Results 1 to 39 of 39
    Super Fly FS 9.9 vs. Jet9 RDO vs. S Works Epic
    I "tried" out a xc cat 3 race last year and was hooked after the first 3miles. Sold my over sized trail bike to build an Epic carbon. That bike was great but ended up selling the frame set for more than I paid for it 2 weeks ago. Needless to say I'm on the hunt for a great bike. Problem is no one in my area of iL carries any of these top shelf bikes. Trying to decide which route to take. Think I've settled on FS. My build out would be xx1 cranks with full xtr components and Stans Race Gold wheel set. My epic was just over 24lbs with pedals. A few pound either way would be fine.
    Thanks for the help
    Reputation: 29ger's Avatar
    Jan 2011
    I have no complaints on my Jet9 RDO except for rock chips in the clearcoat. I see quite a few of those out here in UT being race, but not much of the other two. I haven't ridden the other two though.
    Endurance Junkie
    Quote Originally Posted by rayztoyz View Post
    Thanks for the help
    I would go with XX1 over XTR. I can't imagine buying a new bike with top end components that isn't 1x11.
    Mar 2012
    Where in IL are you located? I would go with the Superfly, but I am bit biased.
    Really liked my old Epic. It was a solid bike. The Trek would be a watered down Project One build. I already own everything to build the bike the way I would like it. 1x11 was tempting...but I already own full XTR that I purchased new last August. It has maybe 100 miles on it...maybe. I'm located in northern IL....Oswego area.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Spokes in Wheaton usually keeps a few S-Works Epics and SJ HTs in stock. Give them a call and see what they have.
    Death from Below.
    Formerly of Kent
    I'm trying to imagine a place where I couldn't use a 1x11, and I'm stumped.
    Death from Below.
    Endurance Junkie
    Quote Originally Posted by Le Duke View Post
    +1. Especially in IL, where there are no mountains...
    Quote Originally Posted by Flucod View Post
    IMO 1x11 is pretty useless with our racing. Too much varied terrain, I run full XTR and would never go back to the single front ring.
    Have you ever used 1x11? For an endurance racer (NUE 100milers) its the cats ass.
    I moved 1x10 to 1x11 and you get a better range of gearing for climbing and flats.
    My sworks is a smig over 21 w/ pedals and cages. Once the SRM PM gets here it will add a small amount. For what its worth I'm Cat 2.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Endurance Junkie
    Quote Originally Posted by irishpitbull View Post
    He was saying the exact same thing as you. It was Flucod that was trashing 1x11...
    Quote Originally Posted by skibum1321 View Post
    My bad I quoted the wrong post. Thanks and fixed.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    My point, I guess, was that I already own full XTR trail with the XX1 crank/chain ring. Everything has less than 100 miles. So replacing the group set at this point would be more money. I didn't say it wasn't worth it nor did I say it's not needed. I was trying to get some opinions on fame sets...not group sets.
    Sorry if my original post was misleading.
    Ended up purchasing a left over 2013 S-Works Epic frame set.
    Endurance Junkie
    No, someone else said it wasn't worth it. Totally understand using what you've got...
    Reputation: jnails's Avatar
    I raced a Trek Superfly 100 for 2 seasons and liked the bike - it was my first full suspension 29er. Thought it was great actually, that is, until I rode an epic. I realized really quickly that the Trek was just a barge of a bike that handles like a tank. The epic with the short chainstays handled so much better. Just rips around turns, very flickable, and (even though this may sound weird it helps in riding stuff smooth)easy to wheelie drop/jump rooty or rocky sections. The Epic was a little firmer ride - something about the brain just doesn't let that bike get plush, but hey it's an XC race bike after all. That's really the only 2 big differences between the Epic and Superfly. Way better handling with the Epic versus a plusher ride on the Superfly. Never ridden a Jet, so can't comment on that. Good luck with your decision.
    Jan 2011
    "Epic and Superfly both good bikes but the RDO is way to heavy for a race bike."
    Yeah, that 1/3 of a lb is a real killer.
    Don't be a sheep
    Sep 2004
    Quote Originally Posted by 29ger View Post
    Epic large framset is 5.0lbs
    Jet 9 Rdo and Superfly are just under 5 lbs in large.
    FYI Santa. Cruz tallboy 2 is same as Epic sworks, 5 lbs for a large.
    "Do not touch the trim"
    Rode a non carbon Tall Boy for about 50 trail miles over a weekend. Great bike. But no real support in my area.
    Jan 2011
    Quote Originally Posted by Rivet View Post
    My large Jet 9 RDO actually came in just over 5lb. That's where I was getting the extra 1/3 lb compared to a 5lb Epic. But it rides good for a boat anchor!
    LOL no. The RDO is coming a bit heavier than the Sworks. A teamate just purchased one.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    No reason you couldn't run a 1x10 setup with the XTR and an XX1 style front ring. It would be more than adequate in IL for racing (and most places).
    As mentioned elsewhere, the RDO frame is in the same weight category as an Epic... so don't fret that too much.
    I'm partial to the Epic, but I have several Niners (all HT though) and they are a great company. I don't care for the cable routing on the RDO though. I also think the RDO is a bit dated at this point. The design hasn't been updated in a LONG time and it's chain stays are on the long side. As someone who rides and races in the midwest, I'm not a fan of long chain stay bikes. That's why I picked up an Epic WC to try out this year
    Air 9 RDO would have been a better choice!
    Quote Originally Posted by rwitte View Post
    Yeah if you want to bring a knife to a gun fight.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Inside thing...not to worry.
    As for this particular topic...I myself am giving the SF100 a try for next season...partially a team thing. Owned a first generation Jet 9 RDO and it was a good riding bike, but had a defect that eventually got warrantied. Ended up selling that to a buddy and went back to a hardtail. Now back the other way this year...seem to be stuck in that FS to HT to FS etc. cycle. I wanted to like the Epics, even demoed a couple last Fall, but just did not get on with them at all. Other than the sizes not working for me, the concept just doesn't seem right. Folks who swear by it say it's the best of 2 worlds, but it seems like the worst of 2 worlds to me. Different strokes...
    Formerly of Kent
    I'll be racing XX1 in NY, VA, NC, IL, WI, UT, CO, and OR this year...
    Death from Below.
    Formerly of Kent
    I'm from IL. A HT is the weapon of choice for most Midwest trails.
    Death from Below.
    DLd
    DLd is offline
    Feb 2005
    Re: Super Fly FS 9.9 vs. Jet9 RDO vs. S Works Epic
    Not tall enough gear and not low enough gear with 1x11. If you like use it. Not for me, not enough at each end.
    Gear chart using Gear Inches
    Sheldon Brown's Bicycle Gear Calculator
    You're giving up about one shift at either end. If you're weak enough to require a lower gear than your chainring choice allows, then you're probably not strong enough to push a higher gear than the one available at your top end in a xc race situation anyway.
    Sent from my HTC One using Tapatalk
    Fall is here. Woo-hoo!
    Don't be a sheep
    Sep 2004
    This is why I went 2x10 instead of 1x11 on my latest race bike. Plus I heard of people having to switch out front chain rings at the races to get the gearing they need. Screw that.
    Jan 2009
    Yea, only have won 20 Cat 1 races. Maybe I would make the Olympics if I switched to 1x11.
    You have no idea what you are talking about, do you ride where I do? 4,000 ft climbs at 25% grade then 6 miles on a long doubletrack descent? Bring your 1 x 11 so I beat you ignorant butt up and down!
    Go ahead and respond how awesome you are. What class do you race? Pathetic. You want to attack me? Bring it, PUNK!
    I don't think he said anything that bad? I ride a 2x10 and like it, and I race Cat 1, albeit slowly. It's all about what works for you and your riding style/fitness.
    I'd run 1x11 but until I can afford to justify the expense I'll run my XTR. I had XX on a bike and kept breaking the shift levers. SRAM was awesome about taking care of me. With Shimano going to 11spd this year on Ultegra and Dura Ace it's just a matter of time until the have a mtb 11spd group too. (I'm hoping anyway.)
    Formerly of Kent
    Show me these 6 mile, 25% climbs on Strava.
    Oh, and I'll be getting my "Pro" license back this year. I took a four year hiatus to jump out of airplanes and kill people in AFG.
    Death from Below.
    DLd
    DLd is offline
    Feb 2005
    All that work and then not even a singletrack descent. I can see why you're so angry. I empathize with you.
    I race Cat 1. Currently on 1x10 36T/11-36. My new bike will have 1x11. I'm not sure if I'll use the 10 or 42, but surprisingly enough, the cassette is lighter than an 11-36. Ride what you want. I wasn't attacking you specifically btw, just saying in general for most people (myself included) if you can't push a 42T on the climbs, then you're probably not doing a sustained 25mph+ on the flats. Of course if all of your downhills are doubletrack, then I could see maybe you need the bigger gears...
    Thank you for your service! Congrats on your Pro license. I'll be racing Cat3 this season. Hoping do well enough to take on the challenge of Cat2 next year as I turn 40.
    DLd
    DLd is offline
    Feb 2005
    You can do it. Turning 40 was part of my impetus to start racing again. "I will not go quietly into the dark." Now with a six-pack at 43. Who would'a thunk it?
    Must let me know when you'll be in OR.
    Reputation: brentos's Avatar
    What race do you have planned for UT?
    Brent
  1. Replies: 8
    Last Post: 01-10-2014, 08:29 PM
  2. Replies: 8
    Last Post: 02-26-2013, 05:32 AM
  3. Jet9 RDO vs Swork Epic vs Scalpel 1
    By torque29er in forum Niner Bikes
    Last Post: 03-25-2012, 11:47 PM
  4. Jet9 RDO vs Swork Epic vs Scalpel 1
    By torque29er in forum Cannondale
    Last Post: 03-02-2012, 10:24 PM
  5. 2010 S-Works Epic (26) to 2012 Epic Expert 29er
    By MrEconomics in forum Specialized
    Last Post: 11-21-2011, 11:00 AM
