Results 1 to 18 of 18
    Reputation: andrepsz's Avatar
    Jan 2013
    CO2 or pump into 1 1/8 steerer tube
    Little idea here...
    Carbon topcap with American classic tubeless valve cut to thread onto CO2 adapter
    Removing the Star Nut I have full clearance to fit the C02, fitting is perfect!
    For everyday use off race, Topeak Micro Rocket Carbon Pump fits perfect on 1/18 steertube
    Co2 setup is heavier
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Neat, but how much longer does it take to fix a flat?
    Also, do you totally remove your star nut? Or do you temporarily install a compression plug to preload your headeset?
    Raised in a Chicken-Coop by Chickens
    Fat & Single
    Reputation: ozzybmx's Avatar
    Great idea, don't know if I could be bothered though, its just as easy to carry them in my pocket.
    But I like it !
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Jan 2013
    Quote Originally Posted by Sheepo5669 View Post
    I have a lefty fork! Yes a used the star nut during installation but took it off later. The upper lefty clamp already does a great job tightening with the stem.
    1-Preload the bearing with topcap and StarNut
    2-tight lefty clamp
    3-tight stem
    4-top cap and Star nut...."Useless"...
    I WOULD NOT do the same with standard forks...
    Jan 2013
    Smile
    Quote Originally Posted by ozzybmx View Post
    But I like it !
    But you could forget the put your pump on your pocket someday!
    My bike has everything I need on board! worry free!
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Clever if it works! Yeh, the "where to put the pump?" would be solved with this. Perhaps in the future, there could be a really clean and user friendly way of doing this!!
    Jan 2013
    Again, I'm doing this with a lefty fork (upper fork clamp+stem tightening). I don't recommend this with standard forks.
    mnoutain bkie rdier
    Quote Originally Posted by andrepsz View Post
    I doubt anyone will remove the bolt and then pound out the star nut to try this on normal forks....geez...hope not.
    Jan 2013
    Right! Hope not...
    Newb
    Apr 2016
    Quote Originally Posted by rydbyk View Post
    I saw this in the latest "Bike" magazine issue and searched to see if there is a "homemade" way to do this. It's called the Everyday Carry (EDC) by OneUp. Pretty cool:
    CO2 or pump into 1 1/8 steerer tube-oneup-components-edc-tool-storage-capsule-side-grn-966_1024x1024.jpg
    Oct 2007
    Quote Originally Posted by StuartTX View Post
    I've got this system on order. I've collated all the info into a blog post
    https://seekerbikes.com/2017/05/27/o...now-available/
    The top cap / star nut replacement system is neat but unfortunately I don't think an actual CO2 inflator is in there
    I'm going to carry that with my tube in a swat xc box. Others use a strap
    OP - looks super cool btw
    Jan 2013
    I like it. Pretty daring having to create a thread to install the system, wondering if that tool to open the thread comes with it?
    Oct 2007
    There is an option to buy the tap (thread tool) at purchase. The top cap uses the same tool as a cassette I believe plus there is a suitable tool on the multi tool too
    Jan 2013
    Quote Originally Posted by iggs View Post
    Happen to know the price of the tool only?
    Oct 2007
    $35USD
    Jan 2013
    $35USD
    I like this solution not only for the intended purpose but its also something interesting for weightweenies! isolating the idea of threading the tube apart from the system...it does shave that 1g....and the lockring its also lighter than any lightweight starnut, looks pretty cool and can be customized with any lockring at the rider's preferences, very nice!
    Oct 2007
    I'm really looking forwards to getting my hands on mine partly so I (well the weight weenie nerd in me) can check how much the different parts weigh.
    Yes there is removing the top cap and star nut but then also adding the weight of the tool carrier itself
    It is also going to be interesting on how well the threaded steerer functions for tightening up the headset
    The tools still haven't shipped yet. International orders like mine are coming out of the uk. I emailed them at the beginning of the week and they said 2 weeks
    Jan 2013
    Yeah I meant to really separate both ideas. The threading and lock ring as one idea to replace topcap+bolt+starnut is the isolated interesting concept for that scale shot, wish is obviously done without the tools, bottles, etc....
  1. Tapered steer tube vs 1.5 steer tube
    By jsc3582 in forum Shocks and Suspension
    Last Post: 06-29-2013, 06:38 PM
  2. Tapered Steer Tube vs Straight Steer Tube
    By maw77712 in forum General Discussion
    Last Post: 05-24-2013, 10:28 AM
  3. Old 1.5" Steer Tube vs Newer 1.5" Steer Tube
    By cda 455 in forum Cannondale
    Last Post: 07-26-2012, 04:28 AM
  4. How much steer tube is too much steer tube?
    By ridewiththedarkside in forum Beginner's Corner
    Last Post: 02-06-2012, 08:07 PM
  5. Can I get away with a shorter steer tube?
    By guggas in forum Shocks and Suspension
    Last Post: 02-10-2011, 04:54 PM
