Results 1 to 38 of 38
    Jan 2009
    Power people Steady power HR Rise
    Question: Should keep following the power number even though the heart rate rose steeply at the end of the endurance zone workout? It is better to hold to the power zone and ignore heart rate or back off the power to stay in heart rate zone?
    I am new to power training although I have been training with heart rate for years. I am just recently finding how much my power would fall off at the end of a workout. Any experience with this would be welcome.
    Reputation: WR304's Avatar
    Power people
    This is one of the problems with using a heart rate monitor for pacing. Changes in the speed that your heart is beating at don't always track exactly with effort. A heart rate monitor measures how fast your heart is beating. It doesn't measure how hard you're working. There are many different factors that can affect how fast or slow your heart beats on any given day (heat, fatigue, illness, caffeine etc) .
    http://running.competitor.com/2012/0...aining_47287/2
    For the same power output your exercise heart rate can vary from day to day and also vary across the course of a training session, even when you're maintaining a constant power output.
    Where you maintain a constant power output and perceived exertion throughout the session, but your heart rate continues to climb, you're most likely experiencing cardiac drift. Essentially your heart rate monitor is lying to you about how hard you're trying.
    http://running.competitor.com/2012/0...aining_48317/1
    As you have a power meter I'd follow that for pacing and stick to the target power zones that you're aiming for throughout the ride.
    Reputation: jcm01's Avatar
    Oct 2011
    Quote Originally Posted by WR304 View Post
    This. That is why power meters are so helpful and training with HR only can be so challenging.
    18 Focus Raven Max
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Jan 2009
    Awesome! I think I will use HR with a grain of salt or not at all. The concept that my heart rate can change at a fixed output within a workout do to body heat, dehydration, that 5 hr energy I popped before seems quite likely.
    Power people
    If you're taking things like 5hr energy, which are high in caffeine, then that's going to have an effect on how fast your heart beats during exercise, resulting in an elevated heart rate. For pacing in those circumstances you're generally better off just using power.
    http://www.forbes.com/sites/davidkro...-energy-drink/
    "It’s important to note that the actual caffeine content in 5-Hour Energy drinks is not listed on the label, and is not published by the company, which simply states that a 5-hour energy shot contains “about as much caffeine as a cup of premium coffee” while an extra-strength 5-Hour Energy contains “about as much caffeine as 12-ounces of coffee.”
    Consumer Reports once estimated the caffeine content of original 5-Hour Energy at 207 mg; the Center for Science in the Public Interest estimated it at 215 mg. So here are the caffeine data on these products:
    1 5-Hour Energy Drink: Approx 207-215 mg caffeine
    1 Monster Energy Drink: 10 mg per ounce, or 160 mg per 16-ounce can
    1 12-ounce cup of name-brand brewed coffee: 230 mg (Courtesy of Caribou Coffee.)
    Forbes
    http://www.forbes.com/sites/melanieh...5-hour-energy/
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Cardiac drift.
    Death from Below.
    Reputation: xterrafreak's Avatar
    Another term used to explain this issue is "aerobic decoupling". If your HR drifts from your power more than 5% over the course of the workout it's a clear indication that your aerobic conditioning needs some work.
    Are You Fit? Aerobic Endurance and Decoupling | TrainingPeaks
    BTW, if you're using power software it will tell you exactly what your aerobic decoupling % is. If you don't have any software I recommend Golden Cheetah It's free and is an excellent training tool.
    LMN
    LMN is offline
    Or is this the problem with using power meters for pacing?
    It can be argued that your heart rate is a measure of how hard you are working. You experience cardiac drift because it is getting harder to maintain that power output. To put it terms of FTP, your FTP after 3hrs of continuous riding is likely lower then your FTP when you are fresh. Given this, is it appropriate to ride at the same power output for the whole ride?
    Personally I think heart rate needs to be combined with power to effectively estimate training load. Particularly when we look at MTBing, power meters on mountain bikes do not reflect all the work a rider does.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    Re: Power people Steady power HR Rise
    For base training Friel recommends using HR and once the build period starts then use PWR. The problem is most cyclists don't do a true base period (LSD), choosing to do more TH and SST work instead, in these circumstances power is the most reliable metric. IF you're using PWR for an LSD/endurance ride your goal wattage would be in zone 2-3, so, 56%-90% of your FTP.
    Sent from my PC36100 using Tapatalk 2
    Jun 2012
    I made the jump to training with power zones instead of HR zones about six weeks, and definitely it opened up my eyes to how much HR can be influenced by stuff. Power I do the same amount of work, where I can physically control HR and not really get the workout I needing. It was best the change I could've made for my training!
    Endurance Junkie
    It's pretty tough to do a "true base period" in the Northern 1/2 of the US where we have snow on the ground for most of the winter. Therefore intensity takes its place because we would all go crazy doing volume on the trainer.
    Not in agreement with this. Your base should not include "crazy volume" anyway. Winter training (Cat 2) for me is 7-8 hrs max a week. With a mix of HIT and Tempo work.
    Long base mile training rides(Junk Miles) are old school and proven to be inefficient.
    Quote Originally Posted by skibum1321 View Post
    18 Focus Raven Max
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Endurance Junkie
    Quote Originally Posted by irishpitbull View Post
    I don't agree with the loads of miles approach either. That was a response to a previous post that talked about a "true base period", which typically means a bunch of LSD. My winter is a mix of intensity and Z2 but most weeks are probably 8-10 hrs.
    LMN
    LMN is offline
    That is a pretty strong statement there. Particularly when you consider that most racers are doing long base miles right now.
    If you have the time to put them in base miles are critical, probably the most critical part of your training. It is that work that allows you to raise you threshold power to new levels.
    I would actually say that building a big strong base through long steady miles is a proven approach. It has obvious limitations for many people; time and weather being the most prominent. But that doesn't change the fact that when it is done it is high effective.
    Quote Originally Posted by LMN View Post
    Quality base are important yes. Riding around in Z2 for hours on end is "junk". During the base period you are developing Muscular Endurance. While is can do that in Z2, it very slow and not the most efficient way of obtaining a base. Chunk rides with Threshold sets should be used if your base has suffered due to lack of training.
    Also your FTP is increased more with "Sweet Spot" and "Tempo" rides per Allen Hunter and these zones should be your base/foundation for your training.
    Quality of training miles will beat quantity of miles any day.
    You should really pick up "Training and Racing with a Power Meter".
    18 Focus Raven Max
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Reputation: chomxxo's Avatar
    Quote Originally Posted by xterrafreak View Post
    Quality base are important yes. Riding around in Z2 for hours on end is "junk"..
    Call me a Zone 2 connoisseur. I have a pretty narrowly defined Zone 2 HR and power range. In my case currently, it's 130-144bpm and 185-240 watts, with a 53-194 HR range and a 331w FTP. My mountain bike and touring bike are not going to have a power meter so it's important for me to understand zones under both systems.
    I focus on keeping the workout in those zones during base, which I can't say I'm always able to stay within depending upon the ride, but with the help of alerts on my Garmin, it's getting more effective. You can do sprints up short rollers and still stay below 150bpm. It's not difficult for me at all to fall below 67% of max HR several hours into a ride, while still going at a pretty fun pace. I do have to attribute that to miles and miles of "junk" which will hopefully start to be of use in the NUE races
    Quote Originally Posted by chomxxo View Post
    Call me a Zone 2 connoisseur; ) I have a pretty narrowly defined Zone 2 HR and power range. In my case currently, it's 130-144bpm and 185-240 watts, with a 53-194 HR range and a 331w FTP. My mountain bike and touring bike is not going to have a power meter so it's important for me to understand zones under both systems.
    I focus on keeping the workout in those zones during base, which I can't say I'm always able to stay within depending upon the ride, but with the help of alerts on my Garmin, it's getting more effective. You can do sprints up short rollers and still stay below 150bpm. It's not difficult for me at all to fall below 67% of max HR well-into a ride, while still going at a pretty fun pace. I do have to attribute that to miles and miles of "junk" which will hopefully start to be of use in the NUE races
    Honestly that is awesome that it works for you. Our Z2 range is very similar, now i'm pretty interested in your approach. How many hours a week do you put in Z2?
    I also race NUE. I would interested in seeing what your zone distribution is during the race.
    18 Focus Raven Max
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    I wish I had the time and warm weather to do a TRUE base. But I'm stuck on the rollers all winter with the occasional outdoor long ride when temps are 40 and above which isn't very often this year.
    Getting back to the OP's question. Power is very effective at higher intensities because you can properly hit the exact intensity needed for a given interval. With an endurance ride its nice to just ride and enjoy it without stressing about power numbers, just keep your intensity in check, monitor your HR and after the ride check your power averages.
    Reputation: jrastories's Avatar
    Definitely looks like cardiac drift, but more so then just drift caused by dehydration and vaso dilation. I think the OP is working pretty hard and the increase in HR is to combat the production of lactic acid. I agree with all those who suggest that the intensity is too high for the level of fitness.
    As far as LSD and interval training during a base phase I tend to agree with LMN mostly based on his direct observations of a very high level of competition. Put in the work and get those miles in. However I find it quite boring to just do that so I add in a little bit of intervals just to keep things interesting and so I don't get board.
    Rocky Element
    My Attempt at a Blog
    Quote Originally Posted by Drider85 View Post
    Yeah,
    I took a seminar from Dr Stacy Sims of Osomo nutrition a while back. I remember her "number" on caffeine was 25-50 mg per hr depending on tolerance and your weight. After that, then benefits diminish and the drawbacks mount
    So, that 5 hr energy may not have been the best choice. Maybe a Nuun kola nut, or lemon tea might have been better. They have 25 mg per tablet.
    Good luck with the power training.
    Lead by my Lefty............... right down the trail, no brakes.
    LMN
    LMN is offline
    I have read "Racing and training with power a meter." It is a good read with a lot of excellent information. I don't 100% agree with your interpretation of information in the book.
    You are right, for any single unit of training time your FTP is increased more with "Sweet Spot" and "Tempo." But that is only for a single workout in isolation. It is difficult to string together multiple workouts or multiple weeks of workouts if you training is nothing more than a steady diet of intensity workouts.
    The other thing to consider is progression. People respond remarkably well to training, after 3-6 weeks you have experienced nearly all the adaptations you are going to get from a particularly training method. If your training right now consists primarily of intensity work how are you going to change it in March and April to keep on improving?
    As I had mentioned earlier, most successful racers spend their winters doing LSD. If you read more work by Hunter Allen you will see that he too includes lots of LSD work in his programs. Actually if you read "racing and training with a power meter" you will see that he includes it in there.
    The key thing is your training needs to overload you. If you only have 8 hours to train then, depending on your level, you might need to add intensity to achieve overload. But if you have a bit more time then the intensity isn't necessary.
    For instance I have time to train about 15hrs a week. Right now I don't need to hit 15hrs to achieve overload, by the end of a 12hr week made up primarily of zone 2 work I am pretty well done. In a couple of weeks I will be hitting that 15hr mark. After that that point to achieve overload I will add intensity.
    LMN
    LMN is offline
    Do you XC ski?
    A lot of base work can be done on skis. In my neck of the woods winters are pretty long and snowy. My winter base is probably 70% ski, 30% trainer.
    It takes a while to build up to but you can log some big days on skis. One of the guys in town did a cool 100km ski yesterday.
    So I wouldn't do that, as better-stated by others. BTW have you checked out the ingredients of 5 Hour Energy? The B-vitamins megadose is probably not dangerous, but just not useful.
    Getting back to your OP, it looks like your intent was to hold onto about 225w for 1:30. You were able to stay within HR Zone 2ish for about 30 minutes at that wattage, and then your heart rate jumped to Zone 3. At :45 you started getting pretty winded and moved into Zone 4 at about 160bpm. Looks like you took a breather for a minute at :50.
    After resumption, the heart rate went back up and continued to steadily climb to 175bpm near the finish.
    So, based upon this workout, 225w is going to be too high for an endurance Zone 2 workout. I'd suggest trying the opposite: Start pedaling for 1:30 and hold onto 200w or so until your heart rate gets back up to 145bpm. Then back off a little to whatever wattage keeps it from going above that but not too far below.
    Jan 2009
    My goal was to ride 175 to 185w for the first 30min and 190 to 209w for the remainder. It might be that I got carried away and let the wattage climb. Overall the average wattage for the ride was 195.
    Oct 2011
    Quote Originally Posted by sooshee View Post
    What I experienced as well!
    Oct 2011
    Explained very well. Thank you.
    I agree with everything you have said. I'm currently using Hunter's Advanced base program and I will be switching to his in-season plan. Currently the plan calls for a LSD type workout once a week up to week 8 (11 weeks of base) But these LSD's are Tempo intervals. Using the Z2 as recovery.
    Sorry OP for hijacking your thread. I had some Cardiovascular drift myself hydration was my issue, I needed to increase the electrolytes in my hydration mix. As this drift occurred toward the end of your workout, I would look in that direction 1st.
    18 Focus Raven Max
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Oct 2013
    Here's a little video which is worth a look. It is about "polarised training", and the varying amounts of times and sessions done in various zones.
    Definitives should not be drawn from this alone but there are trends and good information, especially in relation to some of the studies towards the end.
    Training periodization. Deep-root cultural heritage and innovative paradigms (2013) - Managing the distribution of training intensity: the polarized model
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Awesome info in this thread, thanks guys. One question though....when you are referring to z2 and tempo, are you referring to Allen zones or friel zones? They are different....right??
    That makes sense. That spike in heart rate for the final five minutes or so was more than just cardiac drift, as noted by jrastories. You probably lifted the pace to finish which would explain the sharp heart rate increase.
    When looking at power data it can be quite jumpy and hard to make out trends to begin with. The scaling and smoothing applied makes a big difference to how easy it is to interpret power graphs. The Garmin Connect website being one of the worst for that. For anything more than a cursory overview the Garmin Connect graph view doesn't tell you much and can be misleading, as seen here.
    For a program that allows you to change scales and make the data presentation meaningful the only real option is WKO+ 3.0 currently (WKO 4 is supposed to be out soon so I'd wait for that).
    If you're going to be using Garmin Connect my suggestion would be to add plenty of manual laps (by pressing the Lap Button on your Garmin Edge whilst riding). For the ride in your first post for example you could press the lap button at thirty minute intervals so that you have the averages for the opening section, the beginning and end of the second section listed as individual laps in the Garmin Connect. Summary screen. At least then you can read the numbers off to get an idea of how your power output and heart rate changed during the ride.
    I think it really depends on what you're doing during that 3 hours of continuous riding. Riding along at a steady pace (the lower end of the Zone 2 Endurance power zone (Coggan power levels)) isn't really that taxing. Sure, it catches up with you at some point if you keep riding indefinitely but three hours of that is hardly apocalyptic. When fully fit it's not as though after three hours of Zone 2 Endurance power zone riding your legs are going to be even slightly cooked. Three hours on the rivet or three hours of constant hard sprints is a different matter.
    What I used to do when healthy was go out for a training ride late afternoon after work and do three or four hours by myself before meeting up with the local chaingang or riding a club ten time trial on the way home. That was a good way of getting some intense effort in after having already done several hours to begin with, just like you would have to do when road racing.
    So out on my ride today I was thinking about this oh the joys of being out on a zone 2 ride for 2 hours. (ya I'm still just starting the season so slowly ramping things up). My conclusion is use as many tools as you have at your disposal. Power, HR and even RPE, They all have their merits and have all been proven at one time or another. The reason power is such a powerful tool is because it is linearly related to VO2 more so then HR (HR is effected by lots of things as stated earlier) plus HR tends to level off when you approach VO2 max. And Further the Borge scale of RPE has been proven many times to correlate to HR in many studies across many disciplines.
    I believe that you need to use all of these tools to guide and personalize your training. So if you believe that you should be in one power zone but your HR is telling you different and how hard you feel like you are working feels more like the power zone believe that.If you feel like you are working harder then what the power meter is saying believe your HR and bring the power zone down a little.
    I will end this with saying I have never trained or even ridden with a power meter. But I feel like I do have a working knowledge of exercise physiology. My HR has come in as a validation a few times when I have gone out for an interval workout and I felt like I was working really hard but my speed and HR were way down. From this information I decided to abandon the intervals and to finish the ride as a very slow recovery ride because that is what I needed. So using the tools I had I was able to tailor that specific workout to my current needs.
    Rocky Element
    Here's an FTP test that I did back in November 2013 when my Powertap hub was still working for comparison. I uploaded the Garmin Edge 500 .fit file to the Garmin Connect website so you can see how the graph looks like alongside the exact same power file with smoothing and adjusted scales in WKO+ 3.0.
    Garmin Connect website:
    WKO+ 3.0:
    Reputation: sbsbiker's Avatar
    Great info again. Thanks
    Do you XC ski?
    I've given it some serious thought and I'm sure I would really enjoy it. There are lots of places fairly close to home where I could go and lots of my fellow MTBers XC ski. I'm really time crunched (4 kids) and I'd have to exchange saddle time for ski time. Does the fitness cross over? How much does a decent set of XC ski's cost?
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    I picked up a decent (I think) entry level skate package this fall for about 375. Bought online from someplace in MI IIRC. Weather has been much more bike friendly than ski friendly so far in WA, so still unused this season.
    If it's not powered solely by you, it's a motorcycle.
    Worshiping at the Church of Singletrack since 1993.
  1. Calculating power and power meter operation
    By dstorjoh in forum XC Racing and Training
    Last Post: 07-23-2012, 08:35 AM
  2. Replies: 13
    Last Post: 03-05-2012, 07:38 AM
  3. Do Power Meters Really Measure Power?
    By bikerbert in forum XC Racing and Training
    Last Post: 10-26-2011, 10:13 AM
  4. Frontier Airlines - Power to the People!
    By CharacterZero in forum General Discussion
    Last Post: 08-13-2011, 06:58 AM
  5. Shifting ON power/climb vs. OFF power/road (29er)
    By brmena101 in forum 29er Bikes
    Last Post: 04-10-2011, 01:32 PM
