I have the 26" Cobalts on my Ibis Mojo too. They held up very well, but I did have the freewheel hub replaced (older design). Very simple to replace and afterwards didn't have any issues. I also never had to true them and they hold air for my tubeless tires great. The customer service at CB is exceptional.
I've had the 29" Cobalts for about 2 months. One race and about 400 miles. So far so good. Did have to re-oil the prawls, but afterwards they are good. What I like about them is they are light, hold tubeless tires very well, customer service is great, and they look cool.
Just a heads up to anyone who has or is getting
a set of Cobalts. I have 3 sets of these wheels and
they have been bomb-proof, and have held up great.
However 2 of the three sets didn't have any lube as
in dry around the pawls. So make sure they are
lubed.
Frame: XL Big Top
Fork: Fox F29 100mm
Wheels: King hubs on Bontrager rims
Handlebar: Crank Bros Cobalt low rise
Stem: Thomson X4
Tires: Bontrager
Seatpost: Thomson
Crankset: Shimano XT
Seat: WTB laser
Shifters: SRAM XO twisters
Rear: SRAM XO
Front: Shimano XT
Brakes: Shimano XT (180/160) still need to trim the front
Pedals: Time ATAC
I have no idea what it weighs, but it feels great!
Standby....needs better pics...
"My Life is violent, but violence is life" - Ice T
Do you have any problems with the brake levers touching the top tube? I'm building up my Large and it's driving me nuts! I'm thinking about buying a low rise bar so I don't have to run so many spacers. Looks silly the way it's set up now
Large frame, Fox F29 fork, Cane Creek headset
Thomson post and stem
Answer Pro-Taper bar, Ergon grips/ends
XT crankset, e13 32t ring
Chris King 20t cog
XT brakes
Hope Pro II hubs / ZTR arch rims
I'm still playing around with the cockpit, I now have a Thomson setback post and a shorter (100 mm) no rise stem on it, trying to get it dialed in.
My first 29er and first SS, my fourth Yeti. I love this bike.
Brand new:
Drivetrain:
Broken in:
Never thought I would like a bar this wide, or [gasp!] bar-ends!
Nice call on the black wheel in the back...I thought of that after I built mine up. Not much of a picture taker (too busy riding), so I just have this so-so pic:
1x9, MRP direct mount guide
142x12 thru rear
Stan's Arches on Hope Pro 2s
Nobby Nic front/RaRa rear both Pacestar TL SS
Thomson stem and post
Ergon GP-1 grips
Elixir CR brakes 185/160
SLX cranks
Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
My new steed She's all done other than I'm waiting on a buddy to buy the Fox RL off me so I can grab a *WHITE* 2012 Fox 34 RLC for it. I built it with heavy duty trail use in mind so there's not a lot of weight weenie stuff on it. Everything's sturdy and yes, it's awesome at 120mm of travel and the Fox 34 will be set there as well.
EDGE riser bars at full 700mm width
X9 10 speed drivetrain
Widgit 32t chain guide/bashring/sprocket
SLX crank arms and BB
Flow rims
Champion spokes
King rear hub with 10mm DT skewer
Hope Pro2 EVO front hub
ControlTech seatpost
Syntace Superforce 75mm stem
XT 11-36 cassette
IKON EXO F/R
Formula RX brakes
Hope 2 piece rotors(7" front, 6" rear)
ODI Yeti grips
Blackspire Sub4 pedals
XTR chain
Phenom Expert saddle
KCNC seatpost clamp
Stans yellow tape and valves with 2 scoops of sealant
Mine is the regular size Lefty. It depends on the stack height of your headtube with headset installed. If you are stack height is less than 138mm you can use the regular. The only headset I found that would work for fitting the regular Lefty to the large BT is the Crank Bros Directset. It came in at 137mm installed.
If you have to use the XL lefty you could end up with a large stack of spacers. In some cases that could raise the stem to an uncomfortable level.
