Results 1 to 9 of 9
    Religion = Non-thinking
    Reputation: louisssss's Avatar
    Looking for my first trainer
    Its getting cold, but i still love to bike. Whats a good trainer that i can use as "entry-level" so i can get keep my legs in shape till the spring?
    budget is: $200
    P.S. i only ride recreationally, no racing. if that matters
    RH SL Pro
    Reputation: iWiLRiDe's Avatar
    I'd go with either a magnetic or fluid trainer. Fluids tend to be quieter, but the magnetic resistance is a really good work out. I'd stay away from rollers if you're a beginner as it takes a lot of paying attention to get used to them.
    What do u mean by rollers and paying attention? i am truly a beginner and have only skimmed some websites that sell trainers.
    whats the diff between magnetic and fluid?
    can i use the trainer with 26" bikes with knobby tires?
    i think this one is decent, right? http://www.jensonusa.com/store/produ...a+Trainer.aspx
    RH SL Pro
    Oct 2007
    I am using the basic Mag trainer from CycleOps. It retails for $199.00 and I think I got it for just a little less. It is their entry level mag trainer and the only one "below" it in their hierarchy is their wind trainer. I used to have a fancier mag trainer, a Minura, with different levels of resistance. It was o.k., but I like the CycleOps basic one for its simplicity.
    When I was looking at the new trainer, the guys I trust at my local shop--both a couple of pro mountain bikers--told me the basic mag is the best value and is what they use and the shop owner uses. They suggested the fluid trainers ride a little nicer, but if you really use them a lot they are more likely to need significant maintenance. I also love the ease with which I can get my bike in and out of the CycleOps--it takes about 10 seconds after you set it up the first time and it fits your bike. The Minura I had took me at least 5 minutes turning a crank with the bike falling again and again.
    Unless you are training indoors a bunch, there is a lot to be said for just going simple. And it fits your budget.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Quote Originally Posted by Gatorback
    I am using the basic Mag trainer from CycleOps. It retails for $199.00 and I think I got it for just a little less. .
    Here's some in the$145 range
    http://www.google.com/products?q=Cyc...=next&start=30
    Jun 2005
    Quote Originally Posted by louisssss
    You can...but you can also get a 26" slick tire for cheap.
    bi-winning
    Reputation: rkj__'s Avatar
    You can, but you likely won't want to. The the noise, vibrations, and tire wear are all rather undesirable.
    Reputation: AlliKat's Avatar
    force yourself to let it be your offseason. cross train until you can start riding again. Trainers work if you are racing because you have a goal to work toward. Riding on a trainer is not exactly fun.
    I have a blackburn magnetic. it gets the job done. I am training to race but still am crosstraining with running.
    Oh sh!+ just force upgraded to cat1. Now what?
    Best thing about an ultra marathon? I just get to ride my bike for X hours!
    cougarbait
    Reputation: Lambdamaster's Avatar
    Nov 2008
    fluids are quieter and offer better resistance. I use a Kurt Kinetic Road Machine fluid. before that I had a cycleops magneto that I ended up returning. for your purposes and budget, I'd stick with a magnetic. 26" no problem, knobby?? I'd throw a slick on there. I read some bad reviews on the blackburn. Go with a cycleops mag, or kinetic if you can afford one. Only kinetic has a fluid design that is impossible to leak.
    09AS-Rsl/09Six
