Results 1 to 7 of 7
    Jun 2013
    Ztr 355 question
    I have a K2 zed 2.2 and I'm looking to upgrade the rims, hubs, etc. I'm on a budget and was looking at the no tube ztr 355's. they have a rim brake model. My question is would they be strong than the stock rim? Ok for a heavier rider about 180-190lbs? I'm a beginning rider and the trails I normally ride on are a bit rough, rocks, roots, holes, etc. not just flat dirt track. Hit some smaller jumps nothing big. Would these be a good investment until I can upgrade further and my skills improve?p
    any advice on hubs for rim brakes?
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    No they would not be a good investment.....for you.
    It is a really light rim....actually you are probably over the weight limit for then anyway.
    Being a beginner you are less likely to choose good/smooth lines through the rocks and roots. This likely ending in a damaged wheel.
    At 190 lbs I found them to be way too flexy.
    There are other options out there.....seek them out and avoid uber light weight rims.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Church of the Wheel
    Reputation: mtb143's Avatar
    Ztr 355 question
    355's are plenty strong enough for your weight and application. The limiting factor will be how we'll they're built. If built properly you'll be fine. If built poorly any rim will suck it. Go with a reputable wheelsmith for best results.
    "I thought you'd never love me without my Mojo." -Austin Powers
    Jun 2013
    Well I got a go for it and a no Haha. I have seen some others such as the mammoth and the eliminator. Both stronger rims. Any advice on mismatching rims?
    mtbpete
    Reputation: changingleaf's Avatar
    The 355's are lightweight rims, but I agree that the limiting factor is how well they are built. If you run air pressure too low they will dent easier than the typical OEM rim. As far as I know Stan's does not have any 355 26in 32h rims left with polished sidewall. They may have some with and anodized sidewall which are still usable for rim brake. I have two pair of 32h's with the polished sidewall that I can build onto DT Swiss 240 hubs, or American Classic hubs.
    lamer
    Reputation: llamma's Avatar
    My understanding is that the 355s are the lighter predecessor to the Crest. Having ridden Crests for the past year and being 200-205 lbs geared up (obviously over their weight limit), I would say go for something stronger. I also ride rooty, sometimes rocky, trails and take smaller jumps. I have had to get the Crests trued every couple of months.
    mtbpete
    The 355's are actually the heavier predecessor to the Crest. The 355 26in rim is 355g and the Crest 26in rim is 340g. Most of the weight difference is in the larger bead hook on the 355.
    If you need the wheels trued every couple of months then they are either damaged or not being trued with even tension. A 26in rim will always be substantially stronger than the same rim built with the same materials as a 29in rim.
  1. Bottom Braket Question, yet another pf30 vs bb30 question.
    By ntm1973 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-21-2013, 09:30 PM
  2. Replies: 4
    Last Post: 11-06-2012, 04:02 PM
  3. Replies: 4
    Last Post: 02-07-2012, 07:10 PM
  4. iBis HD owners.. i have a question..(noob question)
    By superunknown222 in forum Ibis
    Last Post: 08-07-2011, 09:59 PM
  5. Forest City Trails Question: Sandusky Question?
    By bycyclist in forum California - Norcal
    Last Post: 07-26-2011, 11:43 AM
