Results 1 to 13 of 13
    Arrrghhh!!!
    Reputation: insighter's Avatar
    Nov 2006
    Theoretical question regarding water bottle weight and time
    I will be riding in a couple of races this year that vary in length between 20 and 60 miles. All are well supported and I could ride with either one or two bottles of water on my bike. I ride mid-pack expert.
    My question is this: If I rode with one 22 oz bottle (approx 1 1/2 pounds) instead of two bottles, how much of an impact would this have on my time?
    The great use of life is to spend it for something that will outlast it.
    William James
    Reputation: Fakie1999's Avatar
    Feb 2010
    Not enough to worry about it!
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    If you drop it you are toaster. 2 small bottles gives you a little more security if you are a clutz like me. And it give you more ammo to throw like a green shell in MarioKart.
    Raised in a Chicken-Coop by Chickens
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Two bottles, use for nutrition on longer races.
    Jun 2012
    “Every extra pound you carry above your ideal weight makes you 15-20 seconds slower for each mile of a climb” — May 12′ Issue of Bicycling Magazine
    If well supported, I would go with multiple 'partially filled bottles' as per below.
    I know it may be kind of 'extreme' but it doesn't make sense to me to carve ounces/grams off of a bike and then carry around extra fluid. I believe 12 oz of water weighs .78 lbs or 355 grams
    On another note:
    Even on a relatively short race, I approximate how much I will drink (heat, etc). And then split the difference between two small bottles.
    IOW - For a 1.5 hr CX race I will split one large bottle into two small ones, in case I drop one (never have though) - less fluid in bottle makes it easier to handle, etc. (yes, I know I am carrying an extra water bottle on bike along with an extra cage)
    Arrrghhh!!!
    Nov 2006
    Great responses; thanks all. That answers it for me.
    William James
    Just train with both bottles. Its not that big of a deal, your over thinking it.
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by scottz123 View Post
    Every mile of vertical? If so, thats not too much. Ill continue to not sweat it.
    LMN
    LMN is offline
    One pound at a VAM of 1200 requires about an extra 1.5 watts.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    Arrrghhh!!!
    Nov 2006
    Quote Originally Posted by LMN View Post
    That is beyond my pea-sized brain. What does this mean to a layperson?
    William James
    LMN
    LMN is offline
    Quote Originally Posted by insighter View Post
    Sorry, I was rather brief wasn't I.
    VAM is vertical ascent rate per hour. For reference Armstrong at his peak did long climbs at 1700ish. Nowadays grand tour riders climb at 1500ish. A good Cat 1 mountain biker might be able to climb at a VAM of 1200 in a race.
    To figure out the extra power required to climb at a particular VAM with a weight gain use the formula:
    Power = (VAM * mass in KG * 9.8)/3600.
    Interestingly using this formula you can see that faster you climb the more important weight is.
    Arrrghhh!!!
    Nov 2006
    This is very interesting! So if I am riding in a race and produce 275 watts and weigh 86 kg all kitted up, this would result in a VAM of 1174. If I weigh 87, the VAM goes down to 1160. Do I have this right?
    William James
    LMN
    LMN is offline
    Yes you have it right. At least theoretically right.
    The problem with the equation I gave is when you riding gravity isn't the only force you are working against. You have wind resistance, and rolling resistance too. You also have to consider thatk, particularly on a MTB bike, you are alway accelerating and decelerating.
    Wind resistance and rolling resistance can be modeled (and analyticcycling.com does). However, I don't think anybody has a clear grasp on frequency and magnitude of the accelerations in mountain biking. This makes it really hard to accurately predict the effect of a weight increase.
  1. Replies: 4
    Last Post: 11-06-2012, 04:02 PM
  2. Water bottle mounts
    By 1SPD in forum Frame Building
    Last Post: 05-16-2012, 05:01 PM
  3. Strictly theoretical poach question
    By sirsam84 in forum California - Socal
    Last Post: 05-13-2012, 05:37 PM
  4. camelbak weight vs water bottle
    By stokerslo in forum Weight Weenies
    Last Post: 02-11-2012, 05:06 PM
  5. Replies: 2
    Last Post: 01-01-2012, 07:57 PM
