Results 1 to 6 of 6
    Reputation: PanFry's Avatar
    Nov 2007
    2013 SB-95AL w/RS Monarch Plus RC3
    Hello All,
    I am very interested in using the Rock Shox Monarch Plus RC3 on my new build, as I believe it would be a very complimentary pairing to the 140mm. RS PIKE that I am going to run up front... That said, I know the FOX rear the Frame comes with was tuned specifically for it. Does anyone have any set-up/tuning thoughts on the Monarch.
    Would be greatly appreciated
    Many Thanks,
    PF
    EXCUSES ARE THE NAILS IN THE COFFIN OF FAILURE.
    Reputation: Colin+M's Avatar
    I just, as in Friday, put a new Monarch Plus on my SB95c. I haven't had a chance to trail test it yet, but it seems to hold up in travel more so than the stock Fox which is what I wanted. I felt the Fox was a tad spiky and blew thru travel a little to easily. Of course I am Clydeworthy so that might make a difference. For what it's worth they both seem to pedal the same on tarmac in terms of shock movement, which is essentially none. The Monarch is in full open position as well.
    In other words, do it I have a Pike on mine as well and they suspension feel is very similar front and back now.
    Nov 2007
    Right on Fella! MUCH appreciated. I'm a bit of a Clyde myself @ 6'5" 220, so your perspective def helps. My build is about another 5-6 weeks out
    (waiting on my ENVE/I-9's..), but I'd love to hear more as you continue trail test it.
    Big Thanks,
    PF
    Also, any initial set up tips?
    Reputation: bpnic's Avatar
    Aug 2005
    Re: 2013 SB-95AL w/RS Monarch Plus RC3
    What travel setting are you guys running your pikes at? 140 or 150mm?
    Sent from my KFJWI using Tapatalk 2
    I'd hit it, but I bruise like a peach.
    Nov 2007
    140mm. on mine
    150mm on mine and use every last mm
  1. What Rock Shox Monarch RT3 for a 2013 Anthem X29
    By Ranger Pride in forum Giant
    Last Post: 06-02-2013, 03:02 PM
  2. 2013 Monarch RL with AUTOSAG question
    By jammin in forum Shocks and Suspension
    Last Post: 05-23-2013, 06:29 PM
  3. Rockshoc Monarch RT3 2013 tune on a Tallboy LTc
    By leszazas in forum Santa Cruz
    Last Post: 03-28-2013, 01:38 PM
  4. 2013 Anthem X Advanced, SID RL and Monarch RL Questions
    By 0sparky0 in forum Shocks and Suspension
    Last Post: 03-28-2013, 12:29 PM
  5. Monarch RT3 IFP differences 2010, 2011-2012, 2013
    By dimitrin in forum Shocks and Suspension
    Last Post: 01-22-2013, 10:23 PM
