My problem is that I want the rim to have a road bike profile to match the front.....the front is a lefty so I'm good there. I was going to have one built but would like a cheaper solution.
Guess I worded it wrong. I know a 29er will work. What I am looking for is a wheel where the rim is an aero style (I think that's what its called) at 30mm in size with no braking surface. In this case a MTB rim wouldn't work. I need to be able to run a 28mm tire on it.
Guess I worded it wrong. I know a 29er will work. What I am looking for is a wheel where the rim is an aero style (I think that's what its called) at 30mm in size with no breaking surface. In this case a MTB rim wouldn't work. I need to be able to run a 28mm tire on it.
hed has a rim and wheelset offereing that are 24mm deep (24.5 for the new + model). hed ardennes is their complete wheel, but i don't think they come without a braking surface, even when offered with a disc hub. if you want to build, hed belgium rims are offered without a braking surface. the original c2 is 23mm external (~18-19 internal), the plus is 25mm external (~20-21 internal). Both widths will fit your 28c tire just fine.
easton makes a set of disc cx wheels without a braking surface, but the rim depth is still only 24.5mm. it's internal width is 17.5mm. ea90 xd.
there's been a lot of interest in the c2 and c2+ offerings by hed. the wider profile is changing the tire profile, permitting riders to use lower pressures with better performance in speed, handling, and comfort.
i think we'll see more offerings in the near future with the demand in the 'gravel grinder' market.
I used Light-Bicycle 50mm deep carbon rims and laced them to American Classic disc hubs for my road bike. One thing to check if using 29er rims is the width (will they fit in your road or 'cross frame) and max pressure. Some MTB rims are 60 PSI max (although aluminum rims generally don't have an issue, but it's worth checking). I replaced my DTRR1.1 rims with WTB Laser Disc Lite disc hubs and saved 9oz, even with 9mm and 10mm thru-axles. I built a carbon-rim disc 700c road wheelset for about $700 or so. There's a 200+ page discussion on the 29er forum about the rims, the upshot is that they are riding well for enduro, so my guess is road and cross should be fine.
I did find the Velocity site and the deep V was the only rim I could find that was similar to what I have. I was just hoping that now the road disc brake option was out there would be some choices in pre made wheels I could choose from. The stock rear hub is very draggy but the Lefty front is super smooth. Maybe at this point my only option is to get my current rear wheel laced with a new hub.
Deep V's are around 600g I believe. The braking surface on the carbon hoops is not that visible IMO.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
