Results 1 to 41 of 41
Thread: Training legs
    Reputation: mjsca07's Avatar
    Dec 2005
    Training legs
    I work my legs out on Mon and give myself ill Wed to start riding again. Problem is, my legs are still tired on Wed, so I may be working them out a little hard. So my question is, how do you all train your legs to still have strength to ride? Thanks.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Hard work on the legs is eased
    by an easy recovery ride th next day. And I mean EASY. It works wonders.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Uh, I ride my bike, and occasionally XC ski or run.
    If you can't hop on your bike the next day, you're doing something wrong.
    Reputation: onlycrimson's Avatar
    Nov 2008
    You mean weight lifting and cycling? If you lift heavy your legs are going to be sore. After a heavy leg workout my legs will be sore for close to a week. I don't train legs during the riding season.
    I ease the pain by going for a short easy ride immediately after lifting.
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    What is the purpose of lifting weights?
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    Lifting weights increases the maximum force output of the muscles.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    it produces fiber hypertrophy of largely the type II and IIa-b fibers, to a lesser degree type I...
    type IIa fibers are the biggest generator of high end cycling performance.....so increasing the size of these fibers can be helpful in increasing your maximum power output for sub 4 minute efforts and sprints.......weightlifting however does little to increase mitochondria number, you only get that from true endurance training.....
    so one model is to weightlift to make the fibers larger, then endurance train them to increase those fibers mitochondrial number, it generally takes a minimum of 6 weeks of hard endurance training to form new mitochondria.......end result is you can produce more power and through endurance training you can sustain that higher power.....
    obviously there are limits to gains you can make from this approach, but most could benefit from it...
    Formerly of Kent
    Quote Originally Posted by suvowner
    If your FTP is low, you won't be able to use those short, maximum power efforts anyways. Why? Because even though you might beat everyone to the top of the first hill, you'll blow sky high trying to recover, while everyone else who was 5 seconds behind you will coming flying by you, never to be seen again.
    In short, unless you're producing 5w/kg+ for a significant period of time, you have better things to do with your time, particularly riding your bike really, really hard.
    Oh yeah, and it maintains bone density, too, if you're doin' it right.
    LMN
    LMN is offline
    How long have you been lifting for? Usually after a couple of weeks you aren't as tired.
    That being said, tired legs is one things you have to deal with when lifting weights. Does it effect the quality of your other training? You bet. This is why some don't lift weights and just focus on riding.
    Reputation: Poncharelli's Avatar
    Jan 2005
    I've done the Friel type lifting before with the phases he describes: AA, MS, ME, PE, etc. It's weightlifting designed for cycling.
    And it seems to me that the lifting he prescribes does not result in extreme muscle soreness due to the high repetition and relative low load, especially the AA and ME phases. His plan is designed to have a balance of intensity between the weight room and the bike. If the weight room intensity is high, then the bike is low. Intensity in the weight room precedes intensity on the bike. So it could be that you have too much overall of intensity for your weightlifting and bike riding.
    And in general, weightlifting should be a small percentage of overall training time. Every 2-3 hours of weekly weigtlifting should be joined with 8+ hours or so of bike time. When you have few total hours to train, that's when you should be thinking about not weightlifting at all; because you're sacrificing the little bike time that you have.
    But if you have lots of hours of train, and the flexibility and time to recover properly, then weightlifting can be very beneficial,...... at least this slouch seems to thinks so:
    http://www.youtube.com/watch?v=uDawlrIeaVM
    Damn, those step ups are high!! Just hurts my knees watching.
    Also, suvowner, keep those comments coming. That's some great stuff!! Do you have an kinesology/science background or something??
    agreed....I am a physician.....
    I have a Masters in exercise physiology... I wish that more physicians had a better understanding of Ex.Phys.
    Katie Compton on running and strength training: http://www.youtube.com/watch?v=N4qP3...1D702A&index=3
    Reputation: gjenkins@'s Avatar
    Quote Originally Posted by Andrea138
    So, when you are lifting, when and what kind of riding do you do?
    Quote Originally Posted by strader
    Katies story and reasoning are very interesting.....she also mentioned a unique problem with cramping, which I believe is related to her resistance to do any running or lifting.....it is interesting in that I have the same muscle cramping issue she descibes, which actually isn't a muscle cramp, but more of a myalgia.....triggered by high velocity eccentric loading of the muscle, best example running, and made worse by running downhill....cycling is an all concentric exercise, and some peoples muscles probably type IIA fibers, but no one knows for sure, over adapt to the contentric motion of cycling, in expense for reduced tolerance for eccentric loads to the muscle.......the only thing I have found so far to combat this, is intermittent eccentric loading of the major muscles of cycling,(lunges, running/single leg squats) so as to force the muscle to hold on to some of its eccentrc tolerability characteristics, which is most likely sarcomere number.....only a small percentage of cyclist are bothered by this, but they are out there.....I suspect it is related to the type I to II fiber ratio, and a higher type II ratio probably renders an athlete more susceptible to this phenomenon.......
    exercise phys knowlege I have is largely from my own interest and not specific medical training, but my medical knowledge foundation certainly helps me interpret the exercise phys data !!!
    I lift 2x per week (for about an hour), focusing mainly on legs (squat, front squat, deadlift, lunge, leg press, good morning, RDL). Right now is the typical hypertrophy/endurance lifting- 10-12 reps, 60-75% of 1rm, 1.5 min rest btwn sets. I'll mix up the exercises (and add in some Olympic lifts/plyometrics), cut back on reps, & increase intensity in late Jan/Feb. Once I start racing (somewhere around late March/April), I'll cut back to 1x per week of a maintenance program.
    Riding-wise, right now I'm doing Cyclocross, base/tempo/sweet spot road & off-road rides, and occasionally a group ride on the road. I kinda hate highly structured training, so I just try to get in a little bit of everything during the week.
    Do you give yourself any rest days between a leg workout and a strenuous ride? I always feel like, given proper sleep, diet, and hydration, if I am a sore, then I should be resting.
    Quote Originally Posted by gjenkins@
    http://article.pubs.nrc-cnrc.gc.ca/p...&startPage=355
    you gotta read this article.....
    From a performance perspective, it is
    clear that alternating exercise modes during concurrent training
    reduces the capacity for the simultaneous acquisition of
    hypertrophy and (or) mitochondrial training-induced adaptation
    responses, compared with single-mode training.
    In short, we can't have it all ... as you alluded to earlier in this thread.
    Here's a site featuring Andy Coggan's analysis of how max force plays a role in pedaling a bike, and also a good overview of some strength work that can be done on the bike.
    There is menu bar to the left that has 6 links to other pages, read em all for the complete overview:
    http://home.earthlink.net/~acoggan/misc/id4.html
    I have never lifted weights, my experience has only been with on-the-bike strength training. As part of every base period I will do 7weeks of force work using big gears (46x11 MTB gears, or 53x14 road gears) from a 3mph roll, max effort to accelerate as hard as possible for 12sec. Rest 5min and repeat.. I will do these for up to 2hrs (24reps). The first 3 weeks I do them seated, rest week, the second 3 weeks I do them standing. I feel they do improve my ability to power from a low cadence, which is important in MTB (to me). I also beleive that this improved ability is not just because my legs are better able to exert improved force, but every invloved muscle from the foot to the hands is also trained to help maximize the force and reduce fatigue from High torque efforts.
    In a max force effort, I find that form has a lot to do with it. As well as core and upper body strength. Repeated short surges fatigue my back and body, and these workouts help me to improve those areas.
    Quote Originally Posted by perryr
    This link should get its own thread and a sticky at the top of the forum.
    think of michael rasmussen and andy schleck vs lance armstrong and fabian cancellero.....
    Precisely.
    Exactly one of those guys has won the UCI cross-country world championship.
    Quote Originally Posted by flargle
    Precisely.
    wasn't that Lance on a bmx bike ???
    Precisely.
    Wow, that was a crafty response! The one they call "Chicken".. not much meat on them bones..
    He got caught doping (fyi... that's all)
    Reputation: cattledog04's Avatar
    You also have to consider mitochondrial response to rep range with strength training.
    Formerly of Kent
    Uh, no, he didn't.
    To clarify- He was hiding from doping controls and banned for 2 years. He's been an alleged doper for long before that.
    Blood doping/boosting improves performance in endurance sport.
    That's my point... comparing him to other riders is not exactly apples to apples. Even if he weren't on drugs, comparing a 130 pound climber to diesel engines like Fabian and Tom isn't really that great of an argument for or against weight training.
    Formerly of Kent
    Given that Cancellara produces more than 6w/kg at threshold, I think he's a completely relevant example. Just because he's a bigger guy (still under 180lbs) doesn't mean his training regimen is less applicable to the rest of us.
    blood doping and epo or drugs like it that increase hemoglobin/hematocrit really only make a small difference in an elite cyclist........the single most significant benefit from elevating h/h is the high mountain stages, you have to have the O2 to maintain high power output at altitude.....there are advantages at lower altitude, but not as significant than when up high.....the chicken's doping def helped him have power on the high stages........if you really do your altitude training and or tent exposure right you don't really need epo, its really when you don't get your altitude right that epo can make up for any shortfalls in your preperation......pushing your h/h even higher is very very dangerous for DVT and pulmonary embolus and death......your blood viscosity might be ok at normal hydration, but when dehydrated your hematocrit can rise, to the point of you putting you at serious risk of dvt.......
    Formerly of Kent
    For the layman:
    Your blood becomes so thick that, at lower BPM (sleep), your heart simple cannot force it through your body. And then, you die.
    There are plenty of stories of young Dutch riders on the sauce who were awakened by their team staff each night, and made to perform a series of exercises, that were more or less designed to keep their HR high enough to ward off any complications from high hemotocrits (and poorly conceived programs).
    Which is my point, too. In XC racing you don't need a sprint, the concept of "bridging a gap" is totally different, it's way more of a pure endurance sport than road cycling. So serious XC racers would tend to look toward maximizing sustained power and power-to-weight as their goal rather than maximal strength.
    Now, if a person were silly enough to be interested in doing well in crits, road time trials, etc etc, it may very well be a different story.
    if an individual has a relatively weak one rep max squat or leg press but high aerobic capacity, that individual would benefit from weight training for MTB. for road racing you can be a stick figure as long as you can make power.
    near stall manuevers and technical handling in rocky or difficult terrain separates the needs of MTB riders from pure roadies.
    a dismount/remount through a ridable section will cost you time in most cases.
    i couldnt disagree more........mtb is many microburst and very anerobic....road is largely aerobic with big anerobic attacks at the end......
    Reputation: d-town-3-'s Avatar
    Quote Originally Posted by Berkeley Mike
    agreed, if you have a targeted miles count for each week and dont want to loose riding hrs, do a light ride before u train legs maybe 1- 1.5hrs. This gets the legs warm and ready to lift. Be sure to stretch before ride as well as after the bike ride, do your weight routine and stretch again. The day after, as stated already, do a light recovery ride. Ramp down your watts. This should get your ready for the next days full intensity ride. Also there's no need to go to total failure on your leg exercises. That's not to say have a cupcake workout, but leave something in the tank for the rest of the week. Training goals are best achieved over a long consistent workout plan, theres no rush to jump your weights way up. This will also sacrifice form and overall effectivness of the workout. Do what activates the muscle group most effectively with full range of motion, doing weight you cant handle negates this premise. Most importantly and often overlooked is post exercise recovery. Consume simple carbs and protein immediately following the workout to replenish glycogen stores used during your workout so your fresh for the next day. Get lots of sleep if you can manage it, you dont build muscle during the workout your breaking them down through hypertrophy or breakdown of the muscle. Muscle is built at rest when they begin repairing these worked muscles. Eat and sleep and consistency develops muscle. Good luck sorry for long post
    dt3
    You can encounter incredible anaerobic efforts during the course of a road race... personally, I'm not the world's best sprinter, so I do my best to "thin the herd" during a race in order to better my odds.
    I've found that I "feel" my strength training most either on very steep road climbs and attacks as well as on the near-stall MTB efforts that Whybotherme mentioned. My legs look nice, too
