Results 1 to 8 of 8
    Aug 2013
    120 mm fox fork on 2012 sb95 enduro
    Went to the fox website for fork instructions for the oem fork on my 2012 sb95 enduro and they only list. 140mm travel fork in that model. Do I have that fork with the travel shortened to 120? If not, why doesn't fox list the 120mm version of the 34 float on their site?
    Reputation: wilbcol7's Avatar
    Oct 2011
    The 120 mm Yeti fork is a 140 with a reducer installed to make it 120.
    Aug 2013
    So I could remove the reducer and instantly go to 140 travel?
    Oct 2011
    Yes. The instruction are on the Fox website.
    Aug 2013
    Thank you!
    Chilling out
    Reputation: bear's Avatar
    Cbopleasanthi:
    The the fox service stuff can be confusing, but the info is there.
    Most importantly get the info on how to remove the lowers and replace the oil.
    If you're fork is a year old you may want to consider replacing the dust wipers and seals while you're at it.
    Once you have the lowers off, to change the travel limit, you only need to remove the retaining ring at the bottom of the air spring and then gently pull the bottom of the piston down until you can see the travel spacer.
    The travel spacer will just pop off the rod with firm pressure.
    Now reassemble everything, new oil, yadda yadda.
    Good luck.
    FYI: the travel spacer looks similar to this...
    Mar 2005
    kelstr video on the Fox 34
    here is a great video on the Fox 34 that MTBR member kelstr did:
    Aug 2013
    Excellent video...thanks for sharing!
  1. Replies: 8
    Last Post: 10-10-2014, 08:33 PM
  2. SB95: which offset fork?
    By brum in forum Yeti
    Last Post: 07-16-2014, 08:23 PM
  3. SB95 Fox 35 CTD Fork Mod
    By Rockrover in forum Yeti
    Last Post: 06-17-2013, 09:10 PM
  4. SB95 Enduro: Crank/BB spacing wrong?
    By LookerBob in forum Yeti
    Last Post: 08-30-2012, 09:03 PM
  5. 2012 Enduro Comp Fork Question
    By BiknBob in forum Specialized
    Last Post: 02-06-2012, 11:50 AM
