Results 1 to 44 of 44
    Big Hittin'
    Reputation: nokfir2's Avatar
    Oct 2010
    2011 ASR 5 vs 575 vs SB66
    so im in the market for a new bike and recently became a fan of yeti after demo'ing a SB66.
    i recently moved and my local trails consist of a long fire rd climbs, followed by long fast descents over mixed rough terrain. coming from a dh riding background i ride pretty hard downhill but my heavy built 36lb enduro evo is not very efficient on the long fire rd climbs.
    Long story short im interested in either the yeti 2011 575 or the ASR 5. after reading a bunch and talking to people the new 575 seems pretty capable on the downhill and will still peddle up pretty efficiently (for a am bike). on the other hand the ASR 5 would be the better climber for the fire roads but how much dh ability am i loosing?
    Im stuck between the two. i find descending way more fun but i need a bike i can take for a 3hr ride im climbing and descending. does anyone have fire rd climbing time on a new 575? how does she do?
    or in short, how capable is the ASR 5 when descending?
    what do you think? Thanks.
    29er's are Goofy
    Reputation: Andrew8404's Avatar
    Just got a 2011 575 and love it to death! She's climbs just as good as the SB66 as long as you have it in pro pedal. The SB you don't even need propedal! I'd go with the 575 especially if you have a downhill background. Trust me she climbs fine!
    Big Hittin'
    Oct 2010
    What time of climbing are you doing with your 575?
    29er's are Goofy
    I do a little bit of everything. Fire roads to some technical climbing. I even used the bike on a 13 mile road ride and it worked like a champ. It climbs better then my Specialized XC bike.
    Big Hittin'
    Oct 2010
    awesome good to here. did you custom build or buy it with one of the kits?
    what does it weigh in at?
    29er's are Goofy
    I got it at Huck N Roll the enduro model for 2150. It was a great deal. I know there are a few places online still selling the 2011 model but sure if there doing any discounts like Huck N Roll had. I added a reverb and couldn't be any happier with it. It probably weights around 30 if I had to guess. You could get down to 27 if you went all out.
    Reputation: Boxer's Avatar
    Mar 2005
    I think you will be very happy with the 575. I was able to demo a 575 and a asr5 and both climb pretty well but the asr5 climbs better and is more comfortable while climbing for extended periods of time. The bigger difference is when you downhill the 575 is much more capable to handle jumps, drops and high speeds. On the asr5 I was pushing it and it is very fun and has a higher flikability while feeling in control. When you ride the 575 it takes all that to a higher level and increases the smile factor while adding to the stability and feels like your glued to the terrain. I felt the asrc5 was very good on the downhill BUT the 575 was great and still would allow one to grow with it.
    My rides vary from 2-4 hrs and are more then 50% climbing. I also do 12hr races. So I chose the ASR5-C and really love it. For me it was the better choice for the type if riding I do and what I want my bike to do. The 575 for me would have been more fun on the downhills but harder on me on the climbs. They are close but if your looking for a better downhilling ride than the 575 is the better way to go.
    Pedal Dammit!
    Reputation: cwkrause's Avatar
    The 575 sounds like the better bike for you.
    I had a ASR5C (with a 120 fork) and still have a '11 575. I sold the ASR5C and picked up a Big Top to replace it. I sold the ASR5 b/c I kept crashing on it. This was because I could get going as fast as I could on my 575, but there was no room for error with the firm 5" of travel. On the 575 I never have that problem b/c it just soaks everything up and I can descend with more confidence and speed. So I got a Big Top for my longer XC rides; now there is no mistaking which bike I'm on.
    I found the ASR5 to be much more of an XC bike than the 575; therefore it pedals better and is faster on the climbs and flats. If you want to get to the top fast or log lots of miles the ASR5 is sweet. If you take a little more time on the climbs and want to rail the downhill the 575 is so much better for that.
    I've been winning some local enduro races on my 575 and beating guys on bigger travel bikes. It's a great enduro bike! I run a blackspire stinger chain guide and a reverb which has made the bike super fun. I'm also considering putting a 160mm 36 on it and seeing how it does.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    3 hr rides climbing and bombing are great on a 575, can't speak to the 5 but sure it climbs a little firmer.
    One thing to note, if you like any type of technical climbing the 575 really loves that stuff.
    Sounds like with a d/h background a 575 would make you happier. Mine is around 30lbs with a 160mm coil Lyrik and make no mistake, it's not as point and shoot as a 36lb bike, but it does really really well on everything I can through at it.
    Dec 2011
    Quote Originally Posted by Andrew8404 View Post
    Awesome to hear you like your bike. I ordered the same model from hucknroll last week and happily it will arrive just in time for christmas (friday). My predicted date was the 28th. It got into build a few days earlier and they also upgrade me to 2nd day air. Great guys at hucknroll! I'm looking forward to taking it out. What pedals did you end up putting on it?
    2011 Yeti 575 Enduro - full XT group, Thomson cockpit, and Chris King upgrade
    Quote Originally Posted by MD_TX View Post
    It's a great bike you will love it! Im just starting to get comfortable with her. My only gripe so far would be the Elixir 5's which are a little noisy and the pedals strikes due to the low bracket. Otherwise I couldn't ask for a better bike! Huck N Roll also treated me really well so they will always have a customer in me. I put on my old clipless pedals which are the Shimano SLX 530. There not bad and give just enough cushion just in case I don't feel comfortable clipping in.
    Reputation: ridetheridge's Avatar
    I've never ridden an ASR 5, but have a 2009 575 and do a lot of climbing and descending where I live. Very long climbs (fireroad or technical) coupled with long technical descents. The 575 handles all of it with ease. It's a fairly light bike and you can stiffen it a bit using propedal on the fireroads, if necessary. I've also found that using high volume tires really add to the plushness on the technical descents.
    Question to the OP... you mentioned you became a Yet fan after demoing the SB66. With all the hype over this bike, why isn't the SB66 a candidate ? Too heavy, too stiff, too expensive, too hard to get ? Just curious
    Reputation: GreenBonty's Avatar
    As said by others, the 5 is better going up and the 575 going down. In my short demo they were not close but rather the first much better climber (including techincal climbing) where the 575 way better descender, in the air and on landing. The 5 is an XC bike on drugs where the 2011 575 a much heavier and stable AM bike.
    Big Hittin'
    Oct 2010
    Quote Originally Posted by ridetheridge View Post
    Just price.
    29er's are Goofy
    Big Hittin'
    Oct 2010
    holy sh*t anyone see today? they put on 2 white M 575 enduros for 2159.....score!
    that made my decision!
    New Yeti 575 owner! however they are so backed up with the holiday orders they sayed it prob wont ship until after new years...oh well
    29er's are Goofy
    Quote Originally Posted by nokfir2 View Post
    Awesome man congrats! You will love the bike! It should come with kashima fork and shock also.
    Big Hittin'
    Oct 2010
    thanks man.
    it was weird, i checked out hucknroll before but they only had XS size...today 1 M in white popped up (the exact size and color i wanted)....i had to react. i did get the enduro kit which i know has some bottom end components but at 2150 its a steal i think.
    i usually wouldn't buy a bike online, after i saw it i immediately went to the lbs the guy was in shock when i asked if he could price match. he actually told me to go home and buy it now, cool guy.
    29er's are Goofy
    thanks man.
    it was weird, i checked out before but they only had XS size...today 1 M in white popped up (the exact size and color i wanted)....i had to react. i did get the enduro kit which i know has some bottom end components but at 2150 its a steal i think.
    Yeah, it's a killer deal no doubt and something I couldn't pass up either. The nice thing about the enduro though is you can build it up the way you like.
    Reputation: BobGolden's Avatar
    I was reading this and thinking, man, I love my 5 but if it was between my 5 or those discount 575s, I would have jumped at the 575. I was thinking it's a shame the OP missed that deal. Then walla, a x-mas miracle, Congrats!
    Big Hittin'
    Oct 2010
    me hammering the demo sb66... :-)
    just an ideal of my local trail...i cut out the 45 min climb haha
    <iframe src="http://player.vimeo.com/video/33763760?title=0&amp;byline=0&amp;portrait=0&amp;a utoplay=1" width="398" height="299" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    29er's are Goofy
    That looks like a bad ass trail.
    Big Hittin'
    Oct 2010
    so i was thinking i want to remove the big chain ring and convert it to a 2 chainring crank in the front and put on a spare Gamut bash guard i have laying around.
    can i simply remove the big ring from the cranks? or do i need to buy a new crank setup?
    29er's are Goofy
    Which gamut bash guard? I have a p20 on my 11 575 and just simply took off big ring but I needed longer chainring bolts. Gamut sells them, I picked up a set from truvativ.
    Oh yeah, congrats on the new ride! Your gonna love it.
    Big Hittin'
    Oct 2010
    the P20.....thanks.
    would my LBS have the bolts?
    29er's are Goofy
    I got them from LBS but they had to order them. I don't know the size or anything just told them the issue of stock bolts not fitting and they said these will work and sure enough it did. It was like a set of different sized ones. Pretty sure this was the kit Truvativ Bolt Kit For Rock Guard at JensonUSA.com
    Big Hittin'
    Oct 2010
    hope mine comes with Kashima coating....
    29er's are Goofy
    hak
    hak is offline
    Dec 2011
    i was looking at an XS 575 enduro package for my wife yesterday @ huck and roll... today they're gone they are moving bikes!
    Big Hittin'
    Oct 2010
    I told ya!
    they had that one XS for about a week. i was wondering when it would go. I was at the LBS trying to get them to price match it. They told me to race home, buy it, and come back if i need helping building it lol. I was so lucky to get that last M!
    sorry dude you were close....
    29er's are Goofy
    Dec 2011
    -if you just ordered it, then it should have. I believe mine has what some called the '1st gen' kashima on the fork/shock for 2011. I love the way the black color fork looks on the white bike too, nice subtle contrast.
    Dec 2011
    Quote Originally Posted by hak View Post
    They went pretty quick. I started looking around right after thanksgiving and hucknroll had about 8-9 left, I ordered on 12/15 and they had 5, right before christmas they were down to that last XS, and I think some people mentioned they added a couple bikes to inventory too. They went even faster at JensonUSA, even at a couple hundred more for the same bike. I had been debating between a GT with full-XT components (and much cheaper), and a carbon frame Rocky Mt. The GT is still available, Rocky Mt is sold out, but I'm happy with my decision though to go Yeti.
    Big Hittin'
    Oct 2010
    i def want the kashima but i cant decide if i like the white fork or black better. either way i just want this bike to get here. still a week or two out...
    29er's are Goofy
    Dec 2011
    I got the white bike, and thought the white fork looked ok with it. After getting my bike and seeing it with the black fork I think it's totally a better look since the rear triangle is black in color, balances the bike out. As for the kashima, I'm not at the level to know the difference either way, but it's cool to have I guess. Lol The guys at hucknroll are great, I actually got mine 4 days before the projected date and they upgraded me to 2nd day air.
    hak
    hak is offline
    Dec 2011
    I told ya!
    .... I was so lucky to get that last M!
    no need to be sorry, it worked out in the end (more to follow) i just rolled what i would've spent on hers into mine . As to "the last medium" the last medium enduro kit, yes. but there are a few more mediums on there.... hence - more to follow
    Mar 2005
    Nice trail. It looks like you rwere really moving through the top part. I think you have ridden that trail before. :-)
    Pedal Dammit!
    Big Hittin'
    Oct 2010
    Yea that's my home trail. It's a fun trail down a ridge, I actually cut a section out of the vid. Told ya guys I have a downhill background.
    How will the 575 compare to the SB going downhill?
    29er's are Goofy
    Big Hittin'
    Oct 2010
    i usually have the motionx gps app on my iphone going to track my rides.....according to that my fastest speed was 29.7 mph
    29er's are Goofy
    You should check out strava. It's the best phone/gps program out right now.
    Big Hittin'
    Oct 2010
    Hell yeah!
    Tracked and scheduled to arrive tommorow!!!!
    29er's are Goofy
    Dec 2011
    Hell yeah!
    -awesome! Hope you're at home to receive it, or have someone that can....UPS just left mine on the porch, rung the doorbell, and took off leaving it there.
    Is the ASR 5 ( the carbon model) as laterally rigid as the 575 (2011)? I have ridden the 575 but not the ASR...
    Reputation: bpnic's Avatar
    Aug 2005
    can anyone compare the Asr5 (140mm fork) to an Sb for overall trail riding?
    As fast? pedal feedback? climbs, descents?
    I'd hit it, but I bruise like a peach.
    Quote Originally Posted by Cincinnati Kid View Post
    The 5 is very stiff but not as much as the 2011 575 IMO. Only tested both but at the same day
    Have only a short demo on the 5 but I am sure it will not track as well as the SB on the technical sections, climbs. It will not be as fast when stability and peddaling efficiancy plays a role but on clean surfaces uphil it may be faster just because it's lighter. It will be more nimble and responsive than the SB and will be way better on tight switchbacks. It realy excell as an XC bike where the SB can take some heavier duty jobs and still be an extremly fast bike. If you drope on the bike then the 5 is less capable and sure less capable on the rough downhills.
  1. Replies: 10
    Last Post: 04-19-2012, 08:19 PM
  2. Replies: 0
    Last Post: 05-11-2011, 12:02 AM
  3. Replies: 3
    Last Post: 04-27-2011, 10:10 PM
  4. Replies: 23
    Last Post: 01-29-2011, 01:32 AM
  5. Replies: 18
    Last Post: 12-01-2010, 01:09 AM
