FAT BIKES
WINTER APPAREL
TRAINERS
Results 1 to 6 of 6
    Reputation: Gabe3's Avatar
    seat post bottle cage that won't eject
    I need to start carrying a second bottle. I bought this topeak cagemount awhile back for my seat post and havn't used it yet: Topeak® Cycling Accessories ? Products - CageMount
    whats a cage that won't eject? I've heard specialized rib. also getting one of those metal cages and bending it(heard this will eventually crack bottle). also heard of a cage bontrager makes that has a knob on it that tightens bottle but I can't find it. i dont really want to spend more than $10 so a metal cage may be the only option.
    are the side loader cages less prone to ejection?
    curious to hear anything here so doing a quick bump - i gave up and just started to run a minimalist hydration pack/camelback, especially with lame bottle clearance on my Epic frame with the rear shock. I lose a ton of fluids. Plus dealing with bottles while redlining it sucks.
    But so do packs, no matter how small (heat, adding to back pain, etc)
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    ummm
    no an aluminum cage being bent won't crack a water bottle unless you
    are using a crappy bottle
    best cage/bottle combo are camelbak podium bottles and
    a plastic cage like this. Bike24 - Ghost Water Bottle Cage Plastic
    that bottle will not come out unless you want it out.
    but it needs some vertical clearance. on a seat tube I use aluminum
    cages and bend them tight...works great and a normal bike waterbottle
    like camelbak will not crack, there is no way they will crack.
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Specialized Rib Cage. Gorilla Cage.
    I've seen some peeps use a large rubber band (in various fashions) to hold the bottle in the cage. Might be your cheapest/most reliable option.
    Reputation: Harryman's Avatar
    I've used these for probably over 20 years, there might be better out there by now, but I think I've broken one in all that time and can't ever remember launching a bottle. Granted, I mainly have them on road bikes these days, but in the precamelback era, they were the only cage I found that worked.
    https://www.performancebike.com/bike...iew#reviewsTab
  1. Replies: 1
    Last Post: 02-05-2015, 12:12 PM
  2. Replies: 10
    Last Post: 02-24-2014, 12:27 PM
  3. Replies: 0
    Last Post: 06-05-2013, 08:40 AM
  4. Seat post water bottle mount
    By strandog in forum XC Racing and Training
    Last Post: 11-19-2011, 05:36 PM
  5. Replies: 17
    Last Post: 11-02-2011, 10:16 PM
Follow MTBR on Facebook
