    2x9 drivetrain, help please!
    So I am going 2x9 on the 2006 Kona Coiler that I am building up from the frame, and I would like to know what to do shifter wise. I mean, are there shifters with only 2 positions specifically for this purpose or will a shifter with three positions work and if so how? Thanks!
    By the way, I was thinking X.9 trigger shiters and rear derailleur with a SRAM X.Gen front derailleur, lemme know what you think!
    Rocket Scientist
    Mar 2005
    I'm not sure if this is the proper way to do it but I just used the limit screw on the front derailer to keep me from shifting into my bash guard.
    ravingbikefiend
    Just set the upper limiter screw on the the front D to prevent it from trying to shift into a ring that is no longer there.
    I ride with 65'er...he's a mountain goat....But then again, we need to throw him in the mud and pack his pockets with lead shot before a scale will read him. - Psycho Mike
    -Environmental stickers don't mean shite when they are stuck to CARS!-
    Reputation: B.S.'s Avatar
    What they said about the limiter screw. Also, do not move your derailleur position on the frame. Leave it in the position as if you had 3 rings. It'll look a little goofy with the big gap, but that's where it works best.
