Results 1 to 36 of 36
    Big Damn Hero
    Reputation: CBRsteve's Avatar
    Heart Rate: How high is too high?
    So the thread title gets right to it, how high of a heart rate is bordering on unsafe? First off, I realize that each person is different and that only a doctor should provide the guidance I seek, but I just wanted to get some of your folks thoughts.
    Some background info: I am pretty new to racing (only done four in the past 12 months) and I generally finish around the top 50% within my class Cat 3 30 Ė 39. I am 6í3 175lbs. I generally have a higher heart rate than my buddies while we ride, but my also tends to drop off quite a bit quicker than theirs. While slightly exaggerated, we likened it to their hear rate profile looking like rolling hills while mine looks like peaks and valleys.
    Due to work/family schedule Iím relegated to riding on the trainer 2/3 times a week and get out on my bikes only once a week. I try to put in around 6 hours a week on the bikes. I keep all of my heart rate stats for every ride whether itís on the trainer, road or trails. I generally tend to average around mid 165-170 bpm on my trainer which feels relatively rigorous. On road rides I average pretty much the exact same, 165 Ė 170 bpm with a max in the low 180s. Trail rides tend to average a bit higher at around 175 Ė 180 bpm with a max in the low 190s. My resting heart rate is typically around 55-59 bpm.
    My first race of the year (Bluff Creek Ranch, Ward, TX) was 7.5 mile sprint race where I averaged 185 bpm for the 41 minute race. Last weekend was my second race (Double Lakes, Coldspring, TX) where I averaged a ridiculous 195 with a max of 205 for the 12.5 mile 60 minute race! The weather conditions and trail type were about as different as can be, but Iíve never seen numbers like those at Double Lakes and frankly it was a hard race but it didnít seem that insane. :-)
    Afterwards I got to thinking that while itís great that I pushed myself harder than I ever have before, did I push myself too hard? While Iím certainly not a seasoned pro, I have spoken to enough riders to know that those are not normal heart rates and Iím just wondering if I should be concerned with the possibility of potentially pushing myself too far? How big of a factor does weather, hydration, etc play in heart rates?
    I havenít had a physical in a few years, so I planned on scheduling one here within the next week or so and talking to the doc about it, but like I said earlier, I was just hoping to get some thoughts and opinions from you all as I know many of you religiously track your physio metrics.
    Thanks for your thoughts!
    Life is like riding a bicycle. To keep your balance you must keep moving. ~ Albert Einstein
    Reputation: pattongb's Avatar
    I too wonder this. My HRM at times goes over 200 and im wondering if maybe im pushing too hard?
    People ask me all the time "who beat you up"? I tell them "a tree". They just look at me funny....
    Reputation: Poncharelli's Avatar
    Jan 2005
    There is no problem with having a high heart rate. Only if you have other symptoms with it: excessive dizziness, chest pain, etc. Then you should go see a doctor.
    I have two racer friends that have developed heart problems and they ride/race with HR monitors with upper limits programmed (doctors recommend that they shouldn't exceed XXX HR).
    But for the most part, in training, it seems that the most benefit is gained from longer-lower HR rides (below your LTHR).
    LMN
    LMN is offline
    There is a significant variation in max heart rate. Seeing values around the 200 mark are not unusual. It is when you start to see values in excess of 220 that you should start to get excited.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    Jan 2009
    I often hit and spend short periods of time above 200 during races. I've even seen 209. 6'2" 175lbs, 21yr old
    dcb
    dcb is offline
    As others have said, as long as you're healthy there's no issue. Your HR pattern is probably better than your riding buddies as it shows that you're responding and recovering to efforts better than they are. That assumes other factors are relatively equal.
    That is only slightly higher than mine. My threshold is 180 so I can spend a fair bit of time above that and not blow up. I've seen 205 on my hrm before and am not worried about it.
    "Shut up legs!"- Jens Voigt
    On flatter races or races with no big downhills to really recover on, I'll spend the 95% of the race in Z4, which for me is ~175-195. My average for most races is in the 180's. Haven't had any problems so far...
    Big Damn Hero
    Quote Originally Posted by kherron View Post
    Good point, I hadn't thought of that... Double Lake is pretty much flat the whole time, I think there is only about 400 vertical feet worth of climbing so we're pedalling non-stop the entire ride. I guess it could partially be due to cardiac drift related to that effort.
    Thanks for all the responses so far... nice to hear that I'm not a total cardiac freak.
    Sometimes the heart rate strap/monitor can get false readings and can make your heart rate look higher than it really is.
    I have a similar heart rate profile. Max out around 174-ish. When I'm in the 170 range I'm working pretty hard and I can definitely feel it. My resting heart rate is in the upper 30's.
    I've seen "blips" in my heart rate data which suggests a false reading. I wonder if excessive sweating can cause this....
    Aug 2010
    Quote Originally Posted by CBRsteve View Post
    Get the physical. Check your family history for heart problems. If something comes back regarding your heart, then it needs a couple of different medical opinions including a cardiologist before settling on a Max value.
    Heart rate numbers are just a number with no meaning *on their own.* I've been over 200 plenty of times for minutes at a time. Your body is self-regulating so any number of regulators will slow you down.
    Based on my experience
    Your heart rate ranges seem pretty normal.
    The average of 195 seems pretty high but there are accuracy problems with heart rate monitors. During a race where there are a couple hundred people using devices that broadcast on the same frequency its pretty easy to pick up some errors.
    I would suggest (if you have not done so) doing a max heart rate test as well as a threshold heart rate test and keeping the values to compare to in the future.
    Visiting St george/Hurricane? Stay at my vacation rental. Discounts for MTB's
    http://www.vrbo.com/392904
    PM me
    To make a long complicated story short.....
    If you have any reason to believe you have any sort of heart problem see a doc.....
    Tell him you want to go hard....if he says okay...
    Go hard
    Mar 2012
    Sorry, hijack of thread, but related... I have a question related to Heart rate. How big of a tool is knowing your heart rate in terms of training and working out, and then racing?
    Like, i've never really focused on my heart rate other than trying to keep it down while training / racing etc, but do you guys really keep a close eye to have a good idea of "how hard" your going?
    Is a heart rate monitor really worth the $ if your serious about this stuff?
    Which ones would people recommend?
    Thanks in advance...
    I am 45 years old and I can still see 195, when I was in my late 20's and early 30's, I could easily go over 200. Some of us can just go high. Everyone is different but I would not worry about it.
    You also raced at 1:30, right? By then, it was getting hot, which might have contributed to your high heart rate. I raced at 9:00 and by my third lap could feel the heat coming on. I agree with other posters that there's acceptable variation with Max HR. But it wouldn't hurt to get a stress test and echocardiogram if you have worries. Check out the Strava entries for DL. I agree that "average," which I emphasize, 195 HR seems high for that race. But maybe your heart beats faster than others.
    Aug 2010
    Quote Originally Posted by On3_kn0WN View Post
    Knowing your lactate threshold is useful. Heart rate as a number by itself is pretty meaningless. I've found a timed hill climb +/- 10 minutes more useful. That only requires a stop watch.
    It's always a good idea to check in with a doc. But....you are new to this sport and are experiencing high heart rates when you ride. This is a sign that your aerobic fitness is weak. And that also means you are probably toughing out all those rides!
    You would benefit from doing an aerobic endurance block where you would see your speed/power improve at a lower heart rate. Once that plateaus (or you decide to move on), train your higher energy systems (Google Phil Maffetone). Even on limited training time, you should still lay some kind of a base down.
    I've been injured and had trained a limited amount of training time over the last month. My power has jumped 17 watts at the same low heart rate (148ish bpm)...which is not bad for putting in as few hours as I have.
    Turning the pedals faster every year.
    It seems high and the variation is odd, but everybody is different. Heart rate monitors vary in quality and can be affected by a bad battery. I would:
    1. Change the battery in the hrm.
    2. Perform a lactate threshold test on a trainer or something like that to give you a more accurate base line. It's not that hard to do.
    Your heart rate can also increase (and sometimes decrease) if you're dehydrated. Again, the reaction is dependent on the person.
    I think it's important, especially for training. Once you get your lactate threshold dialed in, it helps with increasing or decreasing the intensity of your workouts in a more scientific manner. Also, you'll know how many calories you're burning and what you need as far as nutrition is concerned for recovery. I don't usually watch it too much during a race and go more by feel, unless the race is going more than 2 hours. The longer the race, the more I will use it and monitor my hr. I've used Polar and Garmin. I like my new Garmin better, but Polar still makes a quality and accurate hrm.
    Big Damn Hero
    Quote Originally Posted by TJRosson View Post
    Yeah, it as 85 degrees at the start of the race according to my buddy...
    Quote Originally Posted by Sparty99
    I was unfortunately quite dehydrated... which was especially odd because I'd drank 2 liters of water over the 4 hours prior to the race.
    I like to hydrate 72 hrs prior to a race and continue hydrating until the race start.
    "Your opinion may vary, but it's stupid." -Rich Dillen
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    I hit 206 on my heart rate monitor two weeks ago. I went a little too hard at a very long hill on my single speed. I was fine. I just needed to catch my breath. You're not alone man
    There is not much choice between rotten apples.
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    The heart rate where your legs feel like cement. That one!
    First welcome to racing! At Cat 3 racing only 1 lap at distances lasting an hour or less, I wouldn't get too concerned with heart rate. Go by how your body feels. You appear to have been riding long enough to know your body and recover quickly if you do spike it. Use that as a guide rather than your HRM.
    At Warda, my HRM showed a reading of 223 before we got to the pond...so I backed off and dropped to 15th place. I then had a hard time getting through the slower traffic to get back to the front in a one lap race. Now I ignore my HRM at the start and concentrate more on my breathing.
    I'm a fitness instructor and teach breathing technics to slow down your HR. You can slow it down 20 BPM almost instantly by just slowing down your breathing with long slow deep breaths. Tell yourself to relax and don't get too amped up. You will ride smoother too...and smoother is faster.
    I'm 44 and my HRM shows an average of mid 180's and peak in the low 190's in an XC race. Now when you cat up and race twice as long or do longer races then your HR will be a bigger factor. Then your conditioning level will determine how long you can run higher HR's and how quickly you recover. In longer races of 4 hours, I try to stay under 165, and in 12+ hour races I try to stay under 145 bpm.
    Now go race Dallas and keep your head up, keep your weight on your pedals, brake less, push the steep climbs as hard as you can, control your breathing on the flats and downhills, and go all out on the last steep climb to the finish. Don't worry about the HRM unless it says you are under 170, then you know you can push harder. In your class, the top 7 or so riders are on the gas the whole time and don't let up.
    Go faster!
    Reputation: sergio_pt's Avatar
    damn 223bpm?? How old are you?
    I love the search function on forums! I was wondering some of the same things about unsafe heart rates. I just got a Zephyr HxM and did my regular loop and looked at the results once I got home. My max was 194bpm and I was above 183bpm for 35% of my ride. I just turned 39 and recently lost 15 to 20 lbs. I've been riding hard for a year or two and had no idea my HR was that high. I don't feel like I'm riding at 100% but I do ride at a pretty good clip. From reading some responses in this thread I'm not as concerned as I was. I usually ride by myself so there's no interferance I can atribute the high reading to. Great info guys!
    Jan 2005
    ~ rule of thumb for max: 230 - your age.
    I remember seeing the ultrasound of my first kid and the heart rate was 160 -- I started freaking out that he was under some kind of stress - doc said that was normal.
    Reputation: qdawgg's Avatar
    LOL - I could have written this thread with the same question. Almost everything is exactly the same for me as well; including time racing, CAT racing in, and heart rate readings.
    I've just decided that those rates are okay for my body because I don't ever feel dizzy or nauseous, other than the obvious feelings of my completely drained when the race is over. My heart rate does seem to be significantly higher than my buddies but I also seem to be able to maintain what appears to be a high heart rate longer than my buddies would be able to.
    The biggest problem I've found so far is that on a lot of the mtb courses I've raced so far, there are a lot of short steep climbs. I get my heart rate up at the start of the race and then I start hitting those punchy climbs and it spikes like crazy. I never feel like I can get it back down, or it will start to drop a little bit and as soon as I hit another steep section it shoots up again. I've found that road biking, same thing. Even if I haven't ridden that far and I hit any type of hill my heart rate spikes really quickly even if I'm not pushing myself that hard.
    "Like" the Brewery Ommegang facebook team page
    https://www.facebook.com/pages/Team-...18356588347806
    spec4life???..smh...
    Reputation: spec4life's Avatar
    I noticed racing this season that generally when i cross the 200 mark it doesnt take just a second before the dry heaves set in. Iv only hit this in the last lap of a cross race or in the final sprint of a crit. The highest Iv seen is 207. Im 23 5'8 145 for reference.
    I posted the link to this article in the endurance section, but then I saw this thread. Here is another article regarding training/racing at high HR and possible negative health impact.
    Endurance Sports: Studies on Older Endurance Athletes Suggest the Fittest Reap Few Health Benefits - WSJ.com
    Big Damn Hero
    Since this has gotten a bit more traffic recently I figured I'd update the post with my personal experiences.
    It seems like the race in particular that I referenced was a fluke. While my HR is still typically 15-18 beats higher than my teammates while racing or training, I haven't seen any readings similar to what I experienced in the Coldspring race. I've done five races since then with a max peak HR of 195 and a max average HR of 185.
    I did 26 miles of the Holidaze Half Marathon race yesterday and my average was 176 before a technical DNF...
    On a side note though, I have been able to increase my training load to 8-12 hours a week which I'm sure has helped some as well.
    I once (with lots of caffeine in me) averaged 198bpm for an hour crit races, I also know a 50 year old who can hit 214bpm, incidentally he's also a cardiologist. His way of putting it was - how fast your heart is beating (within its limitations, ie not supra max) doesn't really matter, it's more rhythmic, if something's wrong, you'll know about it!
    More importantly, why are you using the internet to try and figure out if you have a heart condition? Seriously, go and see a trained medical professional if genuinely are worried.
    Quote Originally Posted by spec4life View Post
    Yeah I don't go to the puke point anymore 55 years old...but in my teens and twenties I would...
    I did go to a cardiologist 5 years ago, I had some palpitations etc....turns out no problems...
    I asked can a go hard as I want....several times...
    His answer was yup go for it, you will puke, pass out, fall over what ever.....has heart self protection if you manage to push that hard.
    Giant Anthem
    Reputation: 2fst4u's Avatar
    Your heart rate and how it behaves is genetic-no issues if it appears "high". 200bpm is relative. For me, yeah I would burst at 200bpm but several racers I know routinely go in the 190's and higher. I had a client once with a perfectly healthy heart that needed to get to 190bpm to get close to lactate threshold and get a hard cardio session in.
    Racing and Training Blog
    http://dirtandgears.blogspot.com/
