Results 1 to 3 of 3
    Reputation: MikeDee's Avatar
    5 arm compact crank
    Where can I get a 5 arm compact crank (square taper preferred)? I have a 29er and want a crank that can take a 20 tooth chainring.
    Reputation: shiggy's Avatar
    Dec 1998
    Peter White Cycles sells TA cranks. You can pick any spider size you want. Square taper and lengths from way short to 185mm.
    mtbtires.com
    Basura Blanca
    Got a set of RF Turbine LPs from chainreactioncycles last month for a very fair price. They're ISIS, but if you poke arond you might find something in square taper.
    - Joe
