Results 1 to 20 of 20
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Who's using SRAM PC-991 hollowpin?
    I have heard good and bad things about this chain. What has been your experiences? I have one on the way, but I wanted to check here first before using it in any races.
    Thanks,
    Rod
    There is not much choice between rotten apples.
    Quote Originally Posted by "Rod" View Post
    Thanks,
    Rod
    Not anymore. Holds dirt much more than solid pins chains. I ride shimano XTR now.
    Rod
    Rod is offline
    Oct 2007
    Quote Originally Posted by crimecrusher View Post
    Did you or anyone have a problem with the chain breaking? I have read several reviews of it snapping.
    no excuses
    Reputation: txF5's Avatar
    I have used one for months now without any issue. Keep it clean and lubed and its golden, at least in my experience.
    2011 GT Sensor 29r Pro
    Fox Racing
    Don Johle's Bike World
    Both of my bikes came with PC-991 chain, One broke at the Powerlink... I replaced with the new XTR 10 speeed and Its a great chain, so far its been good..
    www.sebastcycling.com
    2011 Jamis Dakar XCR team
    2011 Jamis Dakota DXC Team
    2010 Jamis Xenith SL Team
    gunslinger
    Reputation: selector's Avatar
    I've used 'em w/o issue.
    is turning a big gear
    I think most chains break because of user error (forcing dumb shifts at high torque). At least that's the only way I break 'em.
    Rod
    Rod is offline
    Oct 2007
    Quote Originally Posted by estabro View Post
    I believe you're right, and then ppl get on mtbr reviews to bash the chain.
    mini clyde
    Reputation: eedavis's Avatar
    I've run 991 Hollowpins for the last 5 years on my main trail bike . I've broken lower-spec Shimano and SRAM chains, but not a 991. They also seem to be a bit more corrosion-resistant than LX/XT-level chains, which die of stiff links before they wear out whereas the 991s live long enough to actually wear out, 2+ years of 6+ hours/week trail riding in my case. I don't take very good care of them, lube every 4-5 rides or after they get wet, clean them maybe twice a year. They hold up great considering how little effort I put into them.
    I have not ever run DA/XTR-level Shimano chains so cannot help with that comparison.
    Mar 2005
    Can Shimano chains run SRAM's quick link?
    Quote Originally Posted by nj0ywatch1np0rn View Post
    I have done that and never had an issue.
    Mar 2005
    Sweet!
    I've had one on my Road Bike for 2 years now (Which is an eternity for me) and it has not caused me a problem. I am the perfect component tester too. Perma Clyde -- am *literally* hell on wheels(Pulled the spokes out of 4 supposedly bulletproof rear rims in 2 years) also very hard on drivetrains. If you have a penchant for breaking chains I would go with the 991 cross step otherwise the hollow pin appears to be at least as tough as the low end 9 speed offerings from SRAM. I don't like the shimano chains as I have had similar stiff link problems as an earlier poster, although I will admit to limited experience with them(maybe 2 chain across 3 bikes in the last 6 years)
    Rod
    Rod is offline
    Oct 2007
    Quote Originally Posted by clydeone View Post
    Thanks for the elaborate post. I appreciate the feedback. I was just wanting to make sure it wasn't as fragile as it appeared in the reviews on this site. I've been using a low end 550 or smoething and 971 before without issue, so hopefully I should be okay.
    likes to ride bikes
    Reputation: TunicaTrails's Avatar
    After far too many mishaps, I now have a new chain mated with a new cassette on race-day only wheels now. It's expensive but effective, and I never have to worry about what stage of life my drivetrain is in. And I don't have to worry as much about my choice of chain (although I can recommend Wipperman Connex).
    Rod
    Rod is offline
    Oct 2007
    yes
    I used one. No issues. Replaced it w/ a much cheaper chain through.
    Reputation: MrEconomics's Avatar
    Used always. No issues.
    Reputation: ghettocruiser's Avatar
    worked the same as my other (PC99) chains.
    The above statements have not been evaluated by the Food and Drug Administration
    Reputation: willymcd's Avatar
    I have been using them for a few year without one break. I crank hard pretty hard, and am sometimes not the smoothest shifter, but I also am pretty anal about keeping my chains clean and lubed up which might account for me not having chain problems, knock on wood...
  1. Sram PC-991 HollowPin Chain (Broken!)
    By Reckless1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2007, 04:09 PM
  2. XTR Cassette/Sram 990 hollowpin chain
    By Ice25gt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2006, 02:15 PM
  3. PC991 hollowpin
    By Havoc138 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-12-2006, 07:41 AM
  4. PC99 Hollowpin chain failure anyone?
    By Fullrange Drew in forum SRAM
    Last Post: 04-07-2005, 04:02 PM
  5. Difference between PC-89 & PC-99 Hollowpin
    By Explosif98 in forum General Discussion
    Last Post: 07-28-2004, 01:34 PM
