Results 1 to 37 of 37
Thread: Bar Ends?
    Bar Ends?
    I used to run bar ends on all my bikes back in the late 90's when they came stock on bikes but switched to riser bars when they became the standard. I am thinking about going back to a flat bar with bar ends on my race bike after seeing a few guys running them over the weeked at a race. What are the pros and cons of switching? I don't need the 1" of rise I am getting from my riser, I know I might add a small amount of weight but I am not concerned with that.
    if you like 'em run 'em. I've seen carbon bar ends if you're worried about weight.
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Cons: style and weight
    Pros: style, great leverage and power position when climbing out of the saddle, multiple hand positions available for extended XC
    W/ the advent of FS, seated climbing became the norm. Standing and cranking/torquing a FS bike up a hill is quite inefficient. So the need for bar ends died with the popularity of FS bikes. Uber wide gullwing handlebars provide better leverage for seated climbing than a narrow xc bar w/ bar ends.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Im on a single speed equipped with fsa slk 620mm carbon bars and titec micro bar ends.
    The 620mm bars without the ends are worthless for extended climbs but with the bar ends it makes a huge difference. And I am always out of the saddle yankin on em.
    The weight is also comparable to wider bars without ends.
    Niner carbon bar- 175g
    Fsa Slk 136g + ritchey wcs 65g= 201g
    So 26g weight penalty with about 8 cm more "tree clearance" and multiple hand positions.
    Raised in a Chicken-Coop by Chickens
    The race I just finished had some long but gental climbs, they were long enough that I was wishing for bar ends.
    What is the thoughts on the 11 or 17 degree sweep on some of these flat bars? I think the norm was like 5 degree in the past.
    By the way I just switched from a FS XC bike back to a hardtail for the first time in 5 years so I am re-learning how to ride a hardtail efficiently.
    I've run bar ends for several years now via the GX2's. They aren't the lightest bar ends around but the comfort keeps me riding longer. I've found that since I went to a hard tail this year I use them a lot more for climbing out of the saddle.
    Reputation: cabbgage's Avatar
    I use them for seated climbing on my hardtail, they seem to help leverage a bit, also i think it is good to move about a bit, helping you core and back. Down side is if you catch one on a branch or sapling on a steep single track downhill!
    Reputation: limba's Avatar
    I LOVE my barends. I use them all the time. Put them back on your bike and decide for yourself what you think.
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Ohhhhhhhhh noooooooooooo
    go here for "opinions":
    http://forums.mtbr.com/endurance-rac...ys-566274.html
    IMO, those who rarely stand and climb will not see a huge benefit to bar ends. I stand quite a bit (got in habit from SS days and road biking) and hate the feel of climbing out of saddle w/o bar ends. When standing/climbing, w/o them, I feel like a t-rex on a bike
    Nearly everyone I watch stand and climb w/o them looks like said t-rex..aka..awkward.
    When standing on a climb on my road bike, I go to the hoods for this exact same reason
    .02
    Helmetless Crasher
    Quote Originally Posted by richmondrider79 View Post
    The ends will be more succeptible to getting "hung-up" on things as, depending on the type of end, they may be slightly splayed-out on bars w/ that much sweep.
    That is the only true "con" I can see to using ends (and that's only w/ a super wide swept-back bar). Otherwise, the added hand positions made available by them, alone, makes them desireable.
    their absence is largely dictated by fashion, me thinks (but I happen to like the look of horns" on my bikes)
    I like 'em too.
    I went for a long ride yesterday on my new Stumpjumper HT and it's going to have to get bar ends. I need the variety of hand positions, especially when climbing.
    I would never ride a HT without bar ends. I have had them on my bikes since my first pair of Onza's back in early 90s. Along with the standard pro's, I have found a new one - they help with my tennis elbow.
    On a side note, even though I don't use bar ends on a FS bike, I still climb out of saddle a lot. I love my Special Ed brain shock
    Got rid of the bar ends after changing from rigid to suspension fork. Don't like to stand so much now and just don't feel I need them anymore. Also much more space on the bar now for the hands.
    Reputation: rob_co2's Avatar
    I used them in the 90s, went FS and got rid of them, also considering going back now that I'm a steady HT rider again.
    I think the course has a lot to do with it, if there is no sustained climbing there is no point. However, I do find L-bends useful on flat road sections- I learn forward and get into a comfy aero position.
    Reputation: BORDERCOLLIE's Avatar
    its a fashion thing, I run shortie bar ends on FSA low riser bars, gives me great leverage on my hardtail, and hand relief.I read an article awhile back in MBT action and they inspired me to go back to bar ends, said they still are useful fro certain types of riding.
    Reputation: Crankout's Avatar
    Jun 2010
    One word: Sauser
    If the top pro runs them, then you should.
    Stick around if you're housebroken...
    Oct 2007
    Early this year I wrote a short blog on the advantages or bar ends. Check it out!
    alloycowboy
    bar end on the Tallboy
    Is it weird? I put a pair of bar ends on my Tallboy for the 24hr race this weekend at Conyer Horse park. I LOVE bar ends on all my HT SS and gears bikes. I haven't try it with the fs yet. We'll see. I love the different hand positions and the leverage when going up hill on the SS. I'm so used to it that climbing without bar ends feel really weird.
    12' Sir9 Rigid
    11' Jabber Rigid
    10 SJ SS rigid
    10' Swork SS 29er
    10' Tallboy
    08' RM Vertex SS
    I have had 2 shoulder surgeries, each time I went through 6-8 weeks of physical therapy. If you have ever been through physical therapy with a shoulder injury you most likely did arm lifts with light weights and you did it so that your thumbs would be pointing up when your arms are out in front of you. The point is your shoulders, arms and hands are more natural in that position like you would be with bar ends. Had I had bar ends on my bike during one of my rides I most likely would not have injured it when I pulled up hard on the bars to come out of a ravine. Both my Orthopedic surgeon and physical therapist agree that bar ends are good to have.
    Still learning how to keep the rubber side down.
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by snellvilleGAbiker View Post
    Conyers would suck for a 24 hour race! Last time I rode there, the trail was fun, but it was seriously rough. I cant wait to go back to Atlanta and ride my home trails.
    As for the bar ends, I swear by em, but i actually took em off for the "dead dog" Trussville AL race this weekend. Short punchy climbs dont warrant bar ends. They really shine on the long extended/steep ones.
    I got rid of mine on my last bike after I took one to the kidney and whizzed blood for a week lol. Probably not the greatest reasoning but I feel alot more comfortable now.
    2010 Giant Yukon FX
    Pure XCR Wheelset/Geax Saguaro Tires/Tubeless
    Bike Weight Lost: 2.48lbs (1124g)
    Oct 2007
    I have ran bar ends since '96. When I bought my Epic in '09, I tried the stock riser bar without bar ends for a coupe rides, but just didn't feel right with that set up. Bought an EA70 flat bar, a set of bar ends, and have been very happy since.
    Most of my climbing is seated, and as mentioned, the position of my hands/arms feels more natural to me with a flat bar & bar ends.
    Chris
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Mine came off in about '99. End of story.
    I don't rattle.
    Reputation: Spinning Lizard's Avatar
    Quote Originally Posted by Berkeley Mike View Post
    +1
    I still sometimes just grab the end of the bar (without barends) for short periods and it gives me a few seconds to change positions during long races.
    is turning a big gear
    I think I would like to try the Ergon's someday. The website says they are not compatible with carbon bars, but there are probably many riders that use them that way.
    Get it unlocked.
    Oct 2007
    Obviously bar ends aren't for everyone. For instance if you like riding slow technical trail or use a ski lift then bar ends won't be very useful to you. But if you ride long marathon and XC type rides then bar ends are a great help.
    @estabro, Ergon grips are really heavy and have to be use with handle bars that can handle clamping at the end of the bar.
    Another option is using "Specialized Bar End Plugs".
    http://cdn.specialized.com/OA_MEDIA/...Bar_End_r1.pdf
    mnoutain bkie rdier
    Quote Originally Posted by Spinning Lizard View Post
    +1
    You should remove your brakes too. Just jam your foot up in there..
    mnoutain bkie rdier
    Lots of folks race XC and endurance with them today. Start of story. To imply that they are "so 90s" is silly.
    Perhaps that is not what you were implying...
    Again, they are NOT for everyone. I think that bar ends are most beneficial for certain styles.
    An XC racer, for example, that does not stand at all, would not benefit much from bar ends..
    Everyone I know that climbs on their road bike, will go straight to the hoods when standing. Same concept here. Pretty simple imo..
    What I use are these..pretty darn minimal!
    Oct 2007
    Quote Originally Posted by rydbyk View Post
    While your at it Mike, you should remove the saddle and drive-train to. Who needs to pedal and sit down when they ride, that's for sissy boys!
    mnoutain bkie rdier
    Quote Originally Posted by sopwithcamel View Post
    Why stop there. Just ditch the whole concept of steering too... Fwiw..that shock on the back is pure win imo. Pure win..
    A Baker St. Muse
    Reputation: michael573114's Avatar
    Quote Originally Posted by estabro View Post
    I have Ergons on my carbon bars. Dunno why they'd be "not compatible" though.
    Oct 2007
    No actually on second thought lets be cool and go with a "Boneshaker" 29er!
    Oct 2007
    Quote Originally Posted by michael573114 View Post
    If the carbon bars don't have metal reinforcement at the ends they have tendency to crack the and bars ends can spin when your honking on the bar ends. It's a really good way to hurt yourself so just be aware of it.
    mnoutain bkie rdier
    Quote Originally Posted by cxbamiriqbal View Post
    Hello.
    Thanks for visiting our forum Camp te koop
    Campingtekoop is de site waar u een overzicht **** vinden van campingen te koop binnen Europa. Kopers van campingen en verkopers van campingen komen samen op deze site. U **** uw camping te koop aanbieden op deze site door zich eenvoudig aan te melden via aanmeldingsformulier op de camping te koop site formulier. U **** foto's uploaden van uw camping en een beschrijving van uw camping.
    I will highly appreciate your comments and suggestions to make my stay in this forum effective.Best Regards
    Umm...lets start with:
    1. Leave. Now. Forever.
    Helmetless Crasher
    Depends on the bar and the bar end. Many super ultra light CF bars do not like bar ends. The clamping action causes the bar to crack at the site of the bar end's "slit". Often the crack is not readily detectable until something goes "wrong" on the trail.
    Some bar ends do this "better" than others. But to be safe, a bar end plug like the one depicted above is the way to go. I use a set from KCNC. Allows you to properly trq the bar end without fear of cracking the bar.
    I would also suggest that he use bar ends on a carbon bar. Let him know that it's a good idea to tighten the bolt REALLY HARD.
    Get it unlocked.
    Have used ergons on easton bars (ec70s) for over 2 years now. I like having the multiple hand positions. I have had some bad wrecks and put some miles on the bars with no signs of wear or stress from the grip clamp. The carbon end units are worth a little more weight to me from a comfort standpoint and are not much heavier than other clamp on grips. ESI's are a very different story and different grip. Carbon paste and a torque wrench go a long way in making sure they do not damage the bar.
  1. Flat Bar vs Riser Bar? Bar ends? No Bar ends?
    By sperky in forum Endurance XC Racing
    Last Post: 10-30-2007, 02:05 PM
  2. bar ends or no bar ends? this ends the debate
    By jaycyclista in forum XC Racing and Training
    Last Post: 06-22-2007, 03:41 PM
  3. Bar Ends or No Bar Ends ? 24hr events.
    By Pedals in forum Endurance XC Racing
    Last Post: 04-05-2005, 10:07 PM
  4. Cable housing ends and Barrel ends
    By summitlt in forum General Discussion
    Last Post: 01-23-2005, 04:36 PM
  5. Flat or Riser? Bar ends or no bar ends?
    By martinman in forum Singlespeed
    Last Post: 06-26-2004, 12:30 AM
