Results 1 to 6 of 6
    D93
    D93 is offline
    Oct 2011
    2011 575, ProPedal lever switches on it's own.
    I noticed that when my shock is in Propedal and I do a decent in-between climbs, the lever switches out of pro pedal by itself. I suppose it's a blessing because sometimes I forget to switch out of Propedal and halfway down a single track I'll reach down and it's already out.
    Is this normal?
    Jun 2010
    I dunno, but my pro pedal seems to make no difference at all.
    Is pro pedal supposed to lock the shock nearly out?
    Big Hittin'
    Reputation: nokfir2's Avatar
    Oct 2010
    mine works great. and it definetely makes it way more stiffer.
    this will probably depend on air pressure. the more air in the shock, the more propedal makes a diff. i run about 225psi cuz im about 180 all geared up
    29er's are Goofy
    Mine does that on my ASR5. Only when I'm using a lot of travel, so I assumed it's a built in safety feature. Doesn't worry me though, I often forget to switch over anyway.
    Mr. Knowitall
    Reputation: hssp's Avatar
    The PP lever is not supposed to work on its own. check if the PP dial on the lever is seated properly.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Quote Originally Posted by moneycash View Post
    No.
  1. Philippines!
    By Raybrig in forum Asia + Philippines
    Last Post: 05-08-2012, 01:22 AM
  2. 2011 HC100 + Coe Everest Challenge / fundraiser, October 1st
    By ElHombre in forum California - Norcal
    Last Post: 12-15-2011, 09:59 AM
  3. All Mountain GT Force Build
    By Prostreet513 in forum All Mountain
    Last Post: 01-23-2011, 04:55 AM
  4. RP23 ProPedal Lever position?
    By jollybeggar in forum Shocks and Suspension
    Last Post: 05-11-2009, 06:27 PM
