Results 1 to 26 of 26
    Reputation: marpilli's Avatar
    Mavic Crossride Disc Wheelset - $99 @
    On-One and Titus USA Store — Mavic Crossride Disc Wheelset
    Shipping looks to be $35.00
    WAS: $249.00
    NOW: $99.00
    SAVE: $150.00!
    Entry level at Mavic always means quality, efficiency and reliability. Completely endorsed by the Crossride - an incredible value! A specific version of the front wheel makes it compatible with 15mm forks.
    Access to the Mavic quality - Reinforced rims: H2 compression - Hub quality: FTS-X freewheel, QRM bearings - Resistant straight spokes Access to the Mavic efficiency - Optimized component design - 15mm version down to 1850 grams Access to the Mavic identity - Large and visible graphics on the disc brake specific rim - Straight pull bladed spokes Rims: Color: black anodised Disc brake specific profile Drilling: traditional H2 technology Internal width: 19 mm Joint: pinned Material: 6106 Aluminum Valve hole diameter: 8.5 mm Spokes: Color: black Count: 24 front and rear Lacing: front and rear crossed 2 Material: steel Nipples: brass, self lock concept Shape: straight pull, bladed, section 2.0 Hubs: Color: black Front and rear axle material: steel Front and rear bodies: aluminum Front axle size:
    15x100 FTS-X, steel QRM Rear axle size: 9,5x135 Compatibility: Disc brakes: Center-Lock, delivered with 6 bolts adapters ETRTO size: 559x19C Front wheel mount: Quick Release or 15mm thru axle (2 separate wheels) M10 Rear wheel mount: quick release Recommended tire sizes: 1.5 to 2.3
    Delivered With: "Center Lock to 6 Bolts" adapter for the 6 Bolts version BR101 quick releases Rim tape User guide and warranty card Valve reducer
    Nice deal. Note the 15mm thru axle, probably the cheapest wheelset with a thru axle I've seen.
    Former Bike Wrench
    Quote Originally Posted by pinkston32 View Post
    Can be converted to QR front for cheap
    Mavic QR Plug- Fits 15mm Front Axle at Price Point
    Right. But it's not so easy to convert a QR to a 15mm.
    So if you have a 15mm thru axle and need a really cheap light wheelset, this is a great value. It also is if you use a QR and missed the last deal on Competitive.
    Heck this isn't even relevant to me. I'm still on those last cheap Mavic Crossrides from Competitive, with the QR.
    Just ordered a set. $134 shipped.
    Quote Originally Posted by marpilli View Post
    <iframe border=0 frameborder=0 framespacing=0 height=1 width=0 marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://tinyurl.com/27shlk6" vspale=0></iframe>
    <iframe border=0 frameborder=0 framespacing=0 height=1 width=0 marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://tinyurl.com/yz4gjyd" vspale=0></iframe>
    Great deal wow
    Is this hub one of those loud hubs like the hope pro2 ?
    Class Clown
    Reputation: dundundata's Avatar
    Quote Originally Posted by tavorh1 View Post
    You'll definitely hear the freehub when coasting if that's what you mean.
    All freehubs sound as loud as hope pro2s? By loud I mean significantly loud sound. Louder than normal.
    I had them for two years and they were the most reliable in that price range (MSRP). now they're only $99! go for it. Mine doesn't sound loud at all.
    Yup I agree, definitely not loud. Maybe your freehub needs grease?
    They certainly are light, especially for the pricepoint. Something like 1920g. And quite stiff. And they look pretty sharp, with the 24 bladed spokes. And they only got slightly out of true when I rode them.
    But not sure about reliable. In fact, I don't think they are at all really.
    Mavic Crossride Hub Defects
    I'm around 110lbs, and I managed that on standard XC riding. The hub design hasn't changed either. Not sure how strong these are, but I personally wouldn't say they're reliable. It happened over an off camber root on a more technical local trail (South Loop at Blankets, for anyone from N. GA) and I was going quite fast, but it shouldn't have broken a wheel. Not even a pinch flat with that, and I run my tires at less than 20psi tubed. Mavic CS was pretty good about it though, my LBS sent them back and I got another rear wheel.
    Class Clown
    Yeah that's a weird issue you had. I got 2 sets of the 9mm QR UB/disc version Crossrides back in the spring and rode 1 set all spring and summer. No babying lots of rocks/roots smaller drops/jumps and a couple crashes. The hub flanges still looks fine. I did just swap out for my second set because the other one was going out of true. I'm wondering if the tension from the factory just isn't that accurate or maybe you got a bad batch (I have seen other reviews with that problem too).
    I can't run anywhere near that low of a PSI with tubes but then again I weigh a good deal more.
    BTW these things are really easy to service.
    Aug 2005
    the crossmax are the higher end version, but do any parts cross over? might be worth buying this just for the parts for my SLR's
    good ski/bike deals at www.mntlion.com
    My life is better than your vacation.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mntlion View Post
    AFAIK the parts are not interchangeable between the Crossmax and Crossride. At best it would be the FH body. The hubs, spokes and rims are all different.
    The Crossrides would be a good backup wheelset.
    mtbtires.com
    Reputation: mb300's Avatar
    My (flyweight) girlfriend has been riding crossrides for several years now- no reliability problems and they take ghetto tubeless very well. $135 shipped is a bargain, we'd buy another set except she needs 20mm front axle now.
    Attached Thumbnails Attached Thumbnails Mavic Crossride Disc Wheelset -  @-air_dre_1.jpg
    -MitchB
    Now with 10% more!
    Reputation: Da Dook's Avatar
    Oct 2007
    ^^^^^^^^^^^^^^ Showoff
    Dirt Huffer
    Reputation: AC/BC's Avatar
    ^^^^ moar!
    mb300, you should post up some of those photos here: hot mountain biker chick passion
    PMarsh Thumbs Up!
    Reputation: StuLax18's Avatar
    Turns out my rear wheel (currently have the Crossrides) needed replacing, so I went ahead and ordered this set to replace both. Thanks for sharing the deal!
    2011 Giant Glory 01
    2013 Pivot Firebird
    2004 Turner Rail - Stoled
    I couldnt resist. Got a set. If these last a year, theyd be worth it
    Sep 2004
    Thanks, got a set to go with new Marz Micro Ti 44 fork from HucknRoll.
    May 2005
    Quote Originally Posted by K2D2 View Post
    Thanks, got a set to go with new Marz Micro Ti 44 fork from .
    Exactly what I did. Very nice upgrade for less than $400. Loving the stiffness of the 15mm vs. QR and the wheels arrived very true and evenly tensioned. Love the look (the 2012s are silver, bleh)
    WIsh the fork was a little more reactive on little stuff, tho Im running very low pressures (too low and the fork wont return to its full resting position).. Hoping Slick Honey and ride time will help!
    Attached Thumbnails Attached Thumbnails Mavic Crossride Disc Wheelset -  @-photo-9.jpg
    May 2005
    Weird -- on my iPad the photo looks fine, on the desktop they're rotated oddly.
    Dont know how to fix -- sorry.
    PMarsh Thumbs Up!
    Quote Originally Posted by mtnbiker72 View Post
    I couldn't use the front wheel because it was the wrong size, so this is all I need right? I have 6 bolt disc brakes also, but I think it only came with one conversion, and that was used on the rear.
    2011 Giant Glory 01
    2013 Pivot Firebird
    May 2005
    That should be all you need to run a QR wheel -- and apparently another Centerlock adapter.
    I like Squishy Bikes
    Reputation: Hollis's Avatar
    Got mine
    I had quite a few years on my old Crossride wheelset, then the cassette started to wobble.
    I researched a few options:
    $60 for the shop to install a new cassette body.
    $16-$40 bucks to buy a bushing kit on eBay.
    MAVIC FREEHUB .003 O.S. BUSHING & Ball Bearing Kit | eBay
    So, for $135 I got 2 new wheels, $67.50 a piece & I'm back on the trail in style. I love MTBR
    Attached Thumbnails Attached Thumbnails Mavic Crossride Disc Wheelset -  @-crossride.jpg
    A dirty book is rarely dusty
  1. Mavic Crossride Disc Wheelset - $99
    By willywilly in forum Where are the Best Deals?
    Last Post: 08-19-2011, 05:49 PM
  2. Replies: 20
    Last Post: 04-21-2011, 10:44 AM
  3. Mavic Crossride Wheelset - $149.93 at REI
    By racer in forum Where are the Best Deals?
    Last Post: 02-12-2008, 06:59 AM
  4. Mavic crossride wheelset
    By noamwax in forum All Mountain
    Last Post: 04-09-2007, 11:08 AM
  5. Mavic Crossride Wheelset
    By Kaotic in forum Wheels and Tires
    Last Post: 12-01-2006, 09:18 PM
