Results 1 to 5 of 5
    Reputation: nathanbal's Avatar
    Powertap SL+ on a 142x12 frame?
    Will be getting a new frame soon and want to see whether my powertap hub will work on it or not - the new frame will have a 142x12 rear end. Will I have any issues?
    Reputation: WR304's Avatar
    Quote Originally Posted by nathanbal View Post
    You'll have the issue that the Powertap hub is designed for a standard 135mm width rear dropout. It won't work with a 142x12mm thru axle rear dropout.
    In order to make it work you would need someone to machine you a new axle and endcaps for the Powertap hub with the correct dimensions.
    Quote Originally Posted by WR304 View Post
    thanks for that. what a PITA !!!!
    Reputation: sprocketjockey9's Avatar
    Get in touch with Wheelbuilder.com
    They are working on an adapter to make it fit, last I knew it was in pre-production and were awaiting parts from the machine shop.
    will do. thanks for the tip!
  1. 142x12 kit arrived. Am I missing something?
    By matmattmatthew in forum Yeti
    Last Post: 06-23-2011, 10:35 AM
  2. Wheel Upgrade to 142x12
    By cllemke in forum Yeti
    Last Post: 06-07-2011, 07:17 AM
  3. Anyone have a 142x12 QR in stock?
    By blantonator in forum Wheels and Tires
    Last Post: 05-04-2011, 11:13 AM
  4. Hadley make a 142X12 kit
    By sammysmc in forum Wheels and Tires
    Last Post: 01-11-2011, 03:39 PM
  5. 142x12 Hubs
    By Lelandjt in forum Downhill - Freeride
    Last Post: 10-22-2010, 02:41 PM
