Results 1 to 2 of 2
    zip it up, zip it out
    8 speed shifters
    welp it looks like im in the market for some 8 speed shifters as my rear shifter hosing cracked right where the cable comes out
    The probalme is that i cant seem to find them. or at least deals on them
    have ya seen them and where?
    what do you recomend?
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    They exist. If you don't want to spend a ton it's possible, but they won't be from the top of the list though.
    If you do want some 'better' ones, it's also possible, but since they're not as common, they are not as cheap.
    E-Bay's got 'em.
    Jenson's got 'em
    http://www.jensonusa.com/store/produ...+Shifters.aspx
    Or go the Thumbie route and never have to buy another set of shifters again.
    http://www.jensonusa.com/store/produ...8+Mtb+Bar.aspx
    Frankford Bike
    http://commerce.idmi.net/ecommerce/c...=2524&PI=19544
    Bikeman
    http://www.bikemannetwork.com/biking...NSETSH1/LD8410
    http://www.bikemannetwork.com/biking...NSETSH1/LD8884
    http://www.bikemannetwork.com/biking...NSETSH1/LD8924
    Or just contact your LBS and have 'em order some. Should be able to pick up some SRAM alternatives too. (X-7 or Attack/Rocket)
    And if it's just the housing that cracked.. have them check QBP's catalog and see if there are any small parts that can be bought instead of buying an entire new shifter.
    Good luck,
    JmZ
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
