Results 1 to 11 of 11
    Apr 2005
    Ergon GX1 Superlight Blister.....
    Hey Guys. I didnt know where to post this question, but since I bought these grips for xc racing.. Im doing it here...
    I bought two set of the GX1 Superlight Grips, I installed on my bikes and went for I ride. I adjusted three time until I got a better feeling. Went for a 2 hours ride. and After the ride my hands were full of Blisters... I couldn't even drive back home..
    What could be happening...
    Hope you guys can help me
    thanks
    Oct 2007
    Are you wearing gloves?
    Apr 2005
    Yes. with no Padding...
    Apr 2005
    full finger gloves...
    Oct 2007
    Maybe the different position of the grips in relation to your hands is causing the gloves to slip in areas they didn't before. Maybe you can try a new pair of gloves before giving up on the grips. I use gloves with a little padding and it seems to help delay getting numbness on long rides.
    Apr 2005
    I adjusted the grips again. I ll gve them a try tomorrow...
    VIP
    Ahhhh buddy you're hands will toughen up
    Nov 2006
    I use the same grips and they're awesome. As someone else said, try full finger gloves. Also, make sure your weight is on the balls of your hands and not on the valley between them. And watch out for the death grip. Your hands should be nice and loose. You should be able to move your fingers freely.
    Singletrack Snob
    Reputation: Vitamin G's Avatar
    I have the same grips and really like them as well. No blisters. using full finger XC gloves with minimal padding in the palms. Sounds like you are holding the grips too tight. Relax your fingers and give that a try.
    "I've got a card in my spokes, I'm practicing my jokes. I'm learning!"
    Ergon Bike
    Reputation: ERGON's Avatar
    Nov 2006
    Few items to note....
    When you ride with Ergon grips, you need to relax. You almost need to relearn how to hold onto the grips. One word....relax.
    Also, with gloves, make sure they have little to no padding and are not too loose fitting.
    Jeff
    Ergon USA
    Apr 2005
    I did another ride with it. and it seems to be feeling a lot better than before. I did have to adjusted again..... more horizontal . I would say like -5 degree.
    hope that helps..
