Results 1 to 3 of 3
    Reputation: TRAIL CRANKER's Avatar
    575 Front Shock Eye???
    Hey ,does anybody know if the front shock eye has any rotation as it cycles thru a bump, ?? I am taking a guess to be no because there is no bearings on the 08 575 front eye shock,,just the fox top hats and the M6 bolt ,,Du bushings don't move , so my question would be if no to above there would be no performance improvement by installing needle bearing ??? Anybody confirm hypothesis??Thanks
    13 On One Fatty
    08 YETI 575 BLK. C.King Hubs/Hadley
    96 Specialized Stump Jumper FS Tweaked
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    There is probably little to no movement there.... however the top hats are meant to rotate in the bushings ( not on the 575, but on other brands, both eyes have the same kind of setup as the front eye on the 575)
    Thats what i thought !! Thanks !! Crisillo
    13 On One Fatty
