Results 1 to 41 of 41
    100% recycled
    Reputation: afie's Avatar
    Cheap steel frames?
    I am looking for a cheap hardtail. Preferably steel for 29" wheels. Also, anyone know any cheap custom builders?
    There was a similar thread on ti frames a few weeks ago, but I need something cheaper.
    enjoying the kool-aid
    Reputation: Chewieez's Avatar
    You need to quantify what cheap is to you.
    You can look into
    Soma (inexpensive but not custom)
    Gunnar ( alittle more $$ but possible custom)
    Waterford (more $$, same guys as Gunnar but custom)
    Independent Fabrications ($$$$ but nice guys who used to make Fat Chance)
    There are many many more custom steel builders.
    What is cheap to you? $500 for the frame? $750? $200?
    100% recycled
    Less than $500.
    Recent searching has turned up:
    Redline Monocog 29er $250
    Zion 737 $250
    Soma Juice 29Er $429
    Surly Karate Monkey $430
    Voodoo Dambala 29" $410
    Salsa Ala Carte 26" $500
    Soma Groove 26" $320
    I would like something with decent steel, but the cheapest 853 frame I have seen is $750. Salsa Ala Carte has true temper ox plat but is 26".
    Apr 2005
    Nashbar has an 853 steel frame for a great price ($400 before discounts). It takes 26" wheels though. Check it out.
    If you can't go fast with a $500 bike, a $5000 bike won't help you.
    Quote Originally Posted by afie
    Less than $500.
    Zion 737 $250
    From your list I would recommend the Soma in a heartbeat. I have their 4one5 frame made from 531 and it rides great! I don't know anything about the Voodoo but I'd recommend the Soma over the Redline, Zion, and Surly.... I think the steel and geometry is better...more compliant. The new Soma's are Tange Prestige steel, but you may be able to find a 2005 Juice in 531.
    If you want to spend more than check out the Salsa El Mariachi frame and fork MSRP $930 in True Temper OX
    http://www.salsacycles.com/frames_06ElMariachi.html
    If you decide to go 26 inch I also recommend the Nashbar 853 frame-especially if its on sale or if they have a 20% off coupon.I paid $235 after discount/on sale about a month ago and I am stunned by the paint and workmanship for the price.I have not built it up yet so unable to comment further.
    Reputation: logbiter's Avatar
    add on-one & kona to your list.
    figure out whichever one will fit you best!
    100% recycled
    Zion 737 $250
    Soma Juice 29Er $350
    Nashbar Signature 853 $400 (26")
    Salsa Ala Carte 26" $500 (26")
    Soma Groove 26" $320 (26")
    Jamis Dragon $660
    on-one is 250 pounds plus 160 shipping to Australia. A poor exchange rate means this is way too expensive
    kona unit or explosif?
    I can only find the unit on Konas site ($500) but they wont ship it to me as there are distributors in Australia. If I get it here, it most likely wont be as a frame, and I will pay through the nose.
    As for fit, I am aiming for the largest size and hoping it will work.
    Is there $100 (40%) difference between the Juice and Zion?
    Reputation: shiggy's Avatar
    Dec 1998
    The Monocog 29er 853 will be available later this fall. Under $500 for frame and fork.
    mtbtires.com
    Out there
    100% recycled
    Quote Originally Posted by pinkheadedbug
    In an effort to reduce component costs I have been looking at singlespeed. But with singlespeed comes problems with track dropouts, rear disc brakes, quick releases etc. The Q Ball may solve these problems. I will research tomorrow.
    Zion 737 $250
    Q ball $430
    Monocog 29er 853 <$500
    try Kelly bikes. They are having a going out of business closeout sale.
    Dec 1998
    Zion 737 $250
    Q ball $430
    Any SS frame with an EBB or sliding dropouts has no issue using disc brakes or QRs.
    I do not see the Q-Ball design as being in the categories above. Still basically a track tip with a disc mount.
    mtbtires.com
    100% recycled
    Quote Originally Posted by shiggy
    Reading the singlespeed faq, it seemed that with track dropouts if you change your cog you then have to adjust the discs. I am probably not interested in a flip flop hub and would leave the cog once set up, but I would like the ability to change thing easily or go to a geared system. Can you set up gears on a ebb bike?
    The faq also states that a quick release may not be strong enough with track dropouts, though on Harris Brown it says that shimano qr's should be okay.
    Kelly does not have any frames in my size left, and I didnt think he had any cheap Ro Shom Bo's anyway.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Hi Afie!
    Sure you can run gears on an EBB bike (as long as it has a derailleur hanger, and you have a cassette rear hub). I have a Zion 853 and, while not being as "cool" as other brands, it gets the job done and fairly well I might add. I personally love the EBB setup, there are alternatives, but I prefer EBB.
    Cheers,
    Cris
    Reputation: CDtofer's Avatar
    Zion 737 $250
    Alfie,
    Would you be will to share where you are seeing the Juice for that price? I have always seen it over 400. I am looking at it myself. I am not sure if I can help with your question about the price difference but I can mention a few things. I have never seen a Soma in person but everyone that has one raves about the paint. I have seen a Zion and while I great functional frame, its no looker by any means. So if appearance matters to you, maybe the Juice would be worth the extra cash. Also one thing to be aware of, the Juice has dropout spacing halfway between road and mountain and is supposed to be able to take either a road a mountain wheel. One more reason I want one but this may or may not be a benefit to you.
    Cheers
    Chris
    100% recycled
    Quote Originally Posted by CDtofer
    http://www.fullcycles.com/product_in...roducts_id/527
    Already have a roadie, so no need for road compatible dropouts.
    I suggest you call them, they might be able to offer you an even better deal over the phone.
    Try to talk to Will or Gary, they will hook you up
    Cheers,
    Cris
    Out there
    I finally chose the SIR9 from ninerbikes.com (actually I got it from bike29.com) which is 853 with an EBB and $799. I was looking at the cheaper frames but when I realizes how much I was spending on componentry I figured the bike was becoming unbalanced. Waiting for it to arrive. By using the SRAM X.9 build kit from pricepoint.com I was easily able to keep the bike under budget.
    100% recycled
    Quote Originally Posted by crisillo
    Cheers,
    Cris
    They also have the On-One Inbred 29er for $350
    Zion 737 $250
    On-One Inbred 29er $350
    Q ball $430
    100% recycled
    I am thinking of going singlespeed to save a little bit more on components that I can then spend on the frame.
    I'm running a Soma Juice 3x9 with standard Shimano QR hubs & skewers and have had no troble with the track drop outs. If I was to go 1x1 on this frame, would recommend a bolt on rear axle becaus of the chain tension and torque of a singlespeed. I am switching over to XT m756 discs with XT skewers and Avid BB7s and I don't anticipate any issues. I never had a problem with my Santa Cruz Chameleon and LX skewers either. Just avoid cheap skewers with horizonal drops.
    - Scott
    I love the smell of Lemon Pledge in the morning...
    Spec?
    had to log in and forgotten your login, so, pink headed pig, what is the full spec of your build - thinking soma juice, but there's too much choice in components.
    wheels is a tough choice....
    shimano SLX or sram x9/x7, or mix, or xt
    fork, rigid, but which
    stem/bar/seatpost - bontrager, nice traditional choice for rigid??
    tyres....
    even frame - whats the niner like?
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    I'd vote for the Soma - my Soma Groove has been retasked as a hardtail SS and it's a fantastic ride.
    Very good quality for the price.
    JMJ
    I've got the Soma Juice, Groove & 4one5 single and I would agree that the Groove gets my vote. Here's my latest Groove...
    - Scott
    Now with 3 more inches!
    Reputation: tigerdog's Avatar
    Damn, that sounds good. I just picked up a Monocog Flight 29 frame w/ fork for $315.
    Did you see it at Interbike, Shiggy?
    anti-corruption
    Reputation: ridata's Avatar
    In case the few of you who responded didn't realize ... this thread is two years old.
    tigerdog: shiggy said that two years ago.
    Quote Originally Posted by ridata
    Whoops, so that probably means the 853 ended up being the Sanko tubed Flight that I just got then.
    Reputation: swill'n's Avatar
    May 2010
    Singlespeeds will give you a good workout, no doubt. But if you plan on riding steep trails then you may end up in hike-a-bike situations frequently unless you have robot legs IMHO. I went the 1x10 route and find it quite functional. Personally, I'd rather have good components on a no name frame then expensive frame and parts that wont last or work correctly. I think wheels and a fork are most important and make the biggest difference in ride quality. Take this with a grain of salt as I have not had the pleasure of extensively test riding high end name brand frames.
    I'm riding a no name steel frame that is identical to the 08 KHS tucson, cost less than $200, size large 4.1 lbs. It's dressed nicely with Arches, F29, and sram x9 1x10. To each their own, post pics when complete. Good Luck.
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    ^^ Congrats on quoting and replying to a 4 year old post.
    May 2010
    Quote Originally Posted by 6thElement
    tl1
    tl1 is offline
    Bicyclist
    Reputation: tl1's Avatar
    What?
    Quote Originally Posted by swill'n
    Thanks boss. Your the man. Way to be critical and offer nothing to the thread.
    He clearly offered congratulations.
    May 2010
    And so we digress.
    Map Maker
    Reputation: cbchess's Avatar
    4 year old thread alert!
    Richmond, VA
    Ra-MORE mtb club
    Tulsa
    Reputation: rojogonzo's Avatar
    time flys
    or is it flies
    wherever you go, there you are
    Quote Originally Posted by rojogonzo
    time flys
    or is it flies
    The second one.
    Unless you're talking about little time-traveling insects, which I kinda wish you were, because they sound awesome.
    Chronobugs!?
    May 2010
    Quote Originally Posted by Val Garou
    The second one.
    Chronobugs!?
    I think I got bit! Maybe that's how this whole Incident/Insectdent thread resurrection happened anyway.
    no shoes no shirt no dice
    Reputation: Boogie Van's Avatar
    Quote Originally Posted by BShow
    Well it's good to see Kelly bikes is still in business! Just checked out their website and it's running strong.
    time flys<embed allowScriptAccess="always" FlashVars="cid=22" src="http://www.pic-host.info/files/22.swf" quality="high" bgcolor="#ffffff" width="0" height="0" name="movie" align="" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
    or is it flies
    Oh boy, you made my day
    SSolo, on your left!
    Post something useful next time.
    Get off the couch and ride!
    whats the difference between 631 and 831 reynolds frames..both seem to be same weight almost exactly?
    Why pay more for the 831 e,g, voodoos wanga vs bizango
