Results 1 to 7 of 7
    Reputation: yeti575inCA's Avatar
    Dec 2011
    3m tape removal.
    Yeti clan - I have never dealt with 3m tape for frame protection.
    My question is can it be easily removed with out damaging or leaving residue on specifically a sb66C frame?
    thanks
    Reputation: Hokidachi's Avatar
    Feb 2012
    In case you don't have the 3M tape yet, I bought the Helicopter Tape (ISC Helicopter-OG Surface Guard Tape (8 mil Outdoor Grade): 4 in. x 12 ft.) and it works great.
    It's pretty easy to remove it and leaves no residue. Only "issue" is that it gives a glossy finish to my matte SB66C frame...
    - Hoki
    Oct 2010
    For matte finishes, check out the stuff at frameskins.com. It's pricey for their complete kits, but you can buy smaller patches to just hit the cable rub spots.
    Dec 2011
    thanks guys
    Reputation: joel63's Avatar
    May 2012
    The 3M tape comes of easily with a heat gun, if the temp is just right the glue pulls with it. Can't speak for the helicopter tape, as I've never used it.
    Word of caution with the heat gun, if you haven't used one before you must be careful as you could easily damage the finish with too much heat ! Once you get it started on one end you work the heat gun ahead of the Pull, also it comes off easier and cleaner if you pull at a sharper angle.
    Dec 2011
    how about a hair dryer...does that have enough heat?
    Good job!
    Quote Originally Posted by yeti575inCA View Post
    More than enough heat. You probably won't have to use it on the hot setting. I doubt you will need the dryer regardless if the tape hasn't been on there more than 6 months an md baked in the sun constantly. The stuff I have removed peeled off in perfect sheets glue in tact
  1. Gorilla tape OVER Roval tape?
    By freeriderB in forum Wheels and Tires
    Last Post: 03-19-2013, 05:54 AM
  2. Tubless rim sticky tape removal
    By randomroot in forum Wheels and Tires
    Last Post: 06-25-2012, 09:31 PM
  3. Stans Tape. Tubeless tape. Info needed.
    By MasterOMayhem in forum Wheels and Tires
    Last Post: 03-01-2012, 12:55 PM
  4. removal of old tape & residue
    By freeriderB in forum Downhill - Freeride
    Last Post: 11-27-2011, 08:53 PM
  5. Gorilla Tape in place of rim tape?
    By dexetr30 in forum General Discussion
    Last Post: 05-01-2011, 10:41 AM
