Page 2 of 2 FirstFirst 12
Results 51 to 94 of 94
  1. #51
    Reputation: WR304's Avatar
    Quote Originally Posted by jared_j View Post
    You cannot control for variation in how athletes test their 20 min numbers (fresh? 5 min blowout like Coggan says? on the flats? on a climb?),
    Good cross-sectional data on power/weight ratios isn't really publicly available, so ultimately making a decision on the validity of this metric as a lay-person rider is going to be a question of faith, e.g. trusting coaches and researchers who have access to the data and publicly state their conclusions.
    That's a good point. Even with just your own tests you're going to see wildly varying ftp test results depending upon the route, and also the test protocol. For example I can achieve a significantly higher 20 minute ftp test result if it's on an uphill course than doing a 20 minute time trial on a flat route.
    About all you can do is try and make sure that your own ftp tests are performed on the same route in the same repeatable manner each time. That should allow you to reliably track your own progress over the year.
  2. #52
    This is an extract quoted from the Google Wattage Group about the best way to test your ftp.
    You have to sign in to view the actual thread:
    Wattage | Google Groups
    "Question for the group...this will be my second year training with power. In the past, I've used the Coggan method for testing FTP (some pre-work followed by a 20min TT, of which I take 95% to be my FTP for that test). As I understand things, the purpose of the abridged testing protocol is to ensure that the athlete maintains focus and to make the test more manageable overall.
    In discussions with teammates, it's come up that this might be returning FTP values that overestimate your (my) true FTP. Basically the questions revolve around the 95% measure and the pre-work adequately simulating a cyclists true FTP over a 1hr TT (from a fresh state).
    The discussion seemed to boil down to "if you're so confident in your (ie: Coggan's) method, jump on the bike and rip off a one hour TT, see if you can replicate your wattage from the Coggan test...
    Any comments, points for or against the Coggan method? Really what I'm asking the group is who uses the Coggan method (the one specified in his book "Racing and Training with a Power Meter") and who uses the traditional 1hr TT method?" EricV
    "It doesn't matter what method you use as long as you're consistent. The point of having an FTP number is not so you can participate in e-wang internet contests, it's to guide your effort during training and potentially racing if you're doing TTs. As far as training you'll find out soon enough if your method is working as the workouts based on particular FTP will either be too hard or too easy. You'll end up adjusting the target %FTP that you use as needed.
    If you're using 95% of 20min power to determine FTP and you end up not being able to maintain that in a 40kTT then you just make an adjustment for next time. There is no way to know ahead of time what the ratio of 20min to 60min power is until you actually test both. Many people need a race to generate the motivation to go all out for 60min hence the prevalence of shorter tests." Gregf
    "There are many reasons why there are several methods of testing for FTP (some valid, some less so):
    - there exist a number of published methods that work reasonably well (some are better than others), in particular those presented by Andy Coggan himself
    - some people don't want to go hard for an hour, so are looking for an easier/shorter alternative
    - some don't want to test 1 hour all out all that regularly, or are concerned with testing interfering with training, so look for other ways (e.g. examining race data)
    - some do not have ready access to suitable venues to go quasi steady state hard for an hour (terrain, traffic lights etc make execution difficult)
    - a 1 hour indoor trainer test may not provide a valid result given the often quoted difference in indoor v outdoor power
    - some need the motivation of a race number on their back to perform, but do not have hour long TTs where they live/train
    - some are experienced in training with power and know from their regular training how it's going (e.g. regular interval work is a test method itself)
    - some might be more interested in performance for other time durations relevant for their goal events, but still want an FTP estimate anyway for all the useful things it enables
    - marketing / "branding" of a preferred testing method by a coaching group/personality
    As a result, there will be no consensus. It comes back to what you are doing testing for.
    To know your maximal quasi steady state power that you can sustain for about an hour, well really there is only one test for that.
    But as to what method is preferred to estimate FTP for the purposes of training with power (setting training levels, assessing fitness changes, using the performance manager etc etc), well one has to take into account all the reasons above that apply to each individual when deciding what's the best method for them.
    As a coach I employ several different methods (e.g. longer and shorter TTs, MAP tests, critical power, assessing regular interval and hard tempo training, inspection of race results) depending on a range of factors for each client. But you then try to remain consistent with the testing approach for that client. Circumstances do change though.
    As to the relationship of the outcomes of the Hunter Allen 20-min test 95% = FTP method, well that's been recently and not so recently picked over a gazillion times. I would suggest that it will get you to within a few %, depending on how one performs the pre-test "blowout" effort. As others have said, pick a method and if you find the result seems a bit out of whack relative to your subsequent training ability, well then you adjust accordingly.
    However there is definitely a variance in the relationship between 20- min power (sans blow out effort) and 60-min power, and those who can hold 95% of 20-min power for 60-min are at one end of the bell curve in my experience. More are closer to 90-93%, some less. And the relationship for an individual can vary as fitness changes and/or they learn to pace better." Alex Simmons
    >Alex, what are your thoughts on the pre-test blowout?
    "Don't have many. I don't use/prescribe it when testing, just a good warm up instead.
    I prefer to know the mean maximal power for any given duration of interest when testing.
    That's not to say it's not a valid test protocol, just not what I prefer to use. I suppose I prefer not to introduce another variable (i.e. "how hard do I ride the blowout coach?"). I use a multiple of sins depending on the individual circumstances. It sounds like a pretty good shorter training session though, which is always a good thing. Toss in some sprints, bit of lactate tolerance work and voila, one for the omnium guys." Alex Simmons
    Alex's Cycle Blog: The seven deadly sins
  3. #53
    Giant Anthem
    Reputation: 2fst4u's Avatar
    I did a computrainer group ride at an indoor facility this Saturday, with my powertap hub on. Weird, huh? I don't know if the results are inaccurate or not using both items but the computrainer and the powertap didn't have the same readings. The powertap was about 25-30watts lower average than the computrainer. It was a great ride but it was set up based on our "guesstimated" FTP so every persons resistance was proportional to their FTP. So 2 guys rode 35-40 miles while others got 25ish. I don't know much about computrainers but we should of all had the same resistance and been able to use our gears.
    Racing and Training Blog
    http://dirtandgears.blogspot.com/
  4. #54
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Quote Originally Posted by whybotherme View Post
    I would be willing to bet that it you could predict MOST of the outcomes of races given that information. The exception would be when the best climbers (as designated by power/weight) cannot descend well and are faced with a technical course.
    yep, yeh, yes, ditto +1
  5. #55
    Quote Originally Posted by 2fst4u View Post
    Have a look at the comments about computrainers by daveryanwyoming in this thread:
    SRM vs Computrainer power readings
    Also:
    SRM vs. Computrainer watts discrepancy : Triathlon Forum: Slowtwitch Forums
    If it was your own computrainer then you could adjust its slope to make it match your Powertap readings. If you're going to be riding a lot in the same facility then you probably want to try and use the same computrainer each time to ensure consistency.
  6. #56
    You can do a static torque test with your powertap to verify it's accurate. Basically you hang a weight from the pedal axle (I use 25lb plate) and look at the torque reading on the PT. I have a spreadsheet around somewhere that calculates it's accuracy, based on torque reading, weight used, gear ratio, and crank length. I check it once a year or so to make sure it doesn't drift.
    On the computrainer I find it's necessary to repeat the spin-down calibration test after at least 10 minutes of warmup in order to get accurate readings. Mine's also calibrated to match my powertap. From the factory the older models were all over the place, but I hear they've gotten better.
  7. #57
    Quote Originally Posted by WR304 View Post
    Garmin Connect and Strava
    I uploaded the same Garmin Edge 500 .fit file to Strava, Garmin Connect and also into WKO+ 3.0. The results are pictured below.
    Whats your current 30 minute TT power average?
    Garmin Connect automatically splits the ride into moving and stationary time for calculating average speeds. It gives you both moving and elapsed time average speeds but doesn't do the same thing for average power. The overall average speed in Garmin Connect summaries is the lower figure which includes stationary time. Average power in Garmin Connect includes any stationary time also. That means average power will always be lower viewed in Garmin Connect than the same ride in Strava.
    Since the recent Garmin Connect update moving average speed is no longer displayed. All stationary time is included within the average speed and average power figures, unless you have auto pause enabled or manually stop the timer. Garmin's auto pause can affect the accuracy of the recorded power figures so you don't really want to use it with a Powertap. The picture I posted above is the old Garmin Connect layout.
    This isn't so much of a problem if you never stop, or only briefly. A ride like yesterday's is a good example of how lots of stationary time can make the averages meaningless when you include stationary time though. Yesterday I went down the canal towpath for a quiet ride. That involved regularly stopping to open and close gates. I stopped and took a few photos at one point too. On the way back I also punctured and spent 30 minutes ( ) trying to work out what had caused the puncture. I think it was a thorn attached to a stick that probably went through the tyre but then pulled out again.
    What that meant was the ride ended up being 2h32 ride time and 49 minutes of stationary time. If you were to view that ride in Garmin Connect its average speed and average power would be much lower than the moving averages as a result.
    Garmin Connect isn't that good anyway but if you do use it it's something to be aware of.
  8. #58
    Giant Anthem
    Your power numbers-just curious
    Still having fun with the power meter-it's been a great training tool this season. I just started racing in the expert class getting hammered this season. I don't road race but 1x per year but do train on the road 80% of my rides.
    Anywho, I'm just curious what kind of power numbers my racing peers are putting up and your experience with using power... thrown in some info about yourself like age, class etc.
    Attached Thumbnails Attached Thumbnails Whats your current 30 minute TT power average?-power.gif
  9. #59
    Reputation: serious's Avatar
    Jan 2005
    I have not tried a 30 minute TT, but I think I can do about 240-245 Watts for 30 minutes, based on a recent interval session as follows:
    16 min at 245w
    3 min at recovery pace
    8 min at 245w
    4 min at 245w
    2 min at 245w
    7 min at recovery pace
    2 min at 245w
    4 min at 245w
    8 min at 245w
    16 min at 245w
    That is a 85 minute session with 60 minutes at 245w. I am 155 lbs, 50 years old and this was done on a CycleOps 300 Pro.
    My rides:
    Lynskey Ti Pro29 SL singlespeed
    KHS Team 29
    S-Works Roubaix SL3 Dura Ace
    KHS CX 550 cyclocross
  10. #60
    Jun 2012
    It depends...
    Quote Originally Posted by Caffeine Powered View Post
    You are weak and should rightly be ashamed of those numbers!
    But really, What Strat said. Check your preferences in the Power Agent and if you have the time, give the CycleOps help desk a call. They're really good at making sure you get the most from their product.
    Depends on riders weight
  11. #61
    Reputation: Poncharelli's Avatar
    Jan 2005
    Here's some data for ya for comparisons.
    This is the culmination of hundreds of power files, taken from the most ideal conditions for highest power (group rides/races are best). Except that these are at elevation (~4000-6000 ft.)
    -The short power records were either crits or group rides that start on a hill.
    -The 2-4 minute records on a long false flat hill, at start of same weekly group ride.
    -The 5 minute on my rollers during a 5-min power test.
    -The 10-30 minute was a day with strong roadies on a long 10% average climb and I nearly the last one up.
    -The 60 and 90 minute PRs, I flatted at the start of a road race and chased alone for 30+ miles; unfortunately didn't catch anyone after spending a few minutes switching tube.
    I usually weigh around 160 mid-summer. Currently 164.
    Cat 3 road, Cat 1 MTB, and entering Bs for cyclocross, nearly 46 yrs old. My race focus has changed to cyclocross. I'm pretty much done MTB racing.
    Attached Thumbnails Attached Thumbnails Whats your current 30 minute TT power average?-power-records.jpg
    Head Coach, Ben Lomond HS MTB Team
    www.utahmtb.org
    Cycling Team and local Club:
    http://www.roostersbikersedge.com/
  12. #62
    mnoutain bkie rdier
    20 min
    is the most common way to measure pwr and ftp as far as i recall. right now i am somewhere around 3.8w/kilo. adding intensity and getting down to race weight should help quite a bit.
    btw...currently get my butt kicked as cat 1 in s. california.
  13. #63
    Registered Dietitian
    Reputation: tommyrod74's Avatar
    Jul 2002
    I've only ever formally tested 20 minute power. 337 watts as of 3-4 weeks ago.
    143-145 lbs, recently upgraded to pro.
    2 x 20 intervals at ~90% of my best 20 minute power works for me as far as a bread-and-butter workout. I rarely do intervals < 20 minutes anymore for MTB-specific training.
    Registered Dietitian, Cycling Coach, Ascend Nutrition and Coaching
    www.ascendthepeak.com
    www.facebook.com/ascendthepeak
  14. #64
    DLd
    DLd is offline
    Feb 2005
    Apparently you and I would have a really close race. I'm within 0.1 of your w/kg on all but 5 sec. and 120min. Some higher, some lower, a few the same. My 60/90/120min numbers are 3.3/3.3/3.2. Those three are all from a recent workout up Mt. Lemmon here in Tucson. 6000' of climbing in 2.5 hours will lead to some solid numbers for those.
    Enjoying the powder and looking forward to spring!
  15. #65
    Giant Anthem
    Quote Originally Posted by DLd View Post
    Very cool...whats your age weight class etc? I'm 40, race expert class, 153#. Looking at your numbers you would probably pull past me after an hour to an hour and a half and beat me by 2-3 minutes in a 2-2.5 hour race
  16. #66
    Giant Anthem
    Quote Originally Posted by tommyrod74 View Post
    337 watts as of 3-4 weeks ago, 143-145 lbs.
    Yowsers- that's a lot of power, guess I have some work to do if I want to go pro
  17. #67
    Jul 2002
    Don't worry, I have lots of work to do as well. Going to be a challenging first season in the new category.
    When I first did a power test it was ~250 watts for 20 minutes a few seasons ago (I had been riding for several seasons already at that time, but no structured training). I've made slow but steady progress through consistency since then. Focused FTP work this past season really paid off.
    I'm getting very close to my big goal of 5.0 w/kg at FTP... but power is only part of riding a bike fast in the woods.
  18. #68
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    I let myself go after about September of 2011 so my power #'s right now (& weight) are a joke. I'm in the process of rebuilding and getting back to form for next season.
    44 yr old (as of a couple days ago)
    Endurance mtb focus
    15min & 30 min power (Powertap #'s) a couple weeks after last race of 2011 (Breck68) = 286w/15min & 270w/30min (both PR figures)
    3.55 w/kg
    Pretty much a mid-packer in the 40-49 yrs old group in RME series races that I did
  19. #69
    Giant Anthem
    So your 20 minute test was 250w a few seasons ago, now 337w... big improvement. You rarely do any intervals shorter than your 20m @ 90% ones? This last (and previous seasons) on my tues/thursday workouts I always do intervals, vo2 max and threshold. They are short and intense but in the expert class (just upgraded in 2012) the races are longer than sport and I find I may need a different focus on my training to push higher numbers longer distances.
    Other than your 90%/20m intervals how did you structure your training to improve as you did? Longer rides (duration)? More workouts per week (frequency)? Less intensity with more volume? In other words what worked for you?
  20. #70
    Jan 2005
    Quote Originally Posted by MSH View Post
    And it's amazing how quick that happens. Last season I broke my wrist which kept me off bike over a month and started base miles barely pushing 130W in low tempo HR zone. My LT power at that time was probably 200W or less, but it does come back quick.
    www.utahmtb.org
  21. #71
    mnoutain bkie rdier
    So your 20 minute test was 250w a few seasons ago, now 337w... big improvement. You rarely do any intervals shorter than your 20m @ 90% ones? This last (and previous seasons) on my tues/thursday workouts I always do intervals, vo2 max and threshold. They are short and intense but in the expert class (just upgraded in 2012) the races are longer than sport and I find I may need a different focus on my training to push higher numbers longer distances.Other than your 90%/20m intervals how did you structure your training to improve as you did? Longer rides (duration)? More workouts per week (frequency)? Less intensity with more volume? In other words what worked for you?
    They really need to make the Cat2 and Cat1 distance the same....for so many reasons. Either make the 2 race longer or the 1 race shorter. This ambiguous thought of "Well, the Cat1 guys are pretty fast, so let's just add 5 miles to their race" sorta thing exists nowhere else in racing. It makes it hard for the 2's to figure out how they stack up against the 1's also. That extra lap is a killer the first season as a 1 imo....
    Sorry for the hijack... Tommy...good numbers. Hoping to get there myself.
    Oh, and why the heck are Cat1's racing from longer periods of time (hr more sometimes) than the world cup racers? Haha. Funny really..
  22. #72
    Jul 2002
    Very little structure, honestly, until this year. With a young daughter and a full-time job I had to structure thing to be effective.
    I had a very good anaerobic engine already from soccer, running, hard MTB riding, and group road rides/racing. What really needed training was my sustained power.
    This is where most MTB racers are deficient, IMO, the ability to go hard for a long time without coasting or soft-pedaling. Granted, off-road you have to coast a lot due to terrain, so road/trainer intervals helped me a ton.
    I now (during a build period) shoot for 2 high-quality interval workouts per week, plus a long zone 2-3 ride on the weekend. All else is zone 2 or even zone 1. About 8-12 hours total depending on the week.
    I will try for 1 week of 1/2 volume after 3 weeks of work this year to avoid overdoing it. Better to be slightly undertrained and fresh tha the opposite.
    I got very far just riding a ton, with a lot of unstructured hard riding. Now with time constraints I need structure, and structure has benefitted me greatly so far.
  23. #73
    Jul 2002
    Quote Originally Posted by rydbyk View Post
    I agree totally with your points on distance and categories. Our first race of the XC series this season will be 3 hours long. Friggin' DOUBLE a World Cup duration. What is the point?
  24. #74
    DLd
    DLd is offline
    Feb 2005
    Cat 1, 42, 165 pounds currently, but I was down to 158 for race weight last year. Then I sprained my MCL two weeks before the start of the season last year, snowboarding, and didn't race last season. I'm surprised how fast my numbers came back, just got serious again in October. I'm looking forward to seeing how I do in cat 1. I haven't raced in about 10 years, but feel a lot more in shape now with structure and diet.
    Sent from my Nexus 7 using Tapatalk 2
  25. #75
    DLd
    DLd is offline
    Feb 2005
    How much rest between the 2x20's? That sounds like a good workout. I just did some 4x6's, but I'd like to try the 2x20's. I would imagine that working on your 20's all the time would tend to bring up your 20min test power, but it seems like an effective range to train for MTB racing, especially cat1/pro. There's only so much you can do on the short 1 hour weekday workouts.
  26. #76
    DLd
    DLd is offline
    Feb 2005
    I have a feeling my 120 minute number is partially due to having the terrain suitable to extracting high performance for that length of time, If you had a solid 2.5 hour climb near you, you would probably put up a similar number.
    A lot of the numbers are for time intervals that I don't do intervals for. Like, I don't think I've ever done 5s sprints. Also, I'll do 20s Tabatas sometimes, but I don't think I have any 30sec intervals in my training. I'll rectify that situation in the upcoming weeks. I'll throw in some 5s sprints, some rest, and a 30 sec sprint just so I can see what numbers I'm really capable of. Y'know, for science
    My workout yesterday was supposed to be 3.5 hours at Endurance, followed by 30 minutes at Tempo. I was short on time, so knocked it down to only 2.5 hours at endurance, but I really wanted to see if I could move up my 20 min, so for the first 20 minutes of the Tempo workout, I really focused on being in high Tempo/Threshold. I hadn't looked at what my 20 min was beforehand though, but I figured keeping it above 260 would be good. I didn't have time to download it yet though. My current 20 min was 269, and seems to be from an apparently random training ride last year. It doesn't look I was doing a 20 minute test or anything, so I'm eager to see if I beat it, actually trying to this time.
  27. #77
    Jul 2002
    I usually take 5 minutes between intervals to recover a bit. My second 20 is usually easier than the first (properly warmed up and used to the effort). It's usually a 1-hour workout - 10 warmup, 20 on, 5 off, 20 on, 5 cooldown.
    I occasionally do 1 x 40 instead for variety, it's really not much harder. 90% of my best power for any given duration is noticably easier than 100%.
    Also, any interval of 10 minutes (at least) or greater works threshold directly. My goal is to spend at least 40 minutes in zone 4 during these workouts. I just don't usually break it up smaller than 20 minute chunks.
    I'll do 1 hour straight at 90-95% FTP every now and again as well. You get used to it.
  28. #78
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Why are my numbers so much higher when climbing compared to flat?
    My 5 min hill climb timetrial number is 6.1 w/kg and my 5 min interval on flat is only 5.52 w/kg...
    Is this because I am a better climber than flat TTer? Or because I was racing on the hill climb and training on the interval? Or something else?
    Im still a noob to power. The only test I have done is 5 mins, and MAX power.(for fun)
    I really want to get a solid FTP test, 5sec, and 30sec though. But that wont happen until March or so...
    Raised in a Chicken-Coop by Chickens
  29. #79
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Quote Originally Posted by Combatcm View Post
    I can do about 300 an hour so probably around 600 for 30 minits
    umm, no.
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
  30. #80
    Quote Originally Posted by Sheepo5669 View Post
    climbing numbers are generally higher then flat speed numbers for a lot of people. The neuromuscular demand of climbing isnt the same as riding the flats. Wind resistance plays a role as well. Think going down a gentle descent where you try to hit FTP, it feels much harder then hitting FTP going up that same small hill.
  31. #81
    Reputation: voodoo5's Avatar
    sick watts bro..
  32. #82
    Jan 2005
    What he said. On flat you only have one resistance source really: wind.
    On a shallow hill, you have wind and gravity.
    That is some hella power, BTW. I'm only 4.7 at that time range.
    www.utahmtb.org
  33. #83
    Giant Anthem
    Same here-most of my numbers are from just riding and one road race. The only numbers I have from a "real" test is the 30 minute TT I did a couple weeks ago.
    I most likely will be testing power throughout all zones soon enough and retest throughout this season for performance markers.
  34. #84
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by Devincicx View Post
    Thanks, that makes since. KINDA. You would think you could put the same numbers down in the wind or up a hill. Could some of it be mental? I am a poor flat TTer...
    Are those charts comparing power to fitness using hill climb numbers? Or flat TT numbers?
  35. #85
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by Poncharelli View Post
    Thanks dude. Im not as fast as those numbers show... First time the borrowed PM read 459w after a 5min hill climb time trial, I thought It was broken. I stole the record by 1 second from a kid who raced for BMC-Hincapie development with that effort
    There is way more to mass start bike racing than that 5 min all out effort. Recovery and repeatability obviously play just as big of a factor.
    I need to get more testing done to figure out what gives and where my weaknesses are. Im still a noob to the sport at just over 1.5 years of racing and 2.5 of riding. I guess a coach would help.
  36. #86
    Giant Anthem
    My personal experience and others is that yeah, going uphill over a given time/distance will increase watt numbers. it's "easier" to get those numbers cheated up higher by hitting a long climb or series of climbs. My 90 and 120 personal power records are all on hilly courses. Although when doing a lactate test/ TT for testing purposes it should done on a flat course or slight uphill (2.5 grade) to keep it accurate.
  37. #87
    Jul 2002
    It's important to remember it's not "cheating up" by having constant resistance, like a hill, headwind, etc. Watts are watts. If you can do it on a hill, you can learn to do it on the flats, or even downhills (as long as you have sufficiently high gearing).
    That said, there's a skill to putting out constant power over varying terrain. It can be done, even on downhills, it just takes more focus and mental attention.
    I do all of my testing and 90% of my intervals on the same indoor trainer. Makes for constant resistance which means I can focus on pushing the pedals and making myself hurt. It also makes my workouts repeatable and consistent.
    I do some longer intervals on rolling and hilly terrain as well to get used to terrain I see in road races.
    If I were looking to set an outdoor power record, though, I'd look for a steady grade that it took me 20 minutes to ascend. None of those nearby, sadly.
  38. #88
    Dec 2005
    pre fatherhood: 20 minute pb 353
    Post fatherhood: 20 minute pb 320 :-(
    (weight 68.5 - 72 kg)
  39. #89
    mnoutain bkie rdier
    I have a hard time maintaining my watts on shallow downhills! Is this a leg speed issue perhaps? Watts are watts ONLY if you can apply them to various terrains imo.
    Maybe I need to work on leg speed?
    This whole pwr mtr thing is new for me also... Do you feel that most folks try to find a subtle 20 climb to test watts?
  40. #90
    Giant Anthem
    Good point. For me to reach the same numbers on flats (or indoor trainer/rollers) as a viscous climb takes a good deal of focus. On a steep enough hill though, there is no choice for the rider but to put out a very high wattage, other wise the rider would have to unclip and get off and push! This is what I meant by "cheating"... the hill provides the resistance which requires you to push hard on the pedals, you have no choice in the matter but on the flats it's a constant temptation to let off the gas.
    Also, I just got rollers and may need to do a large percentage of this seasons training on them- I like them way more than my trainer and was able to do my last 30m test on them with good results. Your ability to put out some good numbers on your trainer is encouraging.
  41. #91
    Jan 2005
    When it comes to cheating up numbers, I'm the best.
    This is the formula (for shorter time periods):
    -Uphill
    -Shallow Climb
    -Pretty easy spin and good warmup before hill
    -In a group with guys around your level.
    This is how we start our Tuesday Night Worlds every week; straight into a 4-5 minute hill, where the first pitch is around 10%.
    But if I'm in a group where the riders are too strong (Cat 2+ roadies, Pro XC and up; for me), I wind up overshooting a reasonable power range right off the bat and just blow up, thus giving me lower average for 30s through 4 min time periods. Plus I mentally give up when the guys are too strong.
    If the guys are at my level (other roadie Cat 3s, for me), it makes everything better. I stay in a reasonable power range from the beginning, and I don't give up, since I should be staying these guys. Like hell if I get dropped!!
    www.utahmtb.org
  42. #92
    Jul 2002
    It's also dependent upon the type of trainer. My Lemond Revolution has a lot of inertia from the large flywheel that kills the "dead spot" in the pedal stroke you feel on most trainers. It feels much more like riding on the road, which means (IMO) that the training is more applicable to real-world riding.
    It's harder to keep wattage up on most (low-inertia) trainers, and I'm not convinced the extra effort translates to riding, due to having to alter the pedal stroke relative to outdoor riding. Unless all of your races are uphill, through muddy grass, with a flat tire.
  43. #93
    Jul 2002
    No, it just requires focus to upshift as soon as it gets easier to pedal and ignore that feeling of "I'm already going fast enough, I can soft-pedal a bit". You can do it at a lower cadence with high force or higher cadence with lower force. Sometimes a higher-than-usual gear with lower cadence helps on steeper downhills.
    You need to pedal through the entire stroke a little more on downhills as well, you can get away with "pedaling squares" a bit more on climbs and still keep wattage high, it seems.
  44. #94
    Mar 2013
    Calibrate your equipment :
    watts on earth the simple math formula is as follows :
    ( watts ) x ( seconds ) = ( 1360 ) x ( pounds ) :
    @ 20 mph :
    On a 4.41 % grade :
    Watts is watts : 300
    Seconds is coasting time in seconds to desend 1,000 feet in elevation : 771
    Pounds is total bike & rider weight : 170
    This means you can truly generate 300w if you can truly cover 20 miles in one hour on flat ground :
    Climb that same grade at 20 mph you are generating 600w
