Results 1 to 12 of 12
    Sep 2016
    2016 6c (boost) rear rotor to frame clearance problem
    Hi guys, I got a problem of my boost 2016 6c rear rotor to frame clearance problem. I bought a hope 180mm float rotor, after I installed I found that the rotor was very very close to the frame and it almost touch the frame. Did any one are using same rotor on 6c and is it normal?
    Here is the photo, Thank you!
    從我的iPhone使用Tapatalk 發送
    Reputation: Silentnight's Avatar
    Oct 2015
    deleted
    16' Yeti SB5c
    11' Yeti ASR5c
    Are those rotors directional? I.e. Does it have outside/inside markings? If not, try flipping it around. It seems that that rotor's mounting flange is quite thick
    Reputation: Dogboy's Avatar
    Quote Originally Posted by Silentnight View Post
    Check the dish of your wheel. Looks like that could be the issue.
    Dish would have no effect on rotor/frame clearance. Looks like a particularly thick carrier on the rotor to me.
    Oct 2015
    Quote Originally Posted by Dogboy View Post
    Good to know thanks. I figured if the hub was too far non-drive side then it'd push the rotor closer to the frame but thinking about it the distance from the mounting point on the hub doesn't move haha. Thank. :-)
    16' Yeti SB5c
    11' Yeti ASR5c
    Sep 2016
    Exactly, I am sure the rotor was installed correctly and I have tried another new hope float rotor, it shows no difference. I am thinking if hope float rotor is not compatible to 6c frame. It is weird. I don't have this problem on my sworks stump jumper.
    Dec 2008
    I have a an 06 6c w a 180mm hope rotor and no clearance issues. What hub are you running? Perhaps the rotor mounting surface sits further outboard than on other hubs?
    Quote Originally Posted by Ryanwww View Post
    Sep 2016
    Quote Originally Posted by tdc_worm View Post
    I am running industry nine enduro hub and i have checked the rims to frame clearance on both size, it's the same. However, I don't know the mounting surface of the hub is further outboard than other hub or not, coz I don't have other hub to fit.
    Jun 2015
    I have the I9 enduro wheels and a set of hope hub'ed wheels currently on the bike. I don't have Hope rotors but can check with the sram ones this WE. and let you know if I see a problem.
    Sep 2016
    Quote Originally Posted by Sluker View Post
    Thank you so much !
    Jun 2015
    Got a 180mm Hope floating rotor too. No issues..
    Jun 2015
    Thank you so much !
    So here is my boost SB6c with the i9 boost hub and shimano ice tech rotor. Looks tight but clears without problem.
    Not sure what the conclusion is but I think the culprit is the hope rotor.
    2016 6c (boost) rear rotor to frame clearance problem-20160911_154625_001.jpg
  1. Replies: 5
    Last Post: 01-18-2016, 11:35 AM
  2. 2016 honzo frame with non-boost fork?
    By mlk3454 in forum Kona
    Last Post: 08-13-2015, 08:20 AM
  3. Rotor clearance after regreasing rear hub
    By jtrux in forum Wheels and Tires
    Last Post: 07-19-2013, 09:41 AM
  4. 2013 trek remedy 7,8 rear rotor clearance
    By itstreky in forum All Mountain
    Last Post: 03-21-2013, 11:09 PM
  5. V10 Carbon Rear Rotor Clearance Issue
    By gazza81au in forum Santa Cruz
    Last Post: 12-26-2011, 08:13 AM
