Results 1 to 8 of 8
    Reputation: client_9's Avatar
    2.35" IKON for SB-95 ... tire clearance?
    I'm gathering parts for an SB95 (medium aluminum)
    Has anyone successfully run a Maxxis IKON 2.35 exo as a rear tire?
    Clearance issues w/ a front derailleur?
    thanks!
    Reputation: GTscoob's Avatar
    Throwing it out there that the Ikon 2.35 is the slightest bit smaller then a 29x2.4 Ardent, like 1mm narrower across the knobs and 1mm narrower across the casing. Both tires mounted on the same rims.
    If the 2.4 Ardent fits you should be fine with the 2.35 Ikon.
    Reputation: wilbcol7's Avatar
    Oct 2011
    I am running one now on my 95c. No issues
    Quote Originally Posted by wilbcol7 View Post
    thanks.
    Homer
    Reputation: brum's Avatar
    Dec 2004
    Quote Originally Posted by client_9 View Post
    thanks.
    Doesnt the carbon have more tire clearance?
    Need optics for DIY bike lights?
    Reputation: Streetdoctor's Avatar
    Oct 2011
    I have one on my carbon also but the carbon DOES have more tire clearance than the aluminum model
    Sep 2013
    Good to know, the other day I got an IKON maXXspeed EVO eXc, 29 2.2 but it's just too narrow compared to Schwalbe RR EVO and Saguaro 2.2, would let it go for $60, brand new in original package... lemme know
    Chilling out
    Reputation: bear's Avatar
    I have it on my '95a ... no problem with rear triangle clearance, and I suspect it'll be fine with the derailleur as I didn't have problems that way with a Hans Dampf 2.35 which happens to be larger.
    BUT,
    The Ikon 2.35 *will* rub the seat tube on full compression.
    I also would not necessarily think it a good tire if you have to deal with mud much. There's not *that* much room in the chain-stays.
    None of the above stops me from rolling it though. :^)
    addendum: above tire experience based upon Stan's tubeless setup of tires on Stan's Flow rim, from '12....not the Flow Ex model. Rear tires generally run at 30psi.
  1. "rolling resistance". Maxxis Ardent vs Racing Ralph vs IKON
    By trhoppe in forum XC Racing and Training
    Last Post: 05-02-2014, 04:36 PM
  2. Replies: 20
    Last Post: 02-22-2014, 06:16 PM
  3. RM Element 26" Rear Tire Clearance
    By LowOnO2 in forum Rocky Mountain
    Last Post: 02-22-2013, 09:37 AM
  4. 26" transam tire clearance
    By ihaveagibsonsg in forum Transition Bikes
    Last Post: 01-14-2013, 03:22 AM
  5. DW-Link Rear Tire Clearance 2.2" Trail King
    By BlackOut in forum Turner
    Last Post: 12-22-2012, 11:42 PM
