Results 1 to 11 of 11
    08 575: Does the Specialized water bottle cage fit?
    I bought the Specialzed Rib Cage Pro MTB for my 08 575 size medium but when I mounted it it looked like a very tight fit - it looked as if the rear shock would touch it.
    Does anyone have experience with this water bottle cage fit
    Link to the cage
    Reputation: Tinshield's Avatar
    I have not had any luck even using a short water bottle. I'm not happy about this at all since my Niterider classic is now essentially useless. I saw the Specialized cage the other day and I don't think it will work any better than a regular one. A side entry cage might. Stupid, stupid design.
    On my 05 575 I had a really cheap and ugly water bottle cage with a side entry which worked perfect.
    Anyone know some decent cages with side entry?
    Moderator Moderator
    Reputation: driver bob's Avatar
    Not for an MTB.
    Invest in a Camelback and ditch the cage.
    I already have a camelback but would prefer to put energy drink into a bottle instead of my camelback
    Quote Originally Posted by driver bob
    Not for an MTB.
    Again,
    it doesn't solve my battery problem with the light. I use a camel back
    Jan 2005
    I found a side entry cage at my LBS---have no idea of the brand. I took my bike up there and bolted them on until I found the right one.
    mine fits on a large,bottle is a bit tight to get out but it fits all the same
    I used a Profile Stryke cage and 2 presta valve nuts under the back bolt to tilt the cage slightly. I'm able to get a small bottle in/out easily. And a large bottle but it's a little tight. I thought maybe the bottles might hit the frame with the tilt of the cage...but not even in the roughest of terrain, it's just fine.
    Hey nice idea!
    I bought a cheap Nashbar
    <a href="http://www.flickr.com/photos/jmhix/2615801515/" title="S5000374 by jmhix_02, on Flickr"><img src="http://farm4.static.flickr.com/3256/2615801515_39b22c8da3.jpg" width="500" height="375" alt="S5000374" /></a>
    <a href="http://www.flickr.com/photos/jmhix/2616629682/" title="S5000375 by jmhix_02, on Flickr"><img src="http://farm4.static.flickr.com/3075/2616629682_f047ed9830.jpg" width="500" height="375" alt="S5000375" /></a>
    BTW it is a large frame. It is a little tight to get to the Propedal lever but it is doable.
