Results 1 to 71 of 71
Thread: Latex Tubes
    I like to ride my bike.
    Reputation: RideFaster's Avatar
    Dec 2004
    Latex Tubes
    Pros seem to be lightweight and less punctures.
    Cons seem to be air loss and with the Michelins, the valve stem is not threaded (so it can twist and rip).
    Thoughts?
    I like bicycles. Bicycles make me happy. Riding them makes me even happier.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    Reputation: Dmytro's Avatar
    Nov 2003
    According to Jenson, the latex tubes aren't any lighter than Maxxis Ultralight tubes (latex=145g, maxxis=125g);
    I do agree that less punctures is a big advantage.
    I usually pump up my tires before every ride, so air less is not an issue.
    I also preffer non-threaded valve stems.
    With that said.. I don't use latex tubes. Why? Because I don't want to pay $14 per tube.
    Dec 2004
    I don't mind an extra couple of dollars if it means flatting less.
    Are they just as pich-able as butyl?
    Scott Bicycles
    Maxxis Tires
    Team Blog
    Nov 2003
    I'm not sure what you mean by "pich-able", but, when I was installing mine - I felt like if I wasn't super careful, that I WOULD pinch it.
    Reputation: rob_co2's Avatar
    I havent heard anything about less punctures, whats that about? I bought some vittoras many years back, and they punctured probably more often than others. They say not to patch them, but i patched them successfully several times.
    But I dont think a few grams are worth the money.
    I've ridden latex Michelins for years, I think I've had two punctures, one from a nail and one from cactus. I ride 2.25s at 30psi and 2.1s at 35psi and weigh 140, never had a pinch flat. I used them on the road this year as well and had my first FLAT FREE road season! Also testing out 23mm latex tubes in my 32mm cross tires, so far so good, super light, great ride and NO FLATS at 45 psi even with some rim banging hits. I won't use any other tubes for competitive riding.
    SP Singletrack rocks
    you do realize that a UCI XC event hasnt been won on tubes since the 90s.......
    just saying tubes are outdated and make you go slower.
    Reputation: sbsbiker's Avatar
    Why use tubes at all, tubless is much better ride, and never a pinch flat. Many ways to convert standard tires and rims to tubless setups. It's 2009, drop that 1800's technology and ride tubless.
    Dec 2004
    I've been hesitant to go tubeless since people are always burping tires, need a compressor, more expensive tires, etc.
    But I guess I do have tubeless ready rims, so...
    I was just curious about the latex thing because I know that Adam Craig carries a latex tube around on his race bike.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    Reputation: MikeDee's Avatar
    Quote Originally Posted by RideFaster
    Latex tubes supposedly give you a little less rolling resistance. They are also supposed to resist punctures more (pinch and thorns) because the rubber is stretchier, but I think a goat head thorn is going to go through any tube, which is about the only cause of my flats. Latex tubes are more fragile, and sometimes fail in one big, long rip. That is why I quit using them. They also leak air faster than butyl, so you're pumping your tires more often.
    Craig carries a latex as a spare 'cause it's lighter. Prob does not use in his tires,yes?
    I use a UST tire, and Stan's rim/sealant, no burps, good luck with no flats, I have even seen small holes seal with extra air pressure and not removing the tire. It's a great system. Better than any tube I've even used.
    I carry latex just because you never know when you might get lucky. ;-)
    May 2005
    Quote Originally Posted by sbsbiker
    Me too. I run UST versions of the Racing Ralph mated to Stan's ZTR 355s, along with a Stan's yellow rim tape, ZTR valves, and some Stan's sealant. With some practice, I can now switch out a Ralph for a Nobby Nic in almost the same amount of time as it took me to swap a tube tire, and seal them with a floor pump.
    Compared to the Stan's conversion approach or even other UST setups (where a compressor is needed to get the bead to 'pop' on the rim), this is the most painless configuration I could have gone with and lucked out since it was my first real attempt at tubeless.
    I had tried conversions in the past using my Mavic wheelset and preferred tire choices from Kenda, all of which failed miserably (granted, non-UST versions of the Nevegal and Small Block 8 have been known to be poor candidates for tubeless conversions).
    That said, I always carry a tube and compressed air just in case of a sidewall tear that I can't fix or a bead fails, so a latex tube may find itself in my <a href="http://www.backcountryresearch.com/Awesome-Strap_c_1.html" target=_>Awesome Strap</a> at some point next season (which is the best freebie I've ever scored at a bike race, I might add! It rocks!).
    If you do use tubes, I do recommend the latex ones particularly on hardtails as they flex a lot more than butyl - so its like having a half inch or inch or something of suspension for free. That said, I've heard tubeless people with big tires that are on the more flexible side say the same thing. But within the tubed world - it definitely adds a half inch or something of suspension that you won't have with normal tubes. There are drawbacks, some mentioned above, also my friends and I used to run Air-B back in the mid 90s and the glue that was used to hold the valve-stem area would melt under intense heat. I do mean very intense heat, one for example failed after we were carrying Bob trailers and descending a Colorado pass, so not a typical ride.
    But, yeah, ride quality is increased quite a bit. I'm on the Michelin ones these days.
    Quote Originally Posted by BushwackerinPA
    Meanwhile the tubeless hype cooled down a little bit and we can see that tubeless is just a system with pros and cons like other systems.
    The Topeak Ergon riders use light tires with latex tubes again for example. Tests have shown just a very little, theoretical difference between tubeless and latex tubes. Installation time and work for tires with tubes compared to tubeless is just a joke, not to mention the costs. Schwalbe is testing new tube materials right now.
    It seems, that tubes have a comeback.
    Quote Originally Posted by Mr.SJ
    This is probably more a function of the tires that they run. I tried to setup some Conti tires for my wife to try and they were nearly impossible to get them to seat (the bead on them is loose like a Kenda tire, my guess is their manufacturing tolerances are poor). When I finally got the tire on her bike and she went for a ride the sidewall gave up life while still on the fire road climb to get to the single track... I hate cleaning all that latex off her pretty carbon MTB.
    The tires that we run aren't necessarily cheap, but we also don't have very many issues with them!
    Uh, bad story. Next to some good traits latex tubes also can (in very rare cases) explode, thatīs the reason for some riders to go back to xxlight butyls, which is just 1 Watt more rolling resistance, but means less puncture resistance (may be better with some sealant).
    Anyway, Iīm waiting for the new tubes.
    they run **** tires.
    what cost are you speaking off? I am running tubeless for the cost of a roll of gorilla tape, and tubeless valve stems. On non tubeless wheels with non tubeless tires. I have not had a flat in 3 years and I ride 10+ hours a week on some of the rockiest terrain in the county.
    my theory is those who dont run tubeless are just to damn stupid to figure it out.
    The problem with test is this, I can ride trails fastest at about 25 psi, with tubes this would mean I would pinch flat every mile, with tubeless I have ridden about 4000 miles with out a single flat of any type.
    VIP
    Cons: not tubeless
    likes to ride bikes
    Reputation: TunicaTrails's Avatar
    I had to run a race recently with a tube in the front tire after a sidewall tear in the preride. It worked fine, but I remembered the significant air loss between rides and two days later, got a flat on a tiny thorn. Laaaaame.
    Tubeless, tubeless, tubeless.
    LMN
    LMN is offline
    I am pretty involved in the race scene. When I look around the pits at a world cup I see only one team putting tubes in their bikes. Everybody else uses tubeless even those who are suppose to use tubes use tubeless.
    Honestly I would like to use a tube, I hate changing tubeless tires. But I am yet to find a tube that allows me to run 20 psi without flatting five times a ride. (OK DH tubes work, but the weight more than my tires).
    ups and downs
    Quote Originally Posted by LMN
    So far I've had good experience running the insanely expensive Eclipse 56gms tubes, they are very resistant to pinch flats running Conti Race King 2.2 SS's at 25-28psi (I'm 195 lbs) on DT XRC330 rims. I've whacked the rim hard enough on rocks and roots to worry about the rim surviving with no tube issues. I have had blackberry thorn punctures with the thin carcass RK's, but they are very slow, like they take overnight to leak down, and are easily patched with their patch kits. I had a 50% failure rate on the first purchase of the new tubes but they were replaced on warranty and have had no issues with the replacement tubes or the other pair that I purchased.
    The Eclipse tubes have no hysteresis, they roll incredibly fast, they take a while to stretch out in a big volume tire.
    First: I wonīt write about those using tubes (may be for some reason ) that they are "just damn stupid to figure it out" without being acquainted to them. Makes simply no sense.
    I have run tubeless, installed by me or a mechanic, and I am not convinced. So I went back to tubes. But I accept those running with it.
    I am running my tubes (and racing with) front with 1.5 bar and rear with 1.8-2.0 bar (depends on the terrain). Within the last 50.000k with tubes again I have had 3 flats. These flats would have been also a real test for tubeless systems, I guess. Costs for the last 50.000k: 3 tubes and of course a few tires, thatīs all. The flat statistics isnīt that bad, I think, and it doesnīt bother me.
    How much sealent has to be used for 50.000k
    I have been using tubes again and a conventional clincher feels more stable (less wallow).
    I really don't understand why people think tubeless cost that much more. It's literally like $50 for tape, stems, and sealant and then maybe you spend 20 bucks on sealant a year. Best bang-for-your-buck performance enhancement you can do to your bike IMHO.
    This is really difficult, and I tested a lot of variants, and I am still not sure which is the best way to ride. As mentioned above, tubeless offers a few pros, but unfortunately there is no 100%-guarantee that running tubeless with 20psi helps to avoid flats, punctures, rim damage etc.
    Once again the chosen tire is the limiting factor in the game. First I would never go out riding again with a tire size smaller than 2.2. We all know: high volume = very low pressure possible, even with tubes. Meanwhile it seems also to be clear, that the general trend to install the lightest tire for race purposes must not be the best solution.
    I had a few problems with superlight tires being installed tubeless (stability and also puncture resistance due to low pressure), I am feeling more controlled with tubes. Meanwhile I think "light enough" is better than "as light as possible". I was pretty surprised and lucky with the combo Smart Sam Evo rear + xxlight tubes (or latex tubes) compared to a much lighter setup used before.
    LMN
    LMN is offline
    It is great that you have had that success with tubes. As I said I wish I could get them to work.
    You should recognize that your success is not normal. Most people who have used both have much more success with tubeless. For myself it is quite dramatic. I dropped my air pressure by 15psi and reduced by rate of flat tires by about 90%.
    Yes, tires make a different. But superlight tires are always prone to flat, doesn't matter if you run them with tubes or tubeless.
    Tubeless I flat a few times a year.
    Tubed I flat at least once a ride.
    Sure slowing down on the descent would probably get rid of most of my flats, but what fun is that?!?!?!?!
    LMN, you are right likely. Perhaps I am just a lucky guy with my tubes.
    As I said Schwalbe for example is testing new materials for tubes. Letīs hope successfully.
    May 2012
    In less harsh words when BushwackerinPA used, but once you try tubeless in real terrain, yo will never go back.
    I used tubeless about 6 years ago for the first time and I cannot imagine using tubes again. When I ride I bike with tubes, no matter how good they are, I feel as if I was using cheap 1kg tires.
    Another step ahead are tubulars, those have many downsides though.
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    2 years and then...bam!
    Yep, 2 years and I'm still one of those "stupid" guys running tubes who in 10 years has never had a pinch flat. I get the whole better traction aspect of tubeless but I am hard pressed to accept that riding on way underinflated squishy tires is somehow magically faster than properly inflated clinchers. Suspension robs the rider of speed and power (in theory) that's why lockout exists. Underinflated, soft tires don't have the same effect? This is a serious question from someone who has never tried tubeless, not trolling.
    Reputation: Johnnydrz's Avatar
    No, "under-inflated" soft tires don't have the same effect because they stop the bike from boucing around. They grab better, are way more comfortable and provide great traction. I used to race with 40lbs in my tires. Now I know that that slowed me down because everything was shaking out of control!!! I ride tubeless on the mountain and on the road.
    May 2012
    Quote Originally Posted by Johnnydrz View Post
    That is 100% right.
    Rolling resistance decreases with pressure when going on fast easy tracks.
    Rolling resistance increases with pressure when terrain gets really rough.
    When using less pressure on difficult terrain, you literally flat obstacles down, thus increasing comfort, tracking, speed etc.
    I personally hardly ever pump over 2 bars, weighing 73kg. Usually I use 1,8 front and 2,0 in back on Tubeless.
    Some of the roadies that I do MTB with during winter time will never agree with me, but this is exactly the reason why they will never go fast in difficult terrain.
    mnoutain bkie rdier
    Quote Originally Posted by robc in wi View Post
    Most "studies" will disagree. It does seem odd at first, but it is true that often a lower psi will roll faster than high psi on bumpy/rocky terrain.
    Bouncing all over the place really slows you down and a lower psi helps to minimize this. An exagerrated example of high psi would be trying to ride a wooden tire/wheel over rocky terrain...not good!
    NOTE: Both extremes, whether too high or too low will lead to problems and loss of rolling speed... Find the sweet spot with regards to proper psi and you will find that your bike is faster than ever..
    .02
    Reputation: brentos's Avatar
    I've found latex tubes to be a viable alternative to tubeless on my CX Racer/Commuter bike. I don't have to worry about the sealant drying out, an they've been really flat resistant, on par with the tubeless setup I had. Overally I still prefer tubeless if the setup isn't too challenging.
    I hate riding butyl tubes since I went tubeless, they ride is dead and they roll slowly, but I really can't tell a difference between tubeless and latex.
    Latex tubes make poor race spares though, because they are hard to place correctly when in a hurry (with no twists and not between the hook and bead).
    Quote Originally Posted by brentos View Post
    Wow, this thread is still alive.
    Emergency case: butyl, just to finish a race or to come home.
    Everyday use: tubeless/latex, whatever you like.
    I still think like brentos latex tubes work fine for xc purposes.
    Quote Originally Posted by Mr.SJ View Post
    you are a coward. SierraJim negative rep under the guise of being anonymous? either debate in public, and stop trying to discredit someone who....
    knows more than you
    out rides you
    out skis you
    and will always be above you, and the only reason I am calling you out is so you can stop being a dick to a bunch of people who actually ride MTBs and race them at elite levels. go back to gapicski.
    Reputation: FLMike's Avatar
    Quote Originally Posted by BushwackerinPA View Post
    knows more than you
    out rides you
    out skis you
    Where is the popcorn smiley when you need it...
    knows more than you
    out rides you
    out skis you
    Anonymous ... Canīt you read? Or did you drink too much Stanīs?
    Apr 2005
    I used a lot of different latex tubes back in the day. Air-B, Michelin, Conti, Vittoria and probably some others. They did give a nicer ride than butyl, also better than other alternative tubes like Panaracer Greenlites. They were good about punctures, but I did get a lot of flats with them. Sometimes pinchflats, but often it was from the valves tearing off. They all seemed to be held on with butyl patches and the butyl/latex interface seemed to be the weak point. I can't imagine why you wouldn't just run tubeless, if you really like changing flats (yes it can be done fast with tubes!), stay with tubes. If you like it a lot, go to latex tubes that way you can also spend more money!
    Save Jesus
    Reputation: beanbag's Avatar
    knows more than you
    out rides you
    out skis you
    Perhaps you got negative rep for acting in a disreputable manner LOL.
    Quote Originally Posted by epic View Post
    @epic
    I have no significant reason why I am sticking with my latex or supersonic tubes, really. I am just used to a quick installation time when changing tires. My last flat? Way back (three years, I think). I can ride as fast as I want with tubes, even with 1.5 bar.
    I think, the following may help to have a mind of oneīs own:
    Eclipse Tube Test Results
    Reputation: twyeld's Avatar
    what's the verdict when comparing latex with synthetic/polycarbonate - like Foss or Eclipse tubes?
    Twyeld, have a look at the link above for more details. In short:
    Latex tubes do have the lowest rolling resistance if compared with Foss or Eclipse.
    Latex tubes are good in penetration or snakebite tests, but the Foss tubes are said to be even more robust with a little self-healing-effect (but quite heavy). Eclipse is just excellent against snakebites, but not that good against penetration, but with a fantastic weight of just 56gr.
    The cheapest are latex tubes, Foss is a little bit more expensive and Eclipse is superexpensive.
    thx Mr.SJ
    Just in the pinch flat dept., would you say the latex (Michelin Air Latex) are better than the Foss?
    I am running Foss now and have gone from 34/38 fr/rr using Butyl to 30/34 using Foss - could I go lower with latex? (and, yes, I know tubeless is the way to go, but I'm still a bit old school and like the convenience and cleanliness of tubes for now...)
    T
    I canīt say for sure, but you should give the Michelin Aircomp latex a try (weight is ~120gr). I am running my Race Kings 2.2 SS with 22-23 psi.
    wow! is that with latex tubes?
    what sort of trails do you ride on?
    I ride on some pretty rocky stuff so need to run higher pressures
    the Michelin Aircomp latex is what I plan to try out...
    Yes, it looks like, but this is for XC/marathon purposes, a hardtail and a quite low body weight. Usually mixed terrain: trails with or without stones or roots, fireroads, split, loam, sand and so on.
    You know what you are doing and what pressure is just perfect.
    The Michelinīs are a good choice (I read somewhere that Michelin re-engineered the production of this latex tube not long ago to achieve a better quality), but of course thereīs no guarantee that you will never get into trouble...
    - all good Mr.SJ.
    I'm 69kg and about 10% bodyfat and a fairly smooth rider so it will be interesting to see if I can lower the pressures with the latex inner tubes - will post back after a test run.
    T
    So you are in a good shape, try to go with 25psi.
    Important: latex tubes should not get in touch with oil or fat. Check your hands and your rims during installation, avoid sharp edges and put some talcum powder (baby powder) in your tire; makes the whole system working very smooth.
    Quote Originally Posted by beanbag View Post
    i would argue that anyone suggesting to use tubes on a MTB is acting in a disreputable manner.
    Although I truly do wish all my competitors run latex tubes, so i can go faster than them and have a more reliable set up.
    Thanks for the tips on latex setup Mr.SJ
    As for tubeless setups - it's not always about having the best setup. Sometimes (as in my case) it just comes down to how much time one has to do the necessary maintenance within the time given. It's just easier to fix a tube than go through all the setting up required for tubeless - yes, and I know the argument will be: 'once setup you won't get any more punctures'. But it is the initial learning/setup curve/time that some of us just don't have - we're lucky to get a few hours ride in a week, let alone proper maintenance... I suppose being fast and winning is good, but not at the expense of having fun - even if the tyres are a little over-inflated...
    Here's an IT analogy - it's a bit like going from Windows XP to Win7 - the benefits are clear but you might lose all your legacy apps that you've been using for years and so you are unproductive for a few weeks while you learn the new system - the benefits are not then immediate nor significant over time if all you do is use your PC as a typewriter...
    besides - tubes are sooooo retro!
    tehe
    @twyeld
    You are welcome.
    Quote Originally Posted by twyeld View Post
    - all good Mr.SJ.
    T
    ...well I said I would get back to report on the latex tubes after trying them out. It has taken me a while to try them out as I was OS for a bit and then rode my roadie for a few weeks and only got on the MTB this week for the first time in about 2 months - getting ready for our XC season (just started).
    The reason I put this history first was to contextualise the test.
    As usual, the first few times I get out on the MTB, after a few weeks riding my roadie, I am understandably a bit wobbly. I went out on my Trance with 150 Sektor up front and a RP23 150x90 out back on ZTR Flows - 2.25fr/2.1rr xmarks, 32/38psi (higher than usual because I know I will be a bit sloppy and pinch flat if not careful). Day 1, I was still using the Foss tubes. I follow a circuit that takes about 3 hrs with some steep hills and very rocky sections with some rocky 1-2foot drops onto more rocks. The final run home is fast and rocky with lots of drops and berms with baby-head sized rocks etc. When I got home I noticed the back tyre had gone soft. Completely flat after about 2hrs. I checked it out and sure enough a pinch flat. So, time to put a latex tube in.
    I have since ridden exactly the same circuit 3 more times this week and not a single flat! I even tried lowering the pressure from 32/38 on day 2 on latex - to 30/36 on the day 3 - until today (day 4) I tried 26/32! Although I was getting better at picking my lines, I still deliberately ploughed through some rocky sections and landed heavy to try and pinch flat the latex tube in back - without success (I keep popping down to the carport to check that the tyre is still inflated...).
    So far I am impressed! But I remain sceptical. Perhaps after 10 rides I will be fully convinced.
    Typically I would flat about every 4-5 rides on the Foss tubes at 30/36...
    ...an update in a few weeks...
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    Some of you people are like Jehovah Witnesses... Preaching your tubeless religion in every tire, wheel or tube related thread.
    umm I was running 23psi today on Flows with no tubes.
    why the hell would you buy flows and run tubes? and how tubes better in performance than tubeless. Answer they aint.
    I think Millfox's post should come after BushwackerinPA's - shouldn't it?!
    ...not everyone wants to run tubeless for lots of different reasons - that's why they post up their various tube related tests - to see what works and what doesn't...
    ...although, i do agree it is inevitable that I will go tubeless - I am just the sort that likes to exhaust all possibilities before making the change - hey, I'm still running XP SP3 on my comp!
    jsut name one performance disadvantage to tubeless.
    Save Jesus
    Increased risk of burps or blowoffs.
    Increased chance of pressure loss due to a pinhole on the sidewall becoming unsealed while riding.
    Extra weight of semi-permeable sidewall + 2 scoops of sealant sometimes weighs more than the equivalent non-tubeless tire + light tube
    Continential Race King Supersonic 26x2.2 + 100g tube = 570g
    Race King Protection (RTR tubeless ready) 26x2.2 + 60g sealant= 610g
    For people who don't pinch or puncture flat, a latex tube has no performance disadvantage to a tubeless setup and is MUCH more convenient to run, especially if you like to swap tires.
    I **** much more than 40 grams every morning. I have never burped since using tubeless rims and tubeless tires. Only flats are from rock tears that would have shreded any tubed tire anyways
    I cna swap tires faster on a tubeless rim than you could with a latex tube. Id bet large sums of money on it. but to make it more fun how about this.
    I can do a non time lapsed video of a tire swap on a tubeless rim, while you do it on a latex tubed rim.
    If I win, you post up in every forum saying tubes suck. and you can name your price. I mean if you going to say stuff on the net, it should be true right?
    Save Jesus
    Well, you know what they say: "One pound on the wheels equals 10 pounds on the rider." So you'd have to poop 400g.
    Name just one performance advantage of tubeless, and I can claim those don't apply to me as well.
    Does this tire swap include:
    Pumping furiously until both beads catch and hold air?
    Adding sealant?
    Having to overinflate the tire until both beads pop into place, and then deflating the tire to operating pressure?
    Doing the Stan's shake and bake procedure with soap water to seal up all the little pinhole leaks in the sidewalls and around the bead?
    Cleaning out the old tire and disposing of the sealant?
    Adding sealant?
    all of the above that apply to said tire.
    I am using compressed air, because well I have it.
    2 adding sealant is easy
    not hard to over inflated with compressed air
    there will not be pinhole with a the tires I am using
    whoa - lets not start a war - wots the point?
    it's pretty clear tubeless sh**ts all over tubes...
    the only real advantage in tubes is no mess, cost (reusable/patchable) and convenience (quick tire changing - especially out on the trail - tubeless you need to carry a spare tube anyways - even tho you might not use it as often..)
    bottom line for me is if Latex lets me run lower pressures than Butyl and Foss without pinching then I am happy...
    ...today i tried 24fr/30rr on a 650b x 2.1 fireXC up front and 26 x 1.95 xmark out back on the AX - no probs so far...
    I agree. I haven't run tubes since 2006 and there is no going back. Very very occaisionally, I will use a tube in an emergency situation and it just confirms that they suck.
  67. #67
    Just went back from a 3 weeks session - with tubes. I usually run with less than 23 psi f/r. This is exactly the same pressure like that when I run tubeless in former days.
    I use latex and xx light-butyls, just to keep things as simple as possible and both performe well enough, as I think.
    I mean, if anyone loves to ride tubeless, this is perfectly ok. Some like me ride with tubes - so what?
  68. #68
    well I'm going with Mr.SJ and beanbag...
    I raced for the first time yesterday on latex tubes 22/28 fr/rr. I used to have to run 32/38 fr/rr with butyl tubes. I probably could have gone lower but it felt fine and was appropriate for a slightly wet but fast course. I finished 5th. Plenty of rocky outcrops to pinch on too - which previously I would have been very careful how I rode over - but I just blasted through like I was running tubeless!!! hahahaha
    but I do think the combination of a ZTR Crest rim with an undersized (1.95) xmark tyre helps...
  69. #69
    Well done, congratulation!
    As a quite new test shows, the difference in rolling resistance between tubeless and latex tubes is 0,6 Watt. But the testers think, considering the still impressive low rolling res parameters of heavy downhill butyl tubes, that tubes give an extra of stiffness to the tire system, which helps on hard terrain to keep up quite easy rolling.
    Twyeld, I think you should install tires with more volume for more comfort and lower rolling res. The effect of 2,25er tires with latex tubes for xc purposes is fantastic.
  70. #70
    Thanks Mr.SJ - yes, I normally run larger tyres. On this occasion I knew there were going to be some mud pits - the skinnier tyre seems to cut through where the fat tyres bog down - well, that's been my experience. I can't wait to try the latex tubes with some 2.2 Icons and low pressures on a drier track...
    I really didn't think there was an alternative to tubeless. I suppose I may change my mind when I get my first pinch flat on the latex. But, to-date, this has been my longest puncture-free stretch. I'll keep lowering the tyre pressures on my trainer (Trance) to find that threshold...
  71. #71
    Unfortunately there is no 100% guarantee to stay all time trouble free with latex tubes (just like tubeless ). But based on experience itīs a quite safe system.
Members who have read this thread: 4
