Results 1 to 11 of 11
    Tire Pressures running Tubed
    To many problems with tubeless so I'm going back to tubes for the rest of the season. Looking for recommended tire pressures for Racing Ralphs 29 x2.25 F&R 170 lbs. rider on FS bike.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Probably around 30 pounds... Depends how hard you are riding.
    I borrowed a Jamis Dakar for a Super D race earlier in the season. 30 pounds felt great in the tires for general trail riding, but as soon as I started the race I wound up with a double flat front + rear.
    Point being, it depends on how hard you ride!
    Raised in a Chicken-Coop by Chickens
    Reputation: JoePAz's Avatar
    May 2012
    I ride with tubes on a 26" HT (160lbs). 26.x2.25 Nobby nic front and rear. 30 psi front and 35 psi rear. Seems work good with good traction and ride, but minimal chance for pinch flats. There is still a risk which is why I don't go under 35 rear.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Reputation: rallymaniac's Avatar
    Oct 2011
    I'm 190+ on 29er IKONs and I found best for me to be 26F and 28R. It's still not the softest but I don't like too soft as the tires get squirmy
    Reputation: serious's Avatar
    Jan 2005
    I still use tubes and generally go 21 front and 24 rear on my rigid SS. In 8 years of racing (with well over 100 races, including many 8 hour solos) I never had a flat. I race at 145 lbs.
    My rides:
    Lynskey Ti Pro29 SL singlespeed
    KHS Team 29
    S-Works Roubaix SL3 Dura Ace
    KHS CX 550 cyclocross
    Reputation: cstem's Avatar
    jscot- You have already seen the myriad of answers here, and that is because there are so many variables. I think your best best is to carry two tubes on your training rides and a small pump. Overinflate your tires a bit and write down what pressure they are.
    Now ride on a course that is similar to your race courses and includes some bit of everything you may encounter. As you are riding take mental notes (or stop and take written) for the first lap. Examples: Rocky section-rear tire bouncing all over. Hardpack mid speed turns front wants to wash out etc. Then lower pressure some, note pressures and try again and FEEL the results.
    Keep doing this over the course of a few rides while also paying attention to your riding style. If you live in a rocky area, and plow over and through rocks instead of slight weaving through them, you will need more pressure than most. Also, if you are a sitter and not a stander on downhills, rough sections etc-you will too.
    I say you should work on your tubeless set up if you are willing to spend the time and maybe a little coin. I have done countless tubeless setups -mostly ghetto and ghetto/retail combos. So I may have some ideas for you. PM me your setup (rim, tape or tubeless convert liner, tire choice, PSI ran when you had problems, FS or HT, riding style (butterfly or bull), sealant used and how much, and issue you are having with the setups. I may not have a direct answer but I may have some suggestions. My personal opinion is that tubeless is the way to go for racing. It is so much quicker to slam a CO2 on, thread a tire plug (or two!) in the hole and let the remaining sealant do the work while you pedal away. I know not all flats are that easy, but I would bet a good 80% are.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    Reputation: targnik's Avatar
    Jan 2014
    220lbs (closer to 228lbs post Xmas)... 35 rear, 30 front
    Sent from my Kin[G]_Pad ™
    "Mountain biking: the under-rated and drug-free antidepressant"
    What was the issue with tubless.
    Im curious about the tubeless issues as well.
    2 yrs of riding/racing tubeless Ive yet to have a flat.
    On 3 years myself with one flat. 30psi in my tires feels like concrete afrer running tu less.
    Jan 2014
    As I'm getting more AM style tires... The psi is dropping, now around 30 out back and mid 20's up front
  1. Replies: 33
    Last Post: 08-13-2013, 07:42 AM
  2. Survey - Float shock owners, what pressures are you running?
    By Steve VS in forum Shocks and Suspension
    Last Post: 04-22-2013, 08:07 AM
  3. Need advice on a rear racing tire (tubed).
    By Eirikur in forum 29er Bikes
    Last Post: 04-17-2013, 11:57 AM
  4. Need recommendations for tire and tire pressures for kids mtn bike
    By stom_m3 in forum Families and Riding with Kids
    Last Post: 05-03-2012, 10:54 PM
  5. Replies: 5
    Last Post: 03-09-2011, 12:16 PM
