Results 1 to 43 of 43
    Reputation: Porschefan's Avatar
    Jan 2011
    142 x 12 Shimano QR through-axle availability?
    Newb here.... trying to get ducks in a row for a wheelset upgrade for a 2010 ASR 5.
    I'm considering getting the chipset to convert to 12x142mm through-axle as part of this "upgrade"--probably don't really need it, but it's a "while I'm at it" kind of thing....
    Checked with Yeti and they have the chipset available--although I can't find it on the website (??). Yeti also said the ONLY chipset they have and support is requires the Shimano axle. (No more support for the DT Swiss axle.)
    Shimano part #: ISMAX75A. This seems to be in super-short supply. I found only one website that says it is in stock and it's a) in Austrailia b) costs about 2x more than it should--not even considering shipping.
    I called Shimano USA and they say it's not available and have no info on when/if it will be. Apparently you can't get one even if you buy the Shimano XTR rear hub that uses it.
    Searching reveals that this situation (out of stock) is at least a couple of months old at this point. The only relevant data I've found is that one website estimates delivery within "7-8 weeks".
    This isn't an urgent situation, and I probably could live quite happily with a standard 10x135 QR axle, but I'd like to have this option open.
    Does anyone have a source for these and/or any info on what's going on?
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you'll crash. ~Julie Furtado
    Reputation: woodyak's Avatar
    Completive Cycles claims they'll have some on Monday. We'll see. I'm kind of annoyed as I spent the cash for the chip kit and the hub adaptor and now it appears Yeti only supports an axle that is vapor-ware.
    Jan 2011
    Quote Originally Posted by woodyak View Post
    I was following your thread and that's one of the reasons I called Yeti to clarify whether there were actually two flavors available, or that they had just switched to the Shimano design. I would think your Yeti dealer would exchange for the "proper" set? Especially since J.P. offered to give them a call and set them straight on this point.
    I discussed my wheelset plans with the LBS/Yeti dealer, and was assured that they wouldn't have any problem coming up with the axle, but I didn't go into great detail with them.
    As far as the axle being vaporware...I hope not! And I suspect that it's highly unlikely since Shimano sells hubs and wheelsets that use them. In theory, the fact that Shimano advertises and sells $1,500 XTR wheelsets that use the XTR rear hub and this axle, might be the reason that everyone else is short---who knows?
    If you hear from Competitive, please follow up here. I may order one just to have it just in case!
    P.S. Did Competitive give you a price?
    I have the Shimano kit and axle...I'm just waiting on the King conversion kit - it's pretty slow coming out too. I'm in Canada and got my axle through a local shop...but you might try Calgary Cycle - I believe they were the supplier for my shop - think they're the main distributor in Canada.
    Jan 2011
    The plot thickens....
    I got excited and gave Competitive Cyclist a call. They were just closing up but the guy I spoke with said he that he didn't have any definitive data, but that there was some kind of hush-hush "new bike" announcement that was relevant to this axle's availability. I asked if it was related to the SB-66 but he really didn't know and/or couldn't say.
    I checked Yeti's website to see if the SB-66 used the 12 x 142 axle stock, but it looks like it's an option just like the ASR's and 575's.
    Jan 2011
    Quote Originally Posted by chunkylover53 View Post
    Thanks for the tip. I called them and they don't have any. Said that every one that they get in goes out as part of a new Yeti--they're Yeti dealers.
    3 Legged Big Top
    Is the Shimano XTR hub the only hub that will work with the shimano thru axle? I cant imagine so but If thats the case Yeti has really dropped the ball on this.
    Seems like a lot of hassle when there are other options readily available. I use the Hope Pro 2's with the bolt on kit in standard DO's and its plenty stiff. I would also consider a 10mm thru axle hub using the DT thru bolt on standard DO's. Just something to consider.
    C
    3 Legged Big Top
    Oh and if you use Hope hubs with the 10mm option now, you could easily change the axle to 12mm thru when Yeti supports a axle supplier who is prepared to deliver product.
    C
    Jan 2011
    Quote Originally Posted by Curtis C View Post
    I'm not qualified to say--I don't know. But I don't think so. I'm assuming that the Shimano through-axle will work with any hub that supports that standard.
    ....Oh and if you use Hope hubs with the 10mm option now, you could easily change the axle to 12mm thru when Yeti supports a axle supplier who is prepared to deliver product.C
    That's a good option, for sure. Again, I'm a newb and trying to wrap my wits around the whole procedure. If I understand one of the replies from my thread on getting new wheels/hubs, the ONLY advantage to getting a "native" 142mm hub is that there would be just a bit more stiffness if the hub body were wider--as opposed to have 3.5mm extensions stuck on the ends of a 135mm hub.
    One of my options, would be to pick up a good used wheelset, but I have to understand these compatibility issues before I feel confident doing that. I want to be ready to pull the trigger when I run across something that's a good deal--either new or used. Pretty focused on Mavic 819 rims with Hope 2 PRO EVO hubs right now.
    3 Legged Big Top
    You are looking at a solid wheelset. The great thing is it could be used today on your current drop outs and then easily changed to 12x142 when those parts become available. I'd bet if you used the DT 10mm thru bolt on a hope 10mm thru hub or the bolt on option you won't look back(other than to check on your buddies). The advantage of the thru bolt over bolt on is the ease of wheel removal. Not sure on your thoughts of hub noise but the Hopes do buzz when freewheeling.
    heres a link to the thru bolt
    http://www.dtswiss.com/Products/Comp...thru-bolt.aspx
    heres a link with some Hope hub info
    http://www.jensonusa.com/store/produ...Disc+Hubs.aspx
    heres an ebay link to a hope hub with 10mm bolt on
    http://cgi.ebay.com/Hope-Pro-2-Rear-...item20a23d47eb
    the beauty of the bolt on is you dont have to buy a thru bolt or axle. the bolts come with the hub. Oh and I have bought from this guy and gotten excellent service each time.
    C
    Jan 2011
    C
    Curtis,
    Thanks for the info and links. If I were to make decision today, I would definitely just get the Hopes and find a 10mm through-bolt or axle.
    One question/observation though--the link refers to Hope Pro 2 (not Pro 2 EVO). If I wanted to keep the 12 x 142 option open, I believe I read somewhere that the conversion kits for the Hope Pro 2 hubs are available ONLY for "EVO's" and not the "plain" Pro 2's?? OTOH, I suspect that you're right about not really looking back if I settled for the Hope + 10mm through-axle combo.
    As a newb, I'm always amazed by the amazing amount of "devil in the details" I run into whenever I stick my nose into something new!
    Here's a good link I found with a detailed comparison of Hope 2, Chris King, DT Swiss, i-9, True Precision and Hadley hubs. The Hope 2's seem to be the best overall bang for the buck. I also found a bunch of Youtube videos with the SOUNDS of all these. They are all kind of noisy in a weird/good kind of way.
    http://www.dropmachine.com/Reviews/h...hope-a581.html
    Quote Originally Posted by Porschefan View Post
    The adapter for my I9 hub goes through the entire hub body which is pretty slick. It wasn't cheap though.
    Hope's are solid hubs. I have a set on one of my bikes. The only problem I have with them is that it has a small amount of engagement points (24?) compared to some of the higher end hubs. It can be quite noticeable when doing technical climbs and any time you are trying to ratchet up something.
    3 Legged Big Top
    Mine are Pro 2's and they were built prior to release of EVO. I would build on EVO for just a little more money now that they are available. The axle options were all available when I was researching my Pro 2's. Doesn't mean they wont stop producing them for the older hub though. The hubs pretty much look the same, makes me wonder if the larger axle and SS bearing of the EVO can be used in the standard pro 2.
    The CK, I9 hubs do engage faster than Hope but they were a good amount out of my budget. I came from XT hubs to the Hopes and the drivetrain engagement was a great deal faster on Hopes. If you want I9 engagement on a budget you could get a rear hub from http://www.project321.com/products_bike-rear-hub.php but you wont be able to match the frt since he only builds lefty frt hubs.
    C
    Jan 2011
    More info on Hope w/ 142 x 12
    Found this here:
    http://www.hopetech.com/page.aspx?itemID=SPG241 (last paragraph)
    The following types are available and can be interchanged with additional spacers/axles which are available separately: - Front QR - Front 9mm - Front 20mm - Front 15mm - Front Maverick fork - Rear QR - Rear 10mm Saint - Rear 12mm (135) - Rear 10mm Bolt in (135) - Syntace X12 142mm - The rear hub is also available in 12mm/150mm wide (note this is a new hub. Not a conversion) and also a trials / singlespeed (see separate page)
    Yeti says their chipset is built to the SHIMANO 12x142mm standard. I believe that the DT Swiss version, that Yeti no longer sells/supports is the SYNTACE design/standard. I take this to mean that 12x142 is not an option with for Hope Pro 2 EVO's + Yeti ASR5??
    3 Legged Big Top
    I believe any hub that can be converted to 12x142 thru will work with either axle(shimano or syntace). The Hope hubs can be converted to 12x142 or bought with that design.
    The difference between shimano and syntace axles is how they attach to the frame and clamp down to lock in the rear wheel. Yeti no longer builds the chip set to support the syntace design but that does not affect the hub.
    heres a link to syntace
    http://www.syntace.com/index.cfm?pid=1&pk=1314
    scroll down and you can see the Shimano XTR hub with 12x142 thru is compatible with syntace axle and the flanges on the other hub builders look very similar
    There are more hub builders than there are axle designs. The hub builders have pretty much made their hubs compatible with all axles designs
    Hope I haven't confused the matter more
    C
    Jan 2011
    C
    Thanks for the clarification. Makes sense: any kind of hub that supports 142 x 12 + Shimano through-axle should work.
    Porschefan - I was able to order an axle online after searching a bit, but lots of suppliers say the axle is included with the XTR hub, for example:
    http://www.universalcycles.com/shopp...1&category=740
    my understanding of all this is that the new yeti chipset needs the shimano axle, but this axle will work with any 142 x 12 hub.
    You may not need the stiffness increase, but it really is easier to remove/replace the wheel with the thru axle. Just don't lose the axle! Also, if you want to use these hubs for a few years, having the 142 x 12 setup may make it easier to carry over the hubs to a new frame a few years from now. Good luck.
    Jan 2011
    Have you tried to purchase one from Yeti itself? I was told today by a respected vendor that:
    "....apparently Yeti bought all of them from Shimano and are a little reluctant to sell them since they are few and far between."
    I have written to Yeti to see if they might be purchased directly--along with a chipset.
    Funny, the Canadian bike shop (Calgary Cycle) also mentioned that every one of the axles they got (from Yeti???) went out as part of a new bike.
    I don't know if this is even true--that Yeti has "cornered the market" so to speak, but if so it is kind of annoying, even if understandable. If the mfgr (Shimano) doesn't have an adequate supply I can see Yeti wanting to have enough on hand to configure new bikes that way.
    Does your local shop have any more?
    Quote Originally Posted by catfishWRC View Post
    I think that's basically it--which implies that the chipset must have a carrier of some sort that accepts this, and only this, through-axle. I've never actually seen it in person.
    I guess between Yeti's possible purchase of a lot of stock and Shimano's own requirements to supply axles WITH the hubs, we have a reason for the short supply. Did you buy your wheelset from someone online? The only XTR-hubbed wheelsets I've found have been Shimano's own--and they're around $1,100.00, which is getting into silly territory for me.
    The ease of removal really appeals and if/when I go this route
    The last e-mail I got from Competitive Cyclist was to go ahead and order one off their site. I was told that 5 more were coming in next week and one of them has my name on it. I'd place an order if I were you and follow up with an e-mail.
    I got my wheels online, custom built from prowheelbuilder.com, but again, an axle didn't come with mine. Universal cycles will build them for you too. I wouldn't get the XTR trail wheelset - my wheels are lighter, have more spokes (and the spokes aren't hard to find, propietary straight-pull spokes), mine are probably better built and cost $200 less. I also got to pick my nipple and spoke color. You could save even more money by getting an XT front hub, the weight difference is tiny.
    I can take a picture of the chipset/thru axle system later. But basically, yes, the new chipset has a little set screw which holds the threaded nut part that comes with the axle in place. It works about the same as the thru axle on your fork.
    Jan 2011
    Update: ordered the chipset and Shimano axle from LBS--new questions
    I called my local Yeti dealer and was assured that if I placed an order with them I would get the chipset AND the Shimano 12mm through-axle in about a week. $50 for the chipset, which has always been the price AFAIK and $70 (!!) for the axle. In old ads this axle was < $50, but I guess the point becomes moot when it's only available from one source. I just decided to pull the trigger and at least have these parts ready when the right wheelset becomes available.
    I have a couple more questions about how to proceed now.
    1. Is it possible to adapt the current Crossride rear end to accept the new chipset and axle combo? I'm thinking probably not, but want to make sure.
    I've seen that Shimano X-7 142x12mm hubs are available for ~$140.00, but disassembling/re-building the Crossride wheel and it probably makes more sense to just keep the whole Crossride setup intact and get new wheels when I'm ready.
    2. Regarding the new wheelset, what is involved as far as the brake rotors go? I have 160mm centerlock rotors on the Crossrides. When evaluating wheels and hub combos, I see that not all, maybe not the majority, of possible hubs are centerlock, but specify "standard 6-bolt" discs. Does this mean I have to either find "centerlock hubs" or get new discs? If I have to get new discs, what about the existing calipers and brake levers, etc.?
    3. In looking for an appropriate new wheelset, I've seen some new and some used set with Hope Pro 2 (not EVO) hubs advertised. But I ran across a website that mentioned that the non-EVO Hope Pro 2's have a history of snapping 12mm through-axles and that defect has been cured with the EVO upgrade. Anyone have any data or comment on that? It certainly makes me shy away from any used wheelsets using these older Pro 2's.
    Red Barn Bicycles (http://www.redbarnbicycles.com/wheels.html) said they can do 819's with Hope Pro 2 EVO's for ~$575 + shipping. That sounds like it's about the best I will do for this combo new and put together by a competent wheelbuilder.
    I guess this thread has veered off a bit and I'm back on to "How do I replace/upgrade" the wheels again. TIA for any pointers.
    There's no room in the crossrides for the bigger axle, and I don't think it's worth taking them apart and rebuilding them at all.
    You could buy shimano six bolt rotors, buy center lock compatible hubs or buy six bolt to center lock adapters (my cross rides actually had adapters on them), so almost any hub can be made to work. Good rotors are ~ $50 each, so the simplest, cleanest, cheapest option is to get center lock compatible
    Jan 2011
    Catfish,
    Just make sure I'm following--the HUBS determine what kind of rotor you need, right? And that's not an option with hubs--they are either one or the other?
    Reputation: KTMDirtFace's Avatar
    Im getting close to pulling the trigger on a sb 66 frame order. Should I have them try to order the 142x12 shimano axel and yeti dropout kit? I definitely want that setup. so weird that that axel is impossible to find.
    Jan 2011
    Quote Originally Posted by KTMDirtFace View Post
    This is conjecture on my part, but I think that if you order the bike spec'd with the 142x12mm rear end, it will come that way. The *probable* reason for this shortage is that Yeti needs all it can get to ship bikes ordered this way.
    Talk to your local Yeti dealer. If you're ready to buy a new SB-66, I'm pretty sure you'll get it the way you want it.
    Yes, but there are adapters out there that will let you use a center lock rotor on a six bolt hub.
    Feb 2005
    This is a good setup and Chad is a very good wheel builder. I've had several wheels built by him with no issues.
    Feb 2005
    Still out of stock at Competitive Cyclist. Where can this be had?
    Quote Originally Posted by joltz View Post
    Put one on order anyway and they'll get one for you. I ordered mine last Monday and I should have it on Wednesday.
    Jan 2011
    As mentioned above, I have the chipset + axle on order from local Yeti dealer. Should be here "within a week." I'll report back on that.
    I just ordered one from local yeti dealer, they said they are having better luck getting them now.
    no idea how long the wait is but I have to wait for the bike anyways.
    Reputation: zenboy99's Avatar
    Feb 2007
    Finally got mine through competitive cyclist yesterday. Took 6 months of shopping around and talking to Shimano rep's trying to get this axle.
    Reputation: Dogboy's Avatar
    No, there are no such adapters. There are adapters that allow you to use a 6-bolt rotor on a Centerlock hub though.
    whoops, sorry, got it backwards. You can adapt a six bolt rotor to centerlock hub. For example:
    http://www.competitivecyclist.com/pr...paign=Datafeed
    Jan 2011
    Update: chipset and axle are here
    Yeti dealer called yesterday and said they are here, so now I'll have them when I find the appropriate wheel(s).
    Ditto, yeti has the axles mine is coming with my frame..(whenever that is )
    I need to figure out wheels too, industry 9 enduro's look sweet but mega expensive. What other options have you found?
    Jan 2011
    I'm not qualified to make any recommendations, but most of what I've found out so far is in these two threads, which you may have already come across.
    What wheel´s? for Asr5-C
    and
    2010 ASR 5 alloy--info on wheelset upgrades
    The second is a thread I started asking advice on how to proceed, and there's some great advice (for me) in there.
    I've been concentrating on the Hope Pro 2 EVO hubs + Mavic XM 819 rims. I've heard nothing but great things about the 819 rims from everyone I've talked to. The other recommended rim was the Stan's Flow rims. Given the sterling reputation of the 819's and the fact that they are a UST rim, those are my first choice.
    The hubs are more complicated and given the fact that I decided to go with the Yeti chipset upgrade, I obviously have to get ones that are compatible with 142 x 12mm dropouts. The Hope Pro 2 EVO's seem to be the best value and they can be configured for 15mm QR and 142 x 12 front and rear. Other hub alternatives include Chris King, Hadley, Industry-9, but these are considerably more pricey than the Hopes. One more set that I like is the Shimano XTR M988's (the rear hub is the one that the hard-to-find axle was made for). But these too are expensive.
    I thought that I might luck out and find a good used wheelset, but not really much luck there. Besides all the risk of buying used, it's also difficult to find quality wheelsets with hubs that support the 142 x 12 and the 15mm through-axles. And, to further complicate things, there is some data that even with Hopes, you MUST (or really should) get the EVO upgrade as the previous Hope Pro 2's snapped a lot of 12mm through-axles.
    I did run across a very good shop for wheelbuilding (recommended here by someone): Red Barn Bicycles, in Montana.
    I've emailed and talked a bit with Chad Devalls, the wheelbuilder there. He can build a set of 819's with Hope Pro 2 EVO hubs for ~$575 plus shipping. That's still a lot of $$, but I guess when it comes to wheels it's all relative. Chad also told me that the Mavic Crossrides that came on my bike are not bad at all, but heavy, and that some of the servicing/reliability problems with the rear hub (Delrin bushing on the freehub) have been solved, so I feel better about riding with them until I'm ready to upgrade.
    Then there's the question of tires...... I guess it never stops. But it's a fun hobby. I'm riding more now and just starting to get a little bit better at it and maybe by the time I get new wheels I'll be good enough to actually notice and appreciate them!
    Good links thanks.
    Yea it never stops. I'm building this bike from the frame up for the first time at this point I'm already into it a crap load so I may as well get the wheels I want or I will just end up buying them in a couple months anyway.
    Reputation: Transfer's Avatar
    Bumping an oldie for some help.
    If I have a 142x12 rear hub wheelset that I'm putting on my SB, then I need these, right?
    Shimano Rear 12X142MM Thru-Axle at JensonUSA.com
    Yeti Cycles 142mm Chip Dropouts at JensonUSA.com
    $107 is a little steep but whatever. Any other axle options confirmed to work?
    I have the SB66 XT Race buid. I would like to put my other wheelset on it. My other wheelset Mavic 521 hoops laced up to DT Swiss 240s hubs. The rear alreayd has the 10mm axle. What do I need to covert it to 12x142 and use it. I know I need the 12X142 coversion kit, but will the 12X143 Shimano axle that came with the bike work? Or do I need to buy the DT 12X142 conversion kit, DT 12X142 axle and Yeti DT 12X142 chips? This is really getting difficult. Can someone shed some light on this?
    Quote Originally Posted by ATVTYSON View Post
    If you convert your 240 hub to the 142x12 endcaps then it will work fine with the Shimano axle.
    Jan 2011
    Quote Originally Posted by Dogboy View Post
    Don't get the DT axle--it won't work with the current Yeti chipset.
    Does anyone make a nut/adapter to allow the DTSwiss 12mm axle to be used with the Yeti dropout?
    I prefer the DTSwiss axle but the finer thread pitch will not work with the scalloped nut captured on the dropout.
  1. Anyone know where to get a Shimano 12x142mm thru-axle?
    By woodyak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2011, 11:24 AM
  2. 9 Speed Availability for Shimano
    By Ranger Pride in forum Shimano
    Last Post: 12-15-2010, 03:35 PM
  3. Availability of Azonic Momentum Axle
    By carrot_top in forum Wheels and Tires
    Last Post: 07-12-2008, 08:40 PM
  4. Shimano axle length ?
    By elder_mtber in forum Wheels and Tires
    Last Post: 11-10-2007, 09:43 PM
  5. Help: Shimano Hollowtech II tool availability???
    By indigosky in forum Singlespeed
    Last Post: 01-13-2005, 11:15 AM
Members who have read this thread: 4
