Results 1 to 10 of 10
    Oct 2012
    150mm or 160mm fork on the SB66?
    Which do you prefer and why? I do a lot of big mountain up and down.
    Reputation: yeti575inCA's Avatar
    Dec 2011
    I ride 160mm slant and have no complaints
    Jun 2012
    FOX Float 34 @ 160mm with PUSH Elite conversion. No complaints!
    I run 160mm....however it does present a few problems depending on the frame size you're running. It slackens the seat angle enough to prevent me getting my saddle far enough forward. I run a large and have lots of seat post showing. If you're running a smaller frame probably not a problem. Just worth pointing out.
    I have to make do.
    Reputation: bart.taylor.sucks's Avatar
    Oct 2012
    I want to hear about the PUSH Elite setup on your 34, please.
    Mar 2006
    I ran a 150 at first and now I am trying 160. I am going back to 150. In my opinion it climbs better and over all corners and handles better at 150.
    160 gives the steering a noticeable flop and makes climbing harder to keep weight over the front. I have not noticed a increase in descending capabilities with the 160 over the 150 to offset the sloppier cornering at 160.
    I think Yeti has gone 160 up front on the new builds.
    I run a 160mm Talas. I've lowered it once I think.
    Reputation: da peach's Avatar
    Mine came with a 160mm 36 Float. It is a monster truck descender, and I am getting better at techy climbing moves all the time.
    I've never tried a 150mm for comparison.
    Oni
    Oni is offline
    Master Of Fooliganism
    Reputation: Oni's Avatar
    On my Al SB-66 I had a 1500mm float. On my 66c, I have a 160mm TALAS 34. Can't say that I've really noticed a huge difference between the two travel lengths, but I have cranked down the TALAS when I'm extended climbing or on calmer terrain.
    Oct 2012
    I went with a 150mm Pike. The Flow video review pushed me over the top. I want a balanced playful bike. I looked up the Axle to crown measurements and it looks like the Pike is slightly taller for the same travel as Fox. About 5mm. So I'm guessing the Pike will be perfect with just under a 67 head tube angle.
  1. going from 150mm to 160mm or just keeping it at 150mm??
    By alfonz212 in forum Banshee Bikes
    Last Post: 02-15-2013, 04:10 PM
  2. 27.5 Float CTD - 150mm to 160mm?
    By MudBike in forum Intense
    Last Post: 01-10-2013, 12:47 AM
  3. Yeti SB-66 150mm vs 160mm
    By eddiek118 in forum All Mountain
    Last Post: 10-19-2011, 12:30 AM
  4. 36 Fox Talas 160mm -> 150mm?
    By happyriding in forum Shocks and Suspension
    Last Post: 10-14-2011, 10:06 PM
  5. Fox 32 150mm or fox 36 160mm
    By Bowhuntmaster in forum All Mountain
    Last Post: 06-24-2011, 11:33 AM
