Wow! Been years since I've been here as a regular.
Looking to buy a new bicycle for my daughter. She would like to get into mountain bike racing with Dad. So I have been looking for a good bicycle for her to race with. What I am looking at, because of its light weight and excellent (for a kids bike) components, is the 2006 Hotrock A1 FS 24 21-Speed Girls. Anyone able to suggest where I might do better? Unfortunately metal prices have driven costs up.
Out the door it's pricing at $372.00 I haven't found a better price (shipping) online anywhere and the bike shops won't budge on price due to increased prices of metal.
FRAME Specialized A1 Premium Aluminum, double-butted TT/DT, CNC HT, formed DT, forged drop out, w/06 replaceable hanger
FORK RST Capa T6A, 51mm travel, alloy steerer, coil MCU spring w/preload adjusment, juvi spring rate
HEADSET 1-1/8" threadless
STEM Alloy A-Head, 1-1/8"
HANDLEBARS Alloy, flat, 6 degree sweep, 540mm width
GRIPS Kraton "Revo" type
FRONT BRAKE Tektro "V", linear spring, stainless steel pipe
REAR BRAKE Tektro "V", linear spring, stainless steel pipe
BRAKE LEVERS Tektro junior "V", alloy, linear pull compatible
FRONT DERAILLEUR Shimano Acera, 31.8mm clamp, bottom pull
REAR DERAILLEUR Shimano Altus, 7-speed
SHIFT LEVERS Shimano RS-41 "Revo" twist shifters, 3/7speed
CRANKSET Truvativ ISO-Flow w/alloy outer ring
CHAINRINGS 22t heat treated Cro-Mo/32t heat treated Cro-Mo/42t 7075 alloy
BOTTOM BRACKET Truvativ 68x113mm, square taper
PEDALS Dual sided, composite body, steel cage, toe clip compatible
CASSETTE/FREEWHEEL Shimano MFHG-37 freewheel 7-speed 14-28t
RIMS SUN CR-18, 24", 32h, double walled w/machined sidewalls, eyelets
CHAIN Shimano IG-31
FRONT HUB Joy-Tech, alloy hub and QR, 32h
REAR HUB Joy-Tech alloy hub and QR freewheel type, 32h
SPOKES 15g(1.8mm) stainless
FRONT TIRE Specialized Roll X, 24x1.8" blackwall
REAR TIRE Specialized Roll X, 24x1.8" blackwall
TUBES Specialized schraeder valve
SADDLE Body Geometry Kids MTB
SEAT POST Alloy, micro adjust, 27.2x300mm
SEAT BINDER Alloy collar w/ QR
NOTES Chain stay protector, Water Bottle and Cage, reflectors, clear coat, owners manual
High performance Specialized A1 Premium Aluminum frame with double-butted top tube/down tube, CNC head tube, and formed down tube RST Capa T6A 51mm suspension fork with alloy steerer and adjustable Coil/MCU spring
Lightweight alloy handlebars
Durable Truvativ ISO-Flow crankset with lightweight alloy outer ring
Lightweight SUN CR-18 alloy, double wall rims with machined sidewalls for improved braking performance
