post: 06-15-2010, 12:57 PM
  5. Asr7
    By jontyw in forum Yeti
    Last Post: 02-05-2010, 03:13 PM
