Results 1 to 38 of 38
    Nov 2008
    4" FS Frame recommendations for XC racing
    I'm looking to gather opinions on what you guys think a worthy 4" full-suspension frame is for XC racing and general riding/training.
    I do have some guidelines:
    * No proprietary forks or front hub arrangements - I have a nice set of XTR wheels and a SID WC that I'm not willing to give up.
    * I'm not sold on VPP. I had a Spider and really disliked it - too many creaks, and durability issues.
    * Weight is obviously an issue. I have lightweight parts but I don't want to start with a 6.5lb frame. I'd like the total bike to hover around 22~23lbs with a full XTR kit, carbon bits for the cockpit and the aforementioned SID.
    * Funds are not unlimited, so "unobtainium" frames are out. I'd like to keep the frame under $1K.
    * Dimensions that I'm shooting for are: 18~19" seat tube, 23.5" top tube, 70~70.5 degree head angle and a 73~73.5 degree seat angle. BB height around 12.5"
    You suggestions / opinions are appreciated!
    mutaullyassuredsuffering
    Reputation: used2Bhard's Avatar
    Dec 2005
    Under $1000?
    I'm not sure what FS racing frame you will find for under $1000? On the balance of lower price/high performance I'd get either the ASR-SL Alloy or the AnthemX...I think both will be around $1600
    Free will is an illusion, people will always choose the perceived path of greatest pleasure.
    Nov 2008
    Price bump
    Okay, so frames are really more expensive since the last itme I shopped. Let's say a price bump of $400~500. Bringing the overall cost to $1500. I know a lot of people will mention the Yeti, it is noted.
    But what else do you guys have up your sleeves? It seems like all of the bike companies are applying to the theory that "more is better" and start most of their lines at 5" of travel and above....
    Dec 2005
    Tricks?
    In 4"-not-too-expensive-land, I can think of these...
    BlurXC - Just plan on a bit of maintenance
    Turner Flux - Heard nothing but good things...never been on one tho.
    RacerX alloy - Great bike, but not as good as the Yeti for some wierd reason despite the fabled Horst link.
    Orbea Oiz Alloy - amazing bike with wonderful suspension, but the chain stays stick out too far for pronated me
    Els Truth - is a great endurance/trail bike but awfully expensive for an alloy 4"er.
    Devinci Moonracer - Recent thread on it here...I had never heard of the thing Price?
    Alloy Scalpel with std fork so you can use your wheels?
    Trek fuel - The new suspensions look pretty sweet. I didn't like the old ones at all.
    GT - They are trying to be hip and cool again...might be a bargain..suspension look wierd
    Fisher HI-Fi - a bit too much travel for me, but raceable
    Felt - More travel, heavier, but looks pretty cool.
    errr.... I'm sure there are others that you will hear about soon.
    Metalheadbikerider
    Reputation: free-agent's Avatar
    Kona
    Quote Originally Posted by skunkwerkscycles
    I ride and race the 2007 Kona King Supreme. It's a single pivot, so it is less active than 4 bar designs. It also requires less maintenance, and is pretty darn light as a scandium frame. If you can find one of those, it is worth checking out. Not sure about the 2009 line, but it may be worth checking out too.
    Support mtb'ing in the Portland area, join NWTA with your dollars, hands, and/or voice. nw-trail.org
    Superlight?
    How about an oldie but a goodie: Santa Cruz Superlight. Very low maintenance with the simple single pivot, relatively cheap, and a proven design that still works. You will benefit a Pro-pedal type shock though to keep it from bobbing.
    Quote Originally Posted by pmurrn
    +1 on the superlight, get a 08-09 model, i use it to race, ride, trail ride... if you don't like the vpp design and unobtanium frames, the superlight is the ticket for you.., climbs like a goat, handles great on the way down, light, proven design with little maintenance...
    Nov 2008
    Supalite
    Thanks for the recommendation on the Superlight. I wish they offered a medium/large because the medium is a bit small in the head tube and top tube. And the large is a bit long in the top tube and headtube.
    I know, I'm a tweaker...I do like the idea of the single-pivot though. Any other other single-pivot suggestions?
    Reputation: dirthead's Avatar
    Competitive cyclist has 2008 Turner Flux frames on closeout for $1199. Sounds like you'll need a medium from the 23.5" top tube length. I'm not saying the Flux is any better or worse than a Yeti AS-R or any other top end frame, but at $1199 it's a screaming deal, in my opinion. They have XS, S, and M in stock, according to their website.
    Reputation: millennium's Avatar
    Quote Originally Posted by free-agent
    I second the Kona. I've had the same frame as noted above, except with Easton aluminum rather than Scandium, and I love it.
    For 08 and 09, its the Kona Hei Hei supreme - which dropped to 2.5" travel.
    http://www.konaworld.com/09_heiheisupreme_u.cfm I've seen Hei Hei frames sell for $800-1000 on eBay.
    For 08, Kona had the Four Supreme for 4" travel.
    http://www.konaworld.com/08_foursupreme_w.htm
    For 09, I don't think Kona had a 4" version (2.5" Hei Hei or 5" OneTwenty):
    http://www.konaworld.com/09_one20supreme_u.cfm
    Finally, Kona calls their design a 4-bar design (see link to 08 Four Supreme above).
    Addictive website!
    TwoWheelTweets.com
    All of cycling's twitter tweets in one place!
    Oct 2007
    With all the specifics you have in mind, why don't you just get on the manufacturer's websites and download or print out the specs on their XC race frames? You have some very, very specific dimensions in mind and I don't think there are too many people out there who carry all this stuff around in their memory.
    If I were you, I'd look on the respective manufacturer websites for the frames for the Anthem, Epic, Top Fuel, Superlight, Racer X, Hi-Fi XC, and Spark. It sounds like you would be able to name all the companies for those frames. Most of them list the specifics of their bikes.
    Nov 2008
    Kona
    Quote Originally Posted by millennium
    Thanks for the recommendations on the Konas - the specs seem pretty good for the '08's. I totally overlooked these. Now the real question will be if any are available.
    Nov 2008
    Just testing the waters....
    Quote Originally Posted by Gatorback
    Hi Gator -
    I have done this for some bikes and I'm not asking anyone to give me fit technician advice over the internet. It's just nice to solicit opinion from others to see what develops and what I have overlooked. It's a chat board, so I'm just looking to "chat" about options..... For example, earlier up Kona was mentioned. I didn't consider them at all. Thanks for your input.
    LMN
    LMN is offline
    A couple of good suggestions here.
    Only one I am not wild about is the Kona. It doesn't have enough travel, if you are going to pack the weight and deal with flexiness of dually you might as well as get one with a decent amount of suspension. The modern shocks allow you to run a bit more travel.
    I am a big fan of the Norco Faze. Time test design that works really well. I have put close to 10 000km of hard riding on mine with no problems at all.
    Of course if you are really looking for a race bike go with a Hard Tail but as duallies go the Norco isn't bad.
    Go with the Turner Flux. I just had the rear shock Pushed, It now pedals better and is plusher in the rough stuff. I have had mine down to 23.5 lbs. Like the other poster said it is a great deal at 1199.00.
    Ed
    I'm very happy with my 2008 Rocky Mountain Element. It's the only FS I've ever ridden so I don't know how it compares with other bikes, but I do know it climbs awesome, has zero bob when the pro-pedal is engaged, makes me feel like a pro downhiller when pointed down and it looks like gold. Mine is a mostly stock 70 so it weighs over 25 lbs, which I sure notice on easy courses and the uphills compared to my 21 lb hardtail.
    No longer 26
    Reputation: G-Live's Avatar
    You could try to find a Gary Fisher Race Day frame from 2007. They only made them the one year. Only 3" rear though. I think the 29er versions were found to be flexy for some and that rep got them discontinued. I either do not notice it or it does not bother me.
    I think the Superlight would be a great pick. My recommendation would be to go with the Large and adjust the stem and handlebar to meet your fit needs (shorter, reverse angle stem and/or, flat bar instead of riser, with sweep if you need reach adjustment).
    After riding a 29er now for a couple of years, I wish I would have went wtih the next size bigger frame in my 26" days than the next smaller that I usually did. I find that stability and ride confidence far outweighs "flickability" now that I have experience with both types of frames. And I love the single pivot of my Supercaliber as well so I think I would really like the Superlight if there were no 29ers.
    G
    You can't depend on honest answers from dependant hands...
    offroader
    Dec 2008
    For under $1000 Racer-X hands down.
    edit: that can of worms picture is really gross.
    Quote Originally Posted by CupOfJava
    Where are you seeing Racer-X frames for sub-$1K?
    David B.
    Metalheadbikerider
    Got a local Kona dealer?
    They may be able to get past year frames easier than you can. I got my '07 King Supreme frame on Ebay from a guy that didn't like the geometry. It was like new and I paid $700 with front der., shipped.
    Nov 2006
    Quote Originally Posted by LMN
    i agree about the hei hei, i thought about getting one last year but decided that 2.5" of travel just wasn't worth it for the added weight of a FS bike. i ended up with a bmc fourstroke w/ 4" of travel since my shop also carried it. if kona would add another 1" or 1.5" i would prolly get a hei hei.
    Captain Underpants
    Reputation: Random Drivel's Avatar
    I'd go used, myself
    Flux, definitely. If the frame is less than 3 years old the warranty still applies. If you weigh less than 180 then a Nitrous might be worth a look.
    A used Epic might also be an option.
    Reputation: Flat Ark's Avatar
    Quote Originally Posted by Kris
    +1 on the Element. I have mine below 25lbs and can't imagine it getting much better. The shock location and the ease at which the propedal can be switched on and off while on the fly is an added bonus. Ebay is flooded with deals on 08's right now.
    Getaway Cycle Center
    Nov 2007
    another vote for the RM Element. Does it all while handling like a hard tail, especailly with a rear lock out. I have a race but built for durability not so much weight and comes in at 26lbs,with reba race uturn, CK hubs and other stuff. Rides great with 85mm and at 115mm. Point and shoot handling down a hill, tight rear during climbing, and great single trac turning. I have a superlight which is great also but more so when I am out with friends. The element is just fast.
    Reputation: StudioDino's Avatar
    My race bike
    for your consideration, the Specialized Epic (with XT rims).
    But my new 2009 Stumpjumper is pretty good too, lighter then my last one.
    www.StudioDino.com
    The Ride: 2013 Specialized Epic is epic / Roubaix
    Nov 2008
    Thanks for all of the suggestions!
    Thanks for all the help guys. My short list so far includes:
    * Rocky Mountain Element
    * Kona Four Supreme
    * Turner Flux
    * Giant Anthem X
    I'm not ruling out a Superlight, as I said the simplicity really appeals to me.
    Thanks again....
    Reputation: supermike's Avatar
    If you're considering the Superlight, you may also want to take a look at a Rush.
    RideSalsa
    Reputation: a_burnside's Avatar
    Dec 2008
    Salsa El Santo
    Just bought a Salsa El Santo for $700.00 from my LBS for the 2009 race season. Frame weight on the shops' scale reads 5.3 pounds, with RockShox MC 3.3 shock and seat collar, for my 16" frame
    PIN IT YA' FAIRY!
    Reputation: mtbmeister's Avatar
    Well, I will be the first to suggest the Giant Anthem X. I am very surprised to see that no one has this listed here. It's an 09' frameset and I don't know what they go for in the US, but are just over $1K up here in Canada. If you do a quick google on this ride, you will see it is kicking some major @ss in the review department as far as a do it all XC/Trail/Race bike goes. The frameset is 5.1lbs and built up with your XTR goods, you should have no problem being around the 23lb mark. My personal bias aside, this is a bike that should exceed the performance of most of the other suggestions here such as the Konas, Blurs, or other. Just my $.02...
    A bad day on the bike is better than a good day doing anything else...
    http://www.apexracephotography.com
    I raced a 22 lbs Nitrous during the last season - absolutely the best racing FS I've ever ridden.
    Can't image how good would be the Flux in the technical stuff.
    Get the Flux.
    flyMTBfish
    +1 on the RM Element. I would say this is the best IMO on your list. I would also consider a Racer X. Kona IMO had been a real good company in the past, just lost their grass roots. Rocky still and in the past made some killer rides.
    Don't Stop Spinnin'!
    Reputation: ReD_tomato's Avatar
    I have to agree on those who suggested the Santa Cruz Superlight. I've been racing mine for the past few years and love it. I even build another full xtr sl for christmas. low maintenance, very stiff (w/rp23), and super fast.
    the only other frame I have considered has been the titus racer x. I hear nothing but good things about it from those who train/race them.
    ~every end is a new beginning...
    RIDE TO LIVE
    Reputation: LIV2RYD's Avatar
    09 S Works Epic, good enough to win a world championship....nuff said.
    Reputation: protocol_droid's Avatar
    lightest 4"er is the spark (just under 4 lbs) they can be had on ebay or even hereLast two on ebay went for under 1100!
    3po armorless, the first weight weenie.
    Quote Originally Posted by mtbmeister
    Where can you get this frame for that price? LBS, or? I'm eally interested in the X!
    Quote Originally Posted by erik$
    They were $1200 up here, but that could have changed as I bought mine in October. What size are you? I have an X2 frameset new in the box with two rides on it. Not trying to spam this forum, but if you want more info or pics, shoot me a PM.
    Reputation: macming's Avatar
    * Kona Four Supreme
    * Turner Flux
    * Giant Anthem X
    Thanks again....
    I have an Element, and a carbon Top fuel. I have also ridden my friend's older Superlight. Granted the super light had an older shock, but it wasn't anywhere near plush or responsive compared to my two bikes. The suspension also bobbed a lot more than my Element.
    I'd go with an Element because it really rides like a hardtail going up, while the rear stays pretty active and plush when things get rough. The single pivot has been free of creaks and has been somewhat maintenance free.
    Give up the kids wheels and move up to a 29er.
    You will have more fun and be at least as fast.
    I recently got a Niner Jet9, with 3.1" rear suspension and 23lbs. Awesome. I have never ridden so much and so fast.
    But you need to keep it light, especially wheels and tires.
    You can see pics and review of mine at:
    My 23lbs Niner Jet9 is ready!!!!
