Results 1 to 5 of 5
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    Eggbeaters 4ti to Eggbeater 11's?
    Hello all,
    Quick question. I sent my 3.5 yrs old Eggbeater 4ti's into CB to have the springs replaced as there was a fair amount of play. They are replacing the springs under warranty and charging me $20 for the rebuild service.
    Under their upgrade program I can get a new set of Eggbeater 11's for $170. Cheapest I can find these is $299 through Pricepoint.
    For those of you that have experience with both is the new version that much better?
    I noticed the new ones have a higher weight limit (200 lbs) vs 185 lbs on the old ones. Not a major concern as I weigh from 165-173 depending on time of year, but I suppose I'm near the weight limit "geared up" on my old ones depending on time of year. I thought I had heard of the old 4ti spindles snapping, so a new set would certainly give me some piece of mind. I have logged a fair amount of miles on them in the past 3.5 yrs.
    Anyway, ultimately, trying to justify if I should spend the $170 for a new set.
    Thanks in advance!
    i have both and feel that the new ones are superior in both engagement and friction.
    Try to be good.
    Has skills-will travel
    I love my 11's, you actually notice less friction from the needle bearings instead of the standard bushing CB usually uses for egg beaters. I just clean and grease my spindles when I wash my bike to keep the needle bearings happy, I have heard of people having problems with them. Yet, after about 30 races on them - and I don't know how many rides - they still work like new for me.
    Eggbeaters are the bomb!
    anything that eliminates that troublesome outboard busing would be a plus
  1. 2011 Eggbeater 11's in the flesh
    By jbsteven in forum Weight Weenies
    Last Post: 07-18-2011, 04:51 AM
  2. Anyone using the new egg beater 11's?
    By Hardtailforever in forum Weight Weenies
    Last Post: 08-21-2010, 09:33 AM
  3. Buy now, or wait for the 11's
    By OMJustice in forum Downhill - Freeride
    Last Post: 05-16-2010, 03:45 PM
  4. Eggbeater Ti + Ti spindles or Eggbeater 4tis?
    By TabascoJoe in forum Weight Weenies
    Last Post: 04-30-2010, 12:11 AM
  5. Chain tugs for Sub 11's
    By eleser in forum Singlespeed
    Last Post: 11-16-2004, 03:51 PM
