Results 1 to 17 of 17
    Laker and a Trail Blazer
    Reputation: Broncstad's Avatar
    Deals on xt brakes
    I've been looking for a set of brakes. Have you seen any with a great price?
    Deals on xt brakes
    $95 for SLX, $120 for XT, $200-$220 for XTR.
    http://m.steepandcheap.com/steepcheap/gear-cache/1979
    For XT with the finned pads and no rotors, the best I've ever seen is $95 and you can find them for $129 many places, so that's your range.
    Best current source I know of is wiggle.com (UK supplier). Using the 12-EXTRA code you can get XT brakes for ~$98 each. But you will need to add another minor item to your cart to reach the $237 minimum spend for that code (pre-discount pair of brakes only gets you to $224).
    Free shipping to the US with that spend level, and typically VERY fast. I got my last order from Wiggle in 4 days.
    BTW, don't skimp on the rotors. In my opinion, the ice-tech rotors are worth every penny because they dissipate heat so well. Not a marketing gimmick from my perspective . . .
    Deals on xt brakes
    Quote Originally Posted by InertiaMan View Post
    I want to order two sets and 3 icetech rotors, adapters. I ride with front brake on the left and rear on the right, they don't have this set up in stock.
    Assuming you can live with black rather than silver, its still a viable option. You'll almost certainly be cutting the hoses, so just swap the levers when you do the cutting. Using the no-bleed method of shortening these XT hoses it adds no complications or risks to swap the lever/caliper combos.
    Depending on your rotor size preference and your mailing address, Bluesky might be an option. They have the finned XT brakes for $119 with adapters, the unfinned XT's for $89 (front silver only) and they have the new RT67 rotors pretty cheap (if you're running CL mounts).
    Deals on xt brakes
    Went through wiggle and got xt front and rear brakes and 160mm rotor and 180mm rotor for $274 to the door! Thx
    Hisforever
    Reputation: SHAHEEB's Avatar
    Dec 2004
    did the same but the price went up slightly. $300 to my door.... super quick shipping
    box was barely still together tho....got lucky all was there
    Jesus Saves
    Reputation: rzims's Avatar
    I just ordered these (F&R without rotors) from wiggle with no discount code (expired) and it came to 223.00 delivered
    Hisforever
    Dec 2004
    hopefully you get the right ones. mine came effin moto style,
    Jesus Saves
    Shaheeb,
    They came moto style because that this the preferred style in the UK, so that's what retailers stock.
    But don't sweat it -- unless you're on a HUGE bike, the hoses will be way too long, and you'll need to trim them anyway. When you trim them, just reconnect to the opposite levers. Voila.
    Hisforever
    Dec 2004
    dont you need new 'olives' or can they be reused after the lines are cut? just pull the old olives out and insert them to the fresh cut lines?
    still have to rebleed the brakes. i hate bleeding brakes. had the worst time trying to bleed formulas....
    Jesus Saves
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Yes you need a new olive.
    You may not even have to bleed the brakes when just shortening the hose.
    New Shimano brakes are easy to bleed. Just make sure you get the bleed cup.....I bled tem without the cup and it is doable, but messy.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Did the brakes come in a retail box? Or OEM bag?
    All the boxed XT brakes include an olive and barb insert for use with the shortened lines. And the yellow blocks to clamp the hose for cutting and inserting the barb.
    Like mtnbikej said, many people have been able to shorten these without bleeds. I've done 6 brakes so far and haven't needed to bleed. Do some searches -- there's a bunch of discussion on that process.
    Hisforever
    Dec 2004
    thanks so much guys, feel better about it now. wont be sending these home to the euros after all!
    cheers
    Jesus Saves
    received the brakes yesterday - 5 days from order to delivered, NICE.
    Yes, they came in the retail box - I didn't notice if there were extra olives and barbs...
    Shortening the hoses on these is a pretty simple affair and I haven't had to bleed on my previous installs.
    Great price, great service!
    Hisforever
    Dec 2004
    Found one set of barbs for two brakes so I used a formula barb/olive for one and the provided shimano for the other, pretty easy for sure.
    One brake feels slightly different than the other. ( little mushier)
    good deal for sure!
    Jesus Saves
    Nashbar price is the same as wiggle right now. Use pricematch at Jenson to get free shipping. Backcountry will pricematch with free two day shipping as well but they have resin pads.
  1. deals on SLX or XT brakes
    By stygz1 in forum Where are the Best Deals?
    Last Post: 02-15-2015, 03:23 PM
  2. anyone know where the best deals are on xt/xtr brakes?
    By goodmojo in forum Where are the Best Deals?
    Last Post: 12-15-2012, 08:59 AM
  3. Any Deals on brakes?
    By loginhater in forum Where are the Best Deals?
    Last Post: 10-10-2012, 10:07 AM
  4. Pre 2012 Model for Shimano XT M775 Brakes Deals?
    By sneakyt in forum Where are the Best Deals?
    Last Post: 08-16-2011, 11:20 AM
  5. Deals for Hope Tech X2 Brakes?
    By myitch in forum Where are the Best Deals?
    Last Post: 02-03-2011, 06:23 PM
