Results 1 to 2 of 2
    Jan 2005
    Winter Indoor Training
    Hi All,
    I have a spin-bike at home but am thinking of trying Rollers. http://www.kreitler.com/
    I'd like to here some ideas and thoughts on indoor training and IF rollers are a good thing for mtbers...
    I like training outdoors much, much better, enough so that I'll go ride in the cold. But, if you live in a place (like me) where the weather makes it absolutely impossible to ride outside at times, then training inside becomes a must. Four-hour rides on the trainer are no fun, but they can be bearable - good music helps, as does video (last year's race videos are great for training).
    Rollers are fine for MTBers, but I wouldn't ride your MTB on them unless you swap out tires for slicks. I swap the rear tire for a slick on the trainer, and if you're on rollers you should change both tires. Go for something fairly low-volume/high-pressure so they won't deform too much around the roller and create lots of wear and resistance.
    Alison Dunlap Coaching
    When you're not paid to ride.
