Results 1 to 12 of 12
    Reputation: ZmyDust's Avatar
    Quote Originally Posted by ZmyDust View Post
    $699
    3x10
    175mm crank arm
    11-34T cassette
    Killing it with close inspection.
    Its an M980 rear derailleur, not the M986 Shadow+ clutch model.
    And a 34T cassette as noted by FireLikeIYA above.
    I won't budge from 36T and clutch der, so unattractive to me even at this price.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    I'd only do it, if that was 2x10....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Binned
    Nov 2008
    It's an excellent value for somebody who wants to remain old school and needs to replace their drive train.
    Reputation: peteer01's Avatar
    Apr 2005
    Quote Originally Posted by Hawg View Post
    I would include me in that group. I needed a new crankset a few weeks ago, and won't give up the third ring because I ride my 29er with road wheels for commuting. If this deal had been out when I was shopping for a new crankset, I almost certainly would have jumped on this.
    The 3x10 wouldn't bother me at all, and I would have preferred 36T, but I'm woefully ignorant of the difference between the M980 rear derailleur and the M986 Shadow+ clutch model.
    Can someone explain the difference and why someone would pass on this because it's not the M986?
    Quote Originally Posted by peteer01 View Post
    Clutch model derailleur's have an extra tight spring in them that keep the chain as tight and secure as possible on the rings. Because of the stronger than normal spring, its also a bit more difficult to remove the wheel because its holding on so tight. The "Clutch" is basically just a button that holds the derailleur cage forward, compressing the spring, loosening the slack in the chain and allowing you to take the wheel off easily.
    Putting the two factors together, my feeling is clutch style derailleur's only became necessary when the 1X trend became popular and it was necessary to more effectively keep the chain on the single front ring. If you were interested in this package, you'd likely be using the 3X drivetrain and not require a clutch derailleur.
    Also for what its worth, it looks like the sale is no longer available. The price has been increased to $799 and where it requires you to select size, there are no selections left available. Hopefully somebody has some shiney new parts on the way.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Putting the two factors together, my feeling is clutch style derailleur's only became necessary when the 1X trend became popular and it was necessary to more effectively keep the chain on the single front ring. If you were interested in this package, you'd likely be using the 3X drivetrain and not require a clutch derailleur...
    Clutch derailleur is awesome... so much quieter, even without the clutch engaged. I run the M986 3x9 with a SRAM XO 9-speed trigger shifter on my hard tail. It is ridiculously quiet compared to an X9 9-speed derailleur on my full suspension bike. I've purchased a second M986 to install on this bike in fact...
    The other item worth noting (for those in the market for 2x10) is the M985 is much nicer crank. I scored a set of 175mm's off Chainlove for $200 a while back...
    【ツ】 eDub 【ツ】
    Apr 2005
    Thank you very much for the detailed reply. That is definitely helpful.
    I wouldn't be surprised if the set is gone forever, but if they keep the set available at $799 and then have one of their sales that apply to any order over $XXX, it could be a great deal with the right promotion at some point in the future.
    Apr 2005
    At least temporarily, you can select 175 and add it to your cart. With the right promo, this could be a great deal for the right person later this year.
    The XTR build is still available and the 15% fathers day discount works. Price is 679.85
    Apr 2005
    Quote Originally Posted by mmmm View Post
    Exactly the kind of deal I had in mind. Free shipping too. I'd grab it if it were 2x10.
  1. 10 speed chain used on full XX1 drivetrain
    By Laterilus in forum SRAM
    Last Post: 07-10-2013, 04:47 PM
  2. pricing full XTR drivetrain
    By cunningstunts in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-02-2013, 05:11 PM
  3. Full drivetrain upgrade with shimanoXT,9speed or 10 speed?
    By zambon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2012, 09:24 AM
  4. Another drivetrain question- drivetrain noise
    By Streetdoctor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2012, 01:50 PM
  5. Drivetrain issues - please help - x post from Drivetrain
    By yohyat in forum Downhill - Freeride
    Last Post: 01-03-2011, 08:30 AM
