Results 1 to 16 of 16
    improving lung performance/capacity
    im just getting back into bikes after a long time and am having issues over being gassed or low o-sat at the top of climbs i recover on even the shortest decents but that leaves me unable to hammer the downhills cus im recovering.whats the fastest most effective way to improve my lung capacity
    Reputation: Fakie1999's Avatar
    Feb 2010
    ride lots.
    Reputation: Metalhack's Avatar
    Take up ERG Rowing....Helped me drastically. I do 45 mins of intervals 3 times a week.
    Here's a good read.
    Reputation: 5power's Avatar
    Quote Originally Posted by Metalhack View Post
    Here's a good read.
    thats some good stuff thank you
    good info thank u
    LMN
    LMN is offline
    Quote Originally Posted by Fakie1999 View Post
    ride lots.
    Probably the best advice here. Or to quote Cavendish's coach "ride your bike".
    There is no magic. You need to ride 4 to 5 times a week with training sessions ranging from 1 to 4hrs. Start doing that and after a couple months you will be fairly quick, after a couple of years you will really quick.
    There is no short cuts, you have to put in the miles.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    Reputation: WR304's Avatar
    There's a thread with some ideas to try for working on your breathing here:
    Race Breathing
    Improving your overall fitness will help a lot. Keep riding regularly, and as you get fitter your breathing should also become less laboured and intrusive. If you've just started riding again, after an extended period off the bike, then you should find that your fitness will initially improve quickly over the next few months.
    You could also look at your pacing up the climbs. If you ride slightly within yourself uphill (so that you aren't totally winded as you crest the hill) then you'll be in a better position to keep pushing on the descent. It's something to experiment with.
    In addition to the fitness aspect....there are many technique issues....
    From opening the airway, to useing the ribs and diaphram effectively....
    The free lower ribs expand more easily than the fixed upper ribs....many people donot breathe deeply enough to effectively use the entire lung....
    A small pause between each exhale and inhale helps increase gas transfer in the lungs.
    The body will automatically increase the breathing rate as you begin to work harder...
    Before a hill or obstacle, you can increase your breathing rate this will also help....you can also maintain that breathing rate after the hill or obstacle...
    There are breathing coaches that work with people who have lung issues and diseases, they employ strategies as above and many others as well.
    Training,training,training...and then much more training
    Reputation: bridger's Avatar
    Dec 2010
    Quote Originally Posted by jeffscott View Post
    " A small pause between each exhale and inhale helps increase gas transfer in the lungs"?
    I perform exercise testing as a part of my job and do single breath and multi breath lung diffusion capacity on subjects & I'm trying to figure how gas transfer in the lungs can be influenced this way?
    I think the best way to "increase lung capacity" is to concentrate on exhaling when working hard instead of inhaling. It's just a matter of getting rid of the CO2 produced.
    Reputation: jrastories's Avatar
    Quote Originally Posted by bridger View Post
    I compleatly agree, The distance and concentrations to cause gas exchange in the lungs is not a limiting factor, most people start to breath really fast and are not able to clear the CO2 from their lungs because they are not breathing out all of the air. If you can drive the CO2 out of your body and lower the blood concentration then your body can drive the metabolic pathways to break down more lactate.
    Rocky Element
    My Attempt at a Blog
    That's what I always try and do as well.
    A strong exhale each time and keeping a steady breathing rhythm are what I focus on. It's sometimes possible to forget to breathe (during really hard sprinting for example) so you have to pay attention to make sure you keep breathing during those sorts of efforts.
    It's also possible to breathe too much. If you're getting close to hyperventilating that's a bad technique. Concentrating on maintaining a steady breathing rhythm will generally avoid that issue. If you find yourself breathing in short ragged bursts try to consciously control and slow your breathing down again (aim for long deep exhales, let the breathing in happen by itself).
    i wouldn't advocate pausing, but i think that "pursed lip" breathing at altitude is definitely handy for lowlanders.
    Try to be good.
    Well not really, you have a number of things going on at the same time...
    The air side O2 transfer in to the membranes the blood side O2 transfer, then of course the reverse for CO2...
    Stale air in lower lungs, but blood still flowing thus bypassing good oxygenation sites..
    You also have to move that air and blood into and out of the lungs..Up to 7% of aerobic output is strictly cardiovascular.
    Basically you want to maximize the Volume of O2 absorbed and the Volume of CO2 desorbed...(they kinda have to balance out over say a 5 minute average).
    There will be an optimum O2 and CO2 concentration in the exhaled breathe, at which maximum O2/CO2 volumes are transfered...
    If you are exhaling high O2 concentrations or low CO2 concentrations you would benefit be pausing a little more....
    If you are the opposite you would benefit by pausing a little less...
    Most people will end up with needing to pause a little more than they are normally inclined to do.
    Quote Originally Posted by jrastories View Post
    I compleatly agree, The distance and concentrations to cause gas exchange in the lungs is not a limiting factor,Not at all true most people start to breath really fast and are not able to clear the CO2 from their lungs because they are not breathing out all of the air. If you can drive the CO2 out of your body and lower the blood concentration then your body can drive the metabolic pathways to break down more lactate.
    The mass transfer of gasses in the lungs is one of many limits to aerobic exercise....and the are almost all in a series chain...each one adds a little bit more resistance to the entire loop.
    Reputation: DavidR1's Avatar
    Running seemed to help me. But I think any kind of intense activity would work.
    CyclingCentralVa.org
  1. Improving performance
    By r1de in forum Washington
    Last Post: 08-20-2009, 01:20 PM
  2. Lung training?
    By flankwood in forum XC Racing and Training
    Last Post: 05-18-2008, 06:51 PM
  3. A tip on Improving RS Domain performance
    By juan pablo in forum Downhill - Freeride
    Last Post: 05-16-2008, 02:40 PM
  4. Replies: 5
    Last Post: 11-07-2006, 02:43 PM
  5. Lung Capacity
    By whataboutben in forum General Discussion
    Last Post: 08-09-2006, 08:44 AM
